Robert D. Leggiero - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Closed Thread
Old July 5th, 2004, 10:07 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Robert D. Leggiero
Model: 1994 Defender 90
Contact: rleggiero@us.nomura.com
<img border="2" src="http://www.defendersource.com/bios/robert_leggiero/robert_leggiero01.jpg">
Modifications:
Front Suspension:
MJLee Front shock towers and lower mounts (heim version)
Fox 10" resivoir shocks
Fox 10" position sensitive shocks
OME 764 MD springs
Safari Gard 3-Link system
Safari Gard Extended Brake Lines
Fabitron Tie rod and drag link
OME Steering damper
Energy Susp. Bump stops
Rear Suspension:
Off Road Shop Upper and lower shock mounts
Fox 12" coil-over resivoir shocks
Hypercoil 12" 400 lb springs
Hypercoil 10" 200 lb springs
Rockware Bent trailing arms
Drive train:
ARB Air Lockers front and rear
Ashcroft 4.10 Gears and bearings
Ashcroft Rear half-shafts and star drives
GBR Double-cardon drive shafts front and rear
Armor:
MJLee Diff guards front and rear
Safari Gard Rear Bumperettes
Safari Gard 2" Rear Receiver
Safari Gard Rear skid plate
Desert Rover Rock sliders
Rockware Frame sliders
Rockware Front bumper
Wheels & Tires:
Discount Tire 16x8" Steel Wheels offset 1" outward from stock
Buckshot Mudder 265-85R16 tires (33x10.5" unloaded)
Engine:
Extreem Outback Endless Air on-board air supply
Premier Power On-board Welder, 160 amp alt.
Flex-a-lite FLX-210 dual electric fans
Optima Yellow top battery
Optima Red top battery
Magnacore 8mm wires
K&N Air Filter
Borla Exhaust
Interior:
Customised Tuffy 12" Stereo Security Console
Alpine SEC-8048 Mobile Security System with motion sensor
Alpine 7618 AM/FM Cassette player and CD shuttle control
Alpine ERE-G180 11-Band Graphic Equaliser
Alpine CHM-S600 6 disk CD shuttle
Soundstream Reference 604 amp - 4 x 75W/channel
Soundstream Reference 500 amp - 2 x 125W/channel
MB Quart QM 218.02 CX 6.5" Component speaker set
MB Quart QM 210.01 KX 8" Coaxial speaker set
Kicker Solobaric 8" sub-woofer set
Lightning Cap 1/2 farad stiffening capacitor
Dynamat sound deadening material (Doors, tub, floor, seat boxes, etc.)
LO-JACK Vehicle recovery system
Cobra HS-70 All-in-hand unit CB
K40 CB antenna (4 foot glass)
Custom rear speaker boxes
Hella Map light
Power Antenna
Recovery/emergency gear:
LR Military tow rings
First aid kit
Hi-Lift jack
Max Axe tool
6V Lantern
Misc:
4.8 gal. air tank under tub
Custom third brake light
Hella Dual horns
<img border="2" src="http://www.defendersource.com/bios/robert_leggiero/robert_leggiero02.jpg">
<img border="2" src="http://www.defendersource.com/bios/robert_leggiero/robert_leggiero03.jpg">
<br/>
Closed Thread
1962 IIA SWB with Robert Davis Engine Conversion Jack Straw For Sale - Vehicles 1 April 12th, 2007 01:53 PM
Robert Kolander chrisvonc Defender Owners 0 July 5th, 2004 10:11 PM
Robert Goodall chrisvonc Defender Owners 0 February 24th, 2004 10:05 PM
Robert Bingham chrisvonc Defender Owners 0 February 24th, 2004 09:59 PM
