100" Hybrid Rebuild - Page 2 - Defender Source
Old March 6th, 2012, 10:01 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I'm not sure what's worse, damaging the frame mount or having a "consumable" mount that can be changed out. Granted, this example I am looking at has been beat to hell, but it shows a weak spot in the design.
ID:	48633   Click image for larger version
Old March 6th, 2012, 10:07 AM
Wow, the frame kink is impressive.
How about reinforcing the stock mounts before galvy? Put some 3/8 plate under there to act like a skid and additional bracing and it should hold up better. Likewise for all the other spots where you'd usually beat on the frame.
Originally Posted by pendy
I'm here for the D's
Old March 6th, 2012, 10:09 AM
Originally Posted by oilburner View Post
If you are looking for a good way to do the chassis outriggers, look up a 4x4 is born on youtube. Episode 2 or 3 has the frame mods, they end up doing a decent job of hanging the bulkhead outriggers. It should be possible to use off the shelf rover outriggers everywhere, I think that goes a long way to making it look good underneath...
This makes me wonder why people don't end up making bolt-on tubular outriggers out of stainless. It seems like a lot less work than forming sheet metal to look like factory. I guess there's some value to making it look "original", but the original design seems (to me) less robust and prone to rust.
Old March 6th, 2012, 10:20 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Yeah this frame has had a hard life. It's a full 7/8" shorter from the front to the transmission mount on one side. I was definitely thinking of full reinforcement along the length of the frame rails on the bottom. I could add some reinforcing under the stock mounts that would help a lot.
Old March 8th, 2012, 09:58 PM
winn442's Avatar
winn442
Winn Bearden
It's in pretty good shape considering that it's a mid 70's frame, I built it in 95-96, and wheeled it at Tellico 2-3 times a year from 1997 until they closed it. Sometimes it wouldn't even come off the trailer between trips. Tellico was about the only place I took it.
It's been in LRO, drove a reporter around one year, Cafepress had t-shirts, lunchboxes, and they still have a mousepad with it on it. http://www.cafepress.com/+tellico_ap..._winn,11739039
In an 18 month period, that truck conquered every trail at Tellico without pulling a line.
This is probably the last trip...lower 2 (rockgarden)
I owned that truck longer than any other vehicle in my life, bring her back to life, hope it gives you as much joy as it did me.
Winn Bearden
Old March 8th, 2012, 10:10 PM
winn442's Avatar
winn442
Winn Bearden
BTW, sorry I took all the good sh*t off it before I got rid of it...but the 90 needed the skidplates and shafts and lockers.
Call me if you want to know the details of all the engine mods...229-389-1766
Also, remember the axle housings are the old ones, but the spindles and hubs are the new style so it can run the post '90 shafts...hard to find hardened shafts in the old length...and keep the LT 95, you'll never be able to tear it up...unless you put 90 wt. in it...it uses motor oil.
Winn Bearden
Old March 8th, 2012, 10:15 PM
Winn how about a thread dedicated to some of your builds? How many of your old trucks have gone up for sale or have sold here in the past month or two? Seems like a few!
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Hey that's awesome Winn. I have had a lot of fun with it so far by digging into it. Pulled the engine today and pressure washed it off. Looking forward to start getting it built in the new frame. I should order that mouse pad! I got your info from Scott the when I picked up the chassis. I would like to give you a call one of these days to chat about the truck.
Cheers.
Jeff
------ Follow up post added March 8th, 2012 10:20 PM ------
Yea what's up with that? Ha ha well if it had all that good sh!t on it still then it would have cost a lot more to get it. I can cost a small fortune to put all that back I'm finding out. I'm thinking about the Toyota conversion. That's good to know about the later hubs. I noticed the vented front disks which indicated a later axle but wasn't really sure.
I almost need a cheat sheet on all the different years and models that the parts are from
Old March 8th, 2012, 10:43 PM
winn442's Avatar
winn442
Winn Bearden
It would take all day to type up everything I did to that truck...I've got a two page writeup on it somewhere, Ill find it and send it to you.....but you're welcome to call if you ever have any questions
I've got the rocksliders still, was going to shorten them and put them on the 90, but I don't have time like I used to so I got some store-bought ones (gasp!)...they're yours if you want them...
------ Follow up post added March 8th, 2012 10:46 PM ------
Lost count of how many I've had over the years, but the only ones I've seen on here lately were the green 110 and the trail truck.
Winn Bearden
Old March 9th, 2012, 09:04 AM
winn442's Avatar
winn442
Winn Bearden
Wrote this several years ago when I was thinking about selling it whole.....
Engine- it’s a 3.5 Rover. Spent a LOT of time and money rebuilding this motor. Besides the machine shop work (crank turned and block bored) I did it all myself.
- bored .030 over, new pistons and rings. Rods, crank, and block Magnafluxed.
- crank turned and balanced, all new rod and main bearings.
- heads reworked, with larger 4.6 “tulip” valves (more flow), new springs and guides, heads extensively ported and polished with valve guides cut down and polished in the runners, combustion chambers ground to stop the “valve shrouding” with larger valves. Hardened valve seats installed.
- cam- 3 degrees advanced for more low end with Buick 3.8 adjustable true roller chain.
- 3.8 front cover with Buick high volume oil pump and Buick water pump
- HEI distributor (1975 Buick 350)
- Edlebrock manifold with Holley Pro-Jection fuel injection system. Simple system with no O2 sensors. Will run at any angle. Manifold and head ports ground to match.
