Trevor Tarr - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Closed Thread
Old July 10th, 2004, 11:17 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Trevor Tarr
Model: 1997 Defender 90 #648
Contact: GerberBaby@aol.com
<img border="2" src="http://www.defendersource.com/bios/trevor_tarr/trevor_tarr02.jpg">
Modifications:
PROTECTION/RECOVERY
ARB bumper
Safari Gard heavy-duty rock sliders
Land Rover rear lamp guards
Safari Gard front & rear differential guards
Safari Gard front chormolly tie rod
Safari Gard rear tie rod Rock Gard
Rockware catalytic converter skid plate
Rockware pinion gard
British Pacific steering protector skid plate
Homemade limb riser cables
Aluminum chequer-plate wing-top and quarter-panel protectors
Warn receiver-mounted recovery shackle
Rockware Frame Sliders
Warn XD9000 winch
ENGINE
K&N air filter
Tornado air management system
Homemade snorkel with simplified routing, relocating air filter box to wingtop
Oil filter heat-dissipating radiator fins
Flowmaster Muffler
ELECTRONICS
Land Rover subwoofer
Land Rover 6-CD changer
Uniden PC-77 40-channel CB with headset/boom microphone, Radio Shack 48"
fiberglass antenna, PA speaker on light bar
Uniden BC-235 scanner with external antenna and speaker
moving map TOPO CD-ROM software
Nokia 6160 cell phone with speakerphone, external handset, external antenna
Warn jumper cable jack
120VAC power inverter
Interior/exterior temperature guage
Garmin eMap GPS, with external antenna
Laptop on adjustable dashboard mount, connected to GPS (running TOPO! moving map software) and to cellphone and to OBD-II diagnostic port
Overhead Console with CB/Scanner/Cellular speakers, cellular boom microphone, map lights, cargo light
6 12VDC outlets
ILLUMINATION/OPTICS
2 Hella 3000 fog lights on ARB bumper
4 Hella 500 driving lights on upper light bar
Rear spotlight
CCD video camera on motorized mount with infrared spotlight and interior
monitor
IPF Headlamp Upgrade
BODY/TRIM
Land Rover bimini top
Field Motor Services wing heater scoop
Quicknuts doortop fasteners
INTERIOR STORAGE
Wheel well Tuffy lock boxes (for tools and portable electronics)
Wheel well mount for NATO water can
Wheel well mount for oil/coolant jerry cans
Wheel well fire extinguisher mount
Fixed padded door-top storage brackets
EXTERIOR STORAGE
Land Rover safari roof rack with bracketry for four NATO jerry cans and two propane tanks
Two longitudinal bars to support rear ladders with basket removed, attached to two lateral hoops anchored on bed rails
Pickaxe head mount on fender-top chequer plate
Four hoop-mounted storage tubes (originally Swiss Army mortar round cannisters, for jumper cables, comealong, tow strap, and wine)
Hoop-mounted first aid kit
Hoop-mounted Olympic shovel/axe rack
Receiver-mounted side-swing four-bicycle rack
Safari Gard spare-tire-mounted Hi-Lift jack
Rear ladder mount for NATO jerry can
Frame-horn-mounted 3-burner propane stove rack
Rear ladder 5-gallon water jug mount
SUSPENSION
BFG 33" MT's (285/75R16)
OME 751 HD springs front, OME 762 HD rear springs
Bilstein shocks
Safari Gard drop kit
Front sway bar removed
Rear sway bar quick-disconnect
<img border="2" src="http://www.defendersource.com/bios/trevor_tarr/trevor_tarr01.jpg">
<img border="2" src="http://www.defendersource.com/bios/trevor_tarr/trevor_tarr03.jpg">
<br/>
Closed Thread
