Brian Bonner - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Old March 4th, 2004, 09:55 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Brian Bonner
Model: 1994 Defender 90 #645
Website: http://www.circle-b.com
Modifications:
Winch Bumper from Rock Ware:
Rock Ware's Rear Drop kit for rancho 9012 shocks: Changed to Safari Gard droop kit
Rock Sliders from Rock Ware:
Frame Sliders From Rock Ware:
Rear pinion Guard from Rock Ware:
Offset strengthened Tie rod
Rock Ware Swivel pin housing protectors
Super Winch S9000-
I removed the solenoids and put them in my drivers side seat box:
Old Man Emu Suspension: Heavy duty front(751) and rear HD(759)
Changed to OME 764's front(3" lift) and Rovertym 285 progressive 3"
lift springs Rear
Rancho 9000 shocks
9012's in rear, and 9014's in front with drop out cones
Took out cones and retained springs
Hinged/pinable front Radius arm
Detroit Locker in Rear: Changed to ARB
ARB Locker in front
4.10 Great Basin Rover gears
Custom Aluminum lock box Rhino coated Red in the rear cargo area
Mount(Home made) for Pull-Pal anchoring device on rear tail gate
Black Panther Heavy Duty Deep cycle battery(1000CCA)
Changed to dual blue top optimas with wrangler power products
isolation selenoid
Tuffy Center console
Cobra SSB CB in center console
with a 102" steel whip in the rear
Jacobs Omni-Magnum electronic ignition: which died in a year!
Dual Electric cooling fans with adjustable thermostat: didn't move enough air!
With 2 swicthes for over ride on and over ride off, for deep water crossings
VDO Water Temperature, Oil Pressure, and Voltmeter Gauges
IPF Head light inserts
with 90/145 watt IPF bulbs and a upgraded wiring harness
Purchased at: Bill Burke's Four wheeling America
IPF hybrid Dual Fog/driving light combo in front grill
Mounted a power distribution block in engine bay
for all electrical upgrades preseent and future Available at any Auto Radio shop
Limb Raisers: Home made for a cost of 12.00
Flexible Radio Antenna: Radio Shack
Land Rover Wing Protectors, powder coated black
Mantec Shovel and pick ax Mounts on front wings
33x10.50x16 Super Swamper Radials: Super Swamper Radial/TSL
Changed to 33x12.50x15 BFG MT's
Safari Guard 8x15 Steel wheels
SG Switch console
SG CV joint Drive shafts
SG Stage 2/3 trailing links
SG Stainless break lines
SG castor corrected radius arms
SG Front and Rear Diff Guards: Safari Gard
Fiber Reinforced Plastic Hard Top
Sold, not my style
LR Bikini top
Badger Surrey Top
LRNA Safari Roof Rack
M416 military trailer
Roof Top tent mounted on trailer
Trade: Front fender flare! TwisteD90 Wanted 12 September 25th, 2005 11:47 PM
Brian OShea chrisvonc Defender Owners 0 February 5th, 2004 11:55 PM
