Greg and Brandi Jevne - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Old February 22nd, 2004, 09:38 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Model: 1995 Defender 90
Modifications:
Safari Gard Front Bumper
Safari Gard Front Skid Plate
Cad plated 360 degree d-ring
Safari Gard Rear Bumper Ends
Safari Gard Rear Skid Plate
Safari Gard Rear 2" Receiver
Safari Gard HD Rock Sliders
Safari Gard Front & Rear Chromolly Tie Rods
Safari Gard Spare Front Tie Rod
Safari Gard Diff Gards
Safari Gard Tire Carrier
Safari Gard JEK Stage III Suspension
Custom Safari Gard 4" Springs
Fox Racing Shocks
Safari Gard Rear Spring Droop Kit
Safari Gard Custom Front External Shock Mounts (4130)
Safari Gard HD Rear Trailing Arms
Safari Gard Custom Front & Rear Drivelines CV Style
Safari Gard 3 Link System
Spare 3rd Link
Safari Gard Crossmember
Safari Gard Steel Braided Brakelines
Tuffy Side Boxes w/arm pads
Tuffy Center Box
Safari Gard Utility Light Bracket
Hella Utility Light
3 Hella HID 4000 Driving Lights
1 Hella HID Back Up Lights
2 Hella HID 1000 Lights w/ custom SG Bracket
Superwinch Husky 10,000 Winch
Superwinch Recovery Kit
Masterpull Winch Rope
Safari Gard Custom Roll Cage (4130)
Reinforced Frame
Premier Power Welder Alternator and on board welder w/ helmet & rod
37x12.5R17 SSR Superswamper tires on KMC Custom Aluminum Wheels
35x14.5 Swamper Boggers on 3 piece Aluminum Beadlock MRT Wheels
35x12.5R15 Wrangler MTR on 3 piece Aluminum MRT Wheels
ARB Front RD56 Airlocker
ARB Rear RD76 30 spline Air Locker
Summers Bros. 300M 30 Spline Rear Axles
ARB Air Compressor
Custom Air Guage
Safari Gard D90 Custom Dash
Safari Gard 2.5 gallon Custom Air Tank
7 cfm Engine Driven Air Compressor
Dual Air Horns
Dual Odyssey Batteries
4:70 Gears
Cobra CB Radio
Mastercraft 4 point harnesses
Mastercraft Front & Rear Seats w/ custom brackets
4.6 Motor w/ Stage 1 heads port matched balanced and blueprinted (10,550 miles)
New Transmission 18,850 miles and T-Box
Headers
K&N Airfilter
Stage II Flowmaster with Custom SG 3" Exhaust
Lightened Fly Wheel
Computer Chip
Dual Friction Centerforce Clutch
Hi Lift Jack
Mean Green Starter
Rhino Lining complete interior
Land Rover Soft Top with tinted zip out windows
Land Rover Surrey Top
Land Rover Bemini Top
Safari Gard Rock D90
Some of the modifications:
Dana 60 front reverse cut, ARB Locker
Dana 60 35 spline full floating rears, Detroit Locker
5:13 Gears
Stock 3.9 motor
Advanced Adapter Atlas II Transfer case
NV 4500 5 Speed Transmission
Michelin XZL 11.00R16 Tires (39" Diam.) on Centerline Wheels
2.5 14" Fox coilover shocks
Eibach Springs
(2) Hawker Engineering 1200 Amp Odyssey
Mastercraft Front & Rear Rubicon Seats & 5 Point Harnesses
Mastercraft limiting straps
Weber Starter
Weber Throughout Bearing
Centerforce Clutch Pressure Plate & Fly Wheel
Trailready Beadlocks
AGR Hydraulic Power Steering
Premier Power Welder & Alternator
Tuffy Security Lock Boxes
Fuel Safe Fuel Components
Earls Performance Products Brake lines and hoses
Superior Axle Shafts Front & Rear
CTM Ujoints
Other Rovers:
1982 Range rover 2-door
1976 Range rover 2-door
1967 Series IIa 109 6-cyl
1962 Series II 88