- Hedman headers with full dual exhaust
- Delco 160 amp alternator
I used this truck for a daily driver for about three months, so I would guess that the engine has less then 2000 miles (including trail rides) on it.
Transmission- LT95- one piece transmission/Transfer case. Toughest Rover unit ever built. Used in the 101’s, and STILL used today by the Australian Army in their 6x6 Perenties with Nissan 3.9 Turbo diesels. Only problem these untis have is the detent springs get weak. Never bothered to replace them, I just use two wooden sticks to hold in place, one for low range and one for high. It even has an OD unit, which is robust compared to the series units. Back when I used this for a daily driver with the OD it would hit 90 MPH easily.
Front axle- Hardened CV’s and shafts, Maxi-drive 4.75 ring and pinion, ARB locker. Southdown guard. Sleeved steering rods. Maxi- drive hubs.
Rear Axle- Maxi-drive shafts and 4.75 R&P. ARB Locker Maxi- drive hubs. Currently missing two teeth on ring gear, will replace if sold.
Body- Basically a Series III 109 with the rear bed shortened at both ends for the 100” wheelbase. Defender hood and grille. Rollbar welded to frame. Two deep cycle Optimas under the seat. ARB compressor. Defender seats. Will throw in a new Tuffy box. Also included is a full hardtop that I custom made to fit, with a roof rack and rear door. Door tops included. I also have a set of rare early 110 doors that were painted to match, they have rollup windows but recessed outer handles a la Series, but they will cost you an extra 500 bucks.
Frame- Won’t lie, the frame is rusty and tweaked in several places. Price includes a mint Range Rover frame to go with the truck. One could probably replace the rear section and go for years with no problem.
Other- Very stout homemade front bumper (same dimension as a defender), brush guard, Southdown steering guard, and a LOT of skidplates underneath. Some are storebought, some homemade. Everything is WELL protected. Rare 15x10 wheels, 38x12.50-15 TSL’s, only three trips to Tellico on them. (15’s stay on rim better than 16’s, I run 9 pounds when trail riding). Warn 9500 HS winch with 150 feet of rope, not cable.
I spent years building this truck, and is probably one of the most capable Rovers around. It has done EVERY trail at Tellico without a line pulled at one time or another. If you want a daily driver, with a little work and a extra set of tires, it could pull double duty. I used it to commute for a while and it drove great on the road with “normal” tires.
Winn Bearden
Old March 9th, 2012, 09:20 AM
winn442's Avatar
winn442
Winn Bearden
In case you're wondering, this is where all the good stuff went....8 month every other weekend rebuild
Winn Bearden
Old March 13th, 2012, 09:42 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
While dissembling the old setup I found a spot where the front drive shaft had wallowed out about a quarter inch deep well on the transmission crossmember. I am wondering if I need to find a shorter bell housing or just cut into the cross member to allow for more articulation in the front end. This is an LT95 on a 1988 Range Rover chassis. My research shows that the LT95 was used on the Range rover through 1983. The factory transmission mounts line up on my new chassis but perhaps either the crossmember is too far forward with this arrangement or the tranny is too far back.
Does any one have any experience with this issue? I doubt it since there aren't that many LT95s around. Apparently there is a short bell housing for a 101 but I have no idea where to find one. This is definitely limiting the front articulation so I would like to figure out how to overcome it.
Thanks.
Jeff
Old March 13th, 2012, 10:18 PM
I would just notch and weld/reinforce the crossmember myself.
Old March 14th, 2012, 04:11 PM
winn442's Avatar
winn442
Winn Bearden
You'd also have to change the input shaft if you went to a different length bellhousing....I didn't know there were different lengths on a LT95...I know there are different lengths on the LT85, LT777, and R380.
Winn Bearden
Old March 14th, 2012, 04:23 PM
Short shaft LT95 was used on 101 forward controls.
Old March 14th, 2012, 07:56 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
This is one company I came across years ago that sells 101 mechanical parts. I would just keep it simple and notch out the cross member and be done with it.
http://www.nkrecovery.co.uk/index.html
Old March 14th, 2012, 08:51 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
what a bone lol. (just kidding) notch the crossmember, common issue with lifted Series rigs. I sometimes make driveshafts that sre of a smaller tube as well as a little scallop action to the frame (insert a section of a tube)
Use nickle copper for the brake lines. Stainless sucks and designed to attract people who like shiny things.
Matt Browne
Old March 14th, 2012, 09:56 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I do like shiny things... And I want them to last most importantly. Why not stainless? It sucks to work with or another reason? It has some type of copper on the old frame now
Old March 15th, 2012, 05:36 AM
aka rover's Avatar
aka rover
ed angel
95 D90
The stainless lines are just fine untill you need to do a do a repair on them they are not as easy to flare and get to reseal.
they are more prone to kink offroad if they get hooked on a log limb etc. I would stick to copper nickle on a trail rig and leave the stainless to the sportscar guys.
Just my .02
Nice build By the way!!
85 D110 3.5 3 DR
Old March 15th, 2012, 05:51 AM
winn442's Avatar
winn442
Winn Bearden
They actually produced the LT95 up into the 90's for the Aussie Perenties. Can't remember the details, but it had a suffix on it (LT95B or something) Third axle ran off of a PTO coming out of the transfer. Wonder if they used an adapter plate with the standard bellhousing or they had a special bellhousing for the Izusu 3.9? One of those bellhousings or adapters would make for an easy conversion...
Winn Bearden
rebuild
A Ghost is Born (100" Hybrid) Part 2 djrover Truck Build-up's & Restores 11 October 4th, 2014 07:31 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
