Bryan Tate - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Old March 4th, 2004, 10:20 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Bryan Tate
Model: Custom Defender 110 300Tdi
Modifications:
I built the entire thing myself. I started valentine day last year, I had it on the road in 3 months. I started with a stripped (new) galvanized V-8 frame. The body parts were Blue body (2000 body), green rear doors (96 ), white front doors (2000), and mint green td5 front end (year??). (it was about 4 different colors at the start). Most of the parts came from George at Roversdownsouth and then had her painted AA yellow.
Salisbury 24 spline heavy duty axles
All wheel disc brakes
Every part underneath was painted with either POR-15 then rustoleum or just rustuleom
The inside is herculiner (like rhino liner) lined under the stock carpet
300tdi engine (had to reweld the engine mounts)
R-380 5 speed with a higher gear ratio for better top end speed
New 110 wiring harness
New A/C (NAS spec)
Heavy duty springs but is pretty much stock underneath (no sway bars)
New brake lines
Stock defender tires
Wolf rims and Goodyear g-90's to play around
All new dash
Mapping GPS
Satellite radio with twin 10" subs
Diamond plate inside rear door
Safety devices full external roll cage (thatchedroofgarage.com)
Warn 9000xdi
(2) hella 3000's on bumper
(4) hella 4000's up top
Dual optima yellow tops
Sunroof installed
DAP galvanived rock sliders painted black
High lift mounted on the front bumper
Hella matodor wired in for reverse and switch on the lamp
No rear bumper
Safari Guard reciever
Black wing top protectors
Raised air intake
Thomas Bryan chrisvonc Defender Owners 0 July 10th, 2004 09:57 AM
