100" Hybrid Rebuild - Page 5 - Defender Source
Old October 27th, 2012, 09:12 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Yep I will have to add the intermediate tub supports as well.
I matched the spacing between the spring perch and tub on my 110 and by the time I lined it up with strings the spacing off the frame in the front of the tub also matched my 110. So in short, I don't think I raised the body to clear the arch. It's close, but I think it's where it needs to be
Old October 28th, 2012, 01:16 PM
Thanks, that's good to know.
Originally Posted by pendy
I'm here for the D's
Old October 28th, 2012, 09:31 PM
Just trying to get my hybrid project off the ground. Trying to find a truck to start with and considering the 109 pickup at ECR. If I can get a cheap enough rolling frame from a LWB and stretch it, this might be a viable option as the truck is a bit expensive for a body shell which is what it appears it would be to me.
Old October 29th, 2012, 10:40 AM
winn442's Avatar
winn442
Winn Bearden
Looking good! Glad you're bringing the 'ol girl back to life! Those wheel well "humps" (and the battery box bottom) were made by an old man who made air conditioning ductwork...was good friends with his sons, he did it for free!
I'll donate a good 90 windshield frame and glass to the project if you're not going to use that cut down NADA top......in case you were wondering, the old windshield was an SIII but I was missing the SIII brackets and hardware so I cut the hinges off an old SII bulkhead and windshield and welded them to that one.....that green tinted glass was cut out of an old Pullman railcar!
Winn Bearden
Old October 29th, 2012, 01:31 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Thanks Wynn.
I'm not opposed to taking donations! That might be nice to have D90 windscreen. At this point I'm leaning towards a NAS style ST cage so that would look better with the correct windscreen. The hard top is certainly nice and I kinda hate to make it obsolete but a soft top is too tempting.
He did a good job on those those wheel wells, but I'm thinking they gotta go. I would like to be able to put lock boxes back there. It will be a lot of work because I will have to add to the tub sides and remake the arch. After lining up the tub it looks like I can add 4" bumpstops and it will keep the tires from rubbing.
Old October 29th, 2012, 01:36 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Oh, the other day I found something you left behind. Some missing teeth.
Old October 29th, 2012, 02:37 PM
winn442's Avatar
winn442
Winn Bearden
Yeah, that was Helicopter Pad. Last trip to Tellico right before they shut it down.....had to come down Schoolbus and all the way back to camp with a chummed up diff. It was either that or come back DOWN Guardrail, and that's zero fun even with a fully functioning truck.
Been meaning to talk to Bill about that, that was a GBR 4.75 R&P, it shouldn't have done that....
Buddy of mine used to wheel a SIII with revolver shackles, the articulation he got was as much as a coiler...what he did was completely cut out the stock wheel wells and had some taller and wider ones made. Then he had a custom fuel cell made to fit in the narrower bed, and still had square wheel boxes to mount tool boxes on.
I'll hold on to the windshield frame, I don't get to your neck of NC often, I usually have to go to either Raleigh or through Chattanooga to Nashville.
------ Follow up post added October 29th, 2012 02:44 PM ------
Next time I'm going thru NC, I'll let you know and maybe we can meet up somewhere and I can hand it off to you....
Winn Bearden
Old November 10th, 2012, 02:06 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I put the Safari Gard 3 link on this week. It was a tight fit but in the end everything looks pretty good. Does anybody know what the round tubes running along the control arms are supposed to do? It looks like I need to have them facing down because otherwise they hit my bulkhead outrigger. One write up I found shows them facing up.
ID:	60653   Click image for larger version
Old November 10th, 2012, 02:14 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
I ran mine facing up on the disco but didnt have the outrigger issue. Honestly I'm not even sure why they put that silly little tube on there and why they didnt just make it of thicker dom or sleeve it.
Old November 10th, 2012, 02:41 PM
Was the tube to reroute the axel breather through?
-Jeff
I thought it was for the ARB lines.
Looks great Jeff!
Old November 10th, 2012, 02:45 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I haven't done anything with the axle breather tube. It's currently broken off at the fitting on top of the axle but it doesn't look like it will be an issue.
Old November 10th, 2012, 08:03 PM
awesome, I hope to see this at Uwharrie in the spring.
Old June 1st, 2013, 07:14 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Wow long time since I've been here.
If I cut these windscreen mounts off and put defender mounts on will I have any problems fitting a defender windscreen?
Old June 28th, 2013, 08:56 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Is this getting too tall? It's about 4-5" taller than the 110 next to it. I have RTE 3" springs on it with 38" swampers.
Old July 5th, 2013, 12:24 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I'm in the middle of bulkhead repair. I'm wondering if the bulkhead feet should be inserted into the pillar section before assembly. Because it's a separate piece one would think that it could be inserted later, but because if the indents for the wing mounts it doesn't look like it will slide in after fabrication. Any tips here?
Old July 5th, 2013, 12:44 PM
I need to do this too, and I think you need to insert and weld it in first. I believe they are just separate pieces for ease of manufacturing and you might have trouble inserting after (but they need to be welded in anyway).
Old July 5th, 2013, 12:48 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok thanks Galpin. If they get welded anyways then I'll put it in first. I'm going to get it dipped so I think it will be ok.
I can't imagine how these bulkheads last at all. There are so many layers stacked up one on top of the other. There is no way to make them last without dipping.
Old July 5th, 2013, 01:16 PM
O yeh, don't fergit you gotter get yer nut plate in thar someways. Elsewize, yerl be installatin yer hingys nuts wit tweezers y'know.
Old July 5th, 2013, 01:44 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
You mean these here doohickeys?
They can go on afterwards. I don't have new ones. But I would like to have it dipped first anyways.
Old July 5th, 2013, 02:23 PM
No, I'm guessing he means the ones for the hinge screws. My plan was to put rtv in those, or maybe some screws.
rebuild
A Ghost is Born (100" Hybrid) Part 2 djrover Truck Build-up's & Restores 11 October 4th, 2014 07:31 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
