1+1=1 - Page 5 - Defender Source
Old May 1st, 2013, 06:17 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by evilfij View Post
Start with cheap/free and easy and work your way up is my view.
Most of the time I fall into that MO, too close to this project, and the added pressure of a "done by date" must be clouding my judgement.
Old May 1st, 2013, 06:30 PM
Should be able to run with no damper. All it is meant to do is limit kick back in the steering.
I ran without one with 35's for six months (forgot to install the replacement after bending one in a U).
Old May 3rd, 2013, 02:49 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Double check the swivel preload as well.
-Jeff
I'm into the swivels this weekend...
Steering looseness tracked to the steering shaft to box joints being 25yo.
Old May 4th, 2013, 10:42 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Put a few bits on the truck instead of finding a place to store them in the warehouse...
Old May 13th, 2013, 12:09 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Ready to go to the overland expo???
to be continued....
Old May 13th, 2013, 12:19 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Ummm....
What. Did. You. Do?
Semper Fi!
Old May 13th, 2013, 12:47 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
That looks like a broken timing belt that caused a valve to be in the wrong place that casued a push rod to push too hard on a rocker arm that has now broke.
Smells like a more than a few $Benjamin$- and a ruined trip.
(off topic - why is the license plate mounted in one place on photo #1 and another on photo #2?)
Firemanshort
1980 Stage One 109
Sterling, VA
Old May 14th, 2013, 01:09 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
brian you still going to expo I should have the shirts ready to ship just want to make sure you still want a partial to AZ
Old May 15th, 2013, 07:26 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Photos out of order...
The truck spent time on a trailer twice in a week and is sitting out the trip the Expo...
Not quite enough time to get it ready and repaired with all the other work the last few weeks.
Such is life, and contingency plans that were put in place we activated and we are showbound with the 130 instead of both trucks.
Old June 16th, 2013, 12:52 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Way behind on updates for the project that was done and is now back in the shop...
Still need to pull the second head off to see the extent of the damage to the engine, but the engine was first generation and not being serviced at a dealership due to the geographical location of the engine. So the mainshaft timing gear had never received the service to resolve the belt eating issue. STC4095K was not installed as this particular engine was in the US at the time the SB went out.
So the belt ate itself (despite the correct timing) resulting in contact and valve pieces destroying the turbo and either the headgasket, rings, or piston head.
To: Click image for larger version
A half days work and the old lump is out - most of the ancillaries are off or have been loosened in preparation for installation into the newly refurbished lump courtesy of the fine folks at Turner Engineering.
Will spend another half day moving over the good bits and hunting down another timing belt as I used/sold the last one I had in stock. Anyone have a 300tdi belt handy while I wait for the 2 dozen I ordered to come in the next container.
Old June 16th, 2013, 10:06 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I can send you a spare belt. Just PM'd you.
Old June 17th, 2013, 11:56 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Thank you! Now I have no excuse to drag the rebuild out later than this week.
I'll be pulling a turbo from a spare engine in the back of the shop and everything else is ready to clean and swap.
Old June 17th, 2013, 12:42 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
No problem.
Old June 18th, 2013, 12:08 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
A short video on the engine pull...
Old June 18th, 2013, 11:03 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Nice to have met a friendly forum member today in Portland, and assuming nothing else goes wrong ill be back home and going after the engine buildup and installation with some gusto this weekend...
Defender Parts, Service, Restoration, and Training
Old June 19th, 2013, 12:35 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Nice one!
Old June 19th, 2013, 12:36 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Old June 23rd, 2013, 08:05 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Old engine is stripped and the new one is getting built up.
Old June 24th, 2013, 03:09 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Done for the night...
All that remains to do before installation is to install the exhaust/intake/turbo and cooling system, and set the timing.
Old July 18th, 2013, 12:08 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Engine in - initial drives are all good. Still dripping a bit of oil from the rear exhaust can from the failure. Will end up pulling and replacing the cans.
Extended road test this weekend and then back on to finishing up the interior...
