Dennis and Maura White - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Closed Thread
Old June 20th, 2004, 11:38 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Model: 1995 Defender 90 #2602, 1993 Defender 110 #402/500, 1967 Series IIa 88
D-90 Mods:
Warn 10,000 lb winch with remote solenoid, 2 controller plugs, 1 in headlight panel 1 in driver's footwell
ARB bull bar with 2 Dixon bates tow hooks and 2 Hella 3000's and bottle opener
Dual Optima batteries with marine all position switch
Garmin GPSIII with external antena
Uniden 40 ch CB
ARB air lockers front and rear
25' Recoilable air hose set-up under fender, accessable through portal in headlight panel
6 12V receptacles; 1 in headlight panel, 1 in each rear speaker enclosure, 3 in dash
110v power inverter
Ashcroft underdrive unit
Ashcroft 4.10 r&p gears
Ashcrost hardened halfshafts Spicer u-joint drive shaft rear, Custom CV front driveshaft (Cityside Garage)
Rovers North SS half roof rack powdercoated black with Jerry can compartments
1 Hella rear mounted work light
Bonnett mounted tire carrier
Custom designed coil springs, dual rate 3" lift all around
Custom Rock sliders
Custon rear bumper with quad recovery points
Southdown steering protector, front and rear diff guards, gas tank guard
South down raised air intake
Custom axle limiters
Custon front panhard rod and offset bushings
Custom front shock towers
Custom rear training arms, shock mounts, , drop kit
Rancho RS9000 shocks all around
VDO programmable speedo
Powdercoated aluminum wing top protectors
SS limb risers
Heated windscreen
American Racing AR23 alloy wheels powdercoated black
305/85/16 Buckshot mudders
Rubicon Hand throttle
Custom front qtr protection bars
Custom 3/8" thick solid rubber floor mats with inlaid alum diamond plate
4 Trakkers inward facing jump seats that exactly match front seats
Trakkers waterproof seat covers on all seats
Onboard nitrogen tank
4' hi-lift
Full Bestop soft top, bimini top, surrey top, full fiberglass hardtop, custom Union Jack surry top (Badger)
Badger 1/2 cab, tonneau & drop curtain (Most Excellent)
Custom tire carrier over tonneau
Hella H4 headlamps
On board Sony Vaio PC with GPS interface and MapTech USGS topo map software
1-1/2" custom stainless steel seat risers
All visible exterior and interior fasteners have been changed to A2 stainless steel with ss and nylon washers
110 Mods & Equip
JE Engineering High Performance 4.6
OME shocks & springs, 2+" lift
BFG MT 255/85
Detroit Lockers rear, TruTrac front
Warn 9000# winch in multi mount
Factory Roof rack with galvanized expanded steel floor, ladder and brush bar
4 Hella 2000's on roof
4 Hella 2 on rear 2 on brush bar
SIIa Mods & Equip
Turner High Performance 2.25 ltr engine" lift
BFG MT 235/85
Wber 2 bbl carb
Ashcroft high range transfer case
Closed Thread
