1+1=1 - Defender Source
Old June 13th, 2012, 09:06 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
1+1=1
Picked up another 110 this weekend with the hope that I can combine the parts from my '86 ROW 300Tdi 110 and the recently aquired '91 LHD converted UK spec 300 Tdi 110.
So now my shop is overflowing with rover parts and I'm ordering new chassis next week before starting down the assembly path.
The end result is intended to be a ROW configured 300TdI 110 SW in Arles blue.
ID:	52900   Click image for larger version
Old June 13th, 2012, 09:32 PM
texrover's Avatar
texrover
Jason
nice work! love arles blue. look forward to seeing more about your build!
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old June 21st, 2012, 02:08 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
So here is where it sits for the moment - Not able to do much on the truck at the moment with a new job and all the household stuff cluttering my shop until we move into our new place on the 15th of July.
  • New Chassis order goes in tomorrow
  • Safari Aux tank and door skin order goes in Monday
  • Misc Parts orders in by the 29th of June
Old June 30th, 2012, 02:49 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Chassis on order, YRM parts on order, still need to source a few things:
Rear disc conversion parts order
Exhaust systems order
Long Range Safari Fuel and water tanks ordered
Spending a couple hours a week cleaning parts when I can spare the time, but overall progress has ground to a halt as I have almost no room to work until July 15th.
defender-restoration
Old July 29th, 2012, 05:35 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Got something done...
Old roller is ready to go to the scrapyard. Just waiting on the new chassis to arrive.
ID:	54840   Click image for larger version
Old August 14th, 2012, 02:15 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Got a little more demolition completed this weekend.
Old frame is out in the bone-yard if anyone wants bits from it. Made a support to hold the complete engine while doing the build, and finally I can start assembling instead of pulling apart rust-ridden bits of what used to be nuts & bolts... Oh, and I forgot but apparently while I grabbed some lunch the the rear output seal decided to remind me that it needs replaced.
ID:	55757   Click image for larger version
Old August 14th, 2012, 03:09 PM
Use a Dana 60 rubber seal instead of the stock leather one. I have never seen a salisbury not leak from the pinion.
Old August 14th, 2012, 04:50 PM
As Ron suggested, use National Oil Seal 9316 or similar (available at Napa or http://www.amazon.com/National-Seal-...=Oil+seal+9316). Watch out for a scored pinion flange as that can be the cause of the leak.
------ Follow up post added August 14th, 2012 04:54 PM ------
Here's a thread where I talk about the scored flange and how to fix with a Speedi Sleeve:
http://www.defendersource.com/forum/...=Speedi+sleeve
Old September 19th, 2012, 12:30 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
New Chassis is in the shop at last!!!
Old September 20th, 2012, 12:18 PM
Looks like two chassis!
Old September 20th, 2012, 01:12 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
plus a ton of parts from YRM...
But only one of the chassis is for my truck - VIN stamped and everything
Old September 20th, 2012, 03:03 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Nicely done on the VIN stamping. Was that done by the Chassis builder or as a later add-on?
Oh.. whats YRM (acronym translater is failing me today)
Firemanshort
1980 Stage One 109
Sterling, VA
Old September 20th, 2012, 03:07 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
http://www.yrmlandrover.com/
yrm metal solutions
Old September 20th, 2012, 05:31 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
yrm metal solutions
Thanks. Indeed YRM was able to tuck quite a lot of parts into the crate between the frame rails.
I'm very much chomping at the bit to get working on the roller - but I need to spend a half a day cleaning up the shop from the last bit of demolition and the little bit of work I've done on the 90.
The crate left me with a truckload of kindling that needs a home as well.
Old October 8th, 2012, 12:36 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Finally assembling instead of disassembling
ID:	58699   Click image for larger version
Old October 8th, 2012, 12:55 PM
Are my eyes deceiving me, or is that the longest chassis I've ever seen?
Old October 8th, 2012, 01:24 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
It gets longer the more you play with it.
-Jeff
LMAO
It's not the size of the chassis, its how you use it...
Old November 3rd, 2012, 05:44 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
A bit more done...
So it's a roller, temp bulkhead in place to get all the wiring/piping done up for controls.
Body prep in process getting ready for paint this month...
Old November 3rd, 2012, 07:43 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
How do you like the quality of the YRM battery box?? Please post more pictures of it when complete.
thanks
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old November 6th, 2012, 02:24 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
thanks
So far I like it. The parts all match up quite nicely and the material is stout and well formed. I haven't had a chance to work on the truck much the last week so I haven't done any more than the test fitting, but it seems like a simple fit. I've got a deep battery box extension that I can't decide if it want to install or not as it would interfere with chassis slung auxiliary fuel/water tanks.
