Ivor Clegg - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Closed Thread
Old July 2nd, 2004, 12:55 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Ivor Clegg
Model: 1984 Land Rover 90 Truck Cab
Modifications:
3.9 Efi (from 1994 Range Rover)
3.9 Efi radiator rebuilt to suit 90
ZF4HP22 Autobox (from the same 1994 Range Rover)
LT230 Transfer Box
Stock front axle, with vented brake rotors
1975 Range Rover rear axle, with solid brake rotors, right side shock mount modified to suit 90
Detroit Soft-locker in rear axle, with Ashcroft heavy duty half-shafts
Stock (3.54:1) ring and pinion gears
Old Man Emu springs (front - 764, rear - 763)
Rancho front shocks - RS9207
Old Man Emu rear shocks - N44
Old Man Emu steering damper - OMESD32
'Sumo Bars' high tensile drag link and tie rod
8" x 16" white 8 spoke steel wheels fitted with 265/75R16 Bronco Dirt Devils
2 x Optima Red Top batteries
Hard-wired jump-leads/power supply for rear winch using 350A quick connectors
Front mounted Goodwinch G-10 winch fitted with 3/8" Plasma cable
Rear mounted Superwinch X-6 winch fitted with 5/16" steel cable
Custom (ok, homemade) front bumper/winch-mount/bull-bar
Homemade rear cross-member (6" x 3" channel), with removable winch mount
Homemade diff protectors
Homemade sliders with integral (side-mounted) fuel tank protector
Unknown brand aluminium steering guard
80 Channel CB
Lots of recovery gear
Clubs:
Webmaster of Irish Four Wheel Drive Club web-site http://www.ifwdc.com
Closed Thread
