Eric Dube - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Closed Thread
Old June 21st, 2004, 10:43 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Eric Dube
Model: 1997 Defender 90 #1280
Modifications:
Safari Gard Front Bumper w/2 Dixen Bates Recovery points
SG Front Skidplate
Warn XD9000i Winch
SG Rear Skidplate w/ Receiver Hitch mount
Safari Gard Rock Gard & Chromoly Tie Rods
British Bulldog (2-Bolt style) Diff Guards
The Off Road Shop Rear Bumperettes
Desert Rover Sliders
BFGoodrich Mud Terrains 33x12.50R15
Custom 15"x10" Steel Rims
Safari Gard Chromoly Trailing Arms
Fox Racing Shocks with External Reservoirs
Warn Black Diamond Steering Stabilizer
Safari Gard Custom OME Springs (approx. 3.5" of lift)
Spicer High Performance Front & Rear Driveshafts
The Off Road Shop Front & Rear Shock Mounts
Energy Suspension 4.5" Bumpstops
SG Stainless Steel Braided Brake lines
ARB Front & Rear Lockers w/Air Compressor
Dual Optima Batteries (Yellow & Red Top)
Sure Power Battery Isolator
Tuffy Lockable Security Boxes
SG CB Antenna w/ rear Hella Backup Light
Hella H4 Vision Plus Headlights
SG Hi-Lift Jack Mount w/48" Hi-Lift Jack
Borla Exhaust
Cobra CB w/Firestik II antenna
Superwinch Receiver Hitch D-shackle
Soon:
24-Spline 4.10 Gears
Rear Pinion Guard
Bilstein Steering Stabilizer
Custom M J Lee Dual Front Shock Mounts (Fox Heim Joint Compatible)
Comments:
With the BFG MT 33x12.50R15's I'm running, only a minimal amount of rubbing is occuring on the rear fender flares (no rubbing in the front) at full compression. (So the black plastic flares need some trimming.) I've also found since the tire is out so far (greater track width), that the turning radius is actually better than stock. I actually still need to tighten the bolt for the steering stops which will increase my turning radius. Two additional things I might note is that the tire width is a bit wider on the 10" rim verses the 8" rim (again, slightly wider track width.) Even with the additional height of the 33" tires, the roll-over angle has to be as good, if not better than stock due to the extra width gained on the wider rims. Also, another benefit is that the entire hub assembly (including the metal shield) actually fits inside of the rim about an inch (does a nice job of protecting everything from any stray debris on the trail.)
Closed Thread
Eric Martin chrisvonc Defender Owners 0 June 22nd, 2004 09:12 PM
Eric Jernberg chrisvonc Defender Owners 0 June 22nd, 2004 09:04 PM
Eric Jansen chrisvonc Defender Owners 0 June 22nd, 2004 09:00 PM
Eric Evans chrisvonc Defender Owners 0 June 22nd, 2004 08:55 PM
Looking for Eric with the blue D90 SW! TwisteD90 Misc. Chit-Chat 1 April 22nd, 2004 02:18 PM
