Barnett Childress - Defender Source
Go Back   Defender Source > Owners Gallerys > Defender Owners
Old February 29th, 2004, 12:47 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Barnett Childress
Model: 1995 Defender 90
Modifications:
Protection:
Safari Gard; front bumper/skid plate; w/3 light tabs, swivel D-ring, & two 3.5 tonne Dixon Bates tow jaws.
Safari Gard front/rear diff gards.
Safari Gard rear fuel tank skid plate.
White Wolf rock sliders; w/air option.
Rover Accessories rear bumperettes.
Limb Riser Cables.
LR aluminum wing top protectors
Drivetrain:
Ashcroft 4:10 R&P's.
ARB Air Lockers front and rear; compressor mounted under passenger seat
Ashcroft Underdrive
VDO programmable speedo
SG front & rear double jointed driveshafts
Suspension:
SG stage III w/dual rate 300# front and 350# rear springs
SG 3-link
Fox 12" remote reservoir heim jointed shocks all 4 corners
Fronts relocated outside of springs
SG rear inner spring droop/capture kit
SG rear HD trailing arms
Earl's extended stainless steel brake lines, front & rear
Tires & Wheels:
Interco Super Swamper TSL radial 36x12.5R16's with Equal balancing powder
LR D110 steel rims
Accessories:
British Pacific 9 Gal. Aux fuel tank; w/custom skid plate. Transfer fuel switch wired to fuel pump lamp in dash.
Borla stainless steel exhaust
Hella two 220 driving lights mounted to front bumper
Hella four 4000 100W driving lamps mounted over windscreen
Corner/Euro/Euro/Corner beam configuration
Hella 100 Watt dual bulb rear work light
LR heated windscreen
LR center dash panel w/LR illuminated switches for Heated windscreen, fog, & off road lights
Optima two yellow top batteries w/custom aluminum battery tray
Battery select, & master on/off switches
Tuffy 12" center console
Tuffy Maximum storage locker mounted behind front seats
Two LR inward facing rear benches
LR CD changer; mounted in Tuffy console
LR rear powered subwoofer
Mantec Snorkel, shovel wing mount, & extended breather kits
Uniden Grant full size CD
102" SS whip British NATO military pintle hitch
LR D110 rear folding step
Rovers North custom stainless steel roof rack powder coated, w/limb riser tabs, rear work light mount, rear antenna mount, rear lockable Pul Pal mount, rear lockable Max Axe mount
Custom lockable Hi-Lift jack front brush bar mount.
LR military bonnet latches
K&N air filter
Full, surrey, and bimini soft tops
Quicknut door top fasteners
Custom padded storage/travel bag for door tops
Lowrance LMS160 global map/GPS
SG rear tire carrier
Custom dog guard behind front seats holds kinetic rope, fire ext., first aid kit, bow saw securely
Recovery/repair/emergency gear:
Superwinch Husky 10 10,000lb winch; Solenoids mounted under driver seat. Assorted snatch blocks, chains, straps, shackles
60" Hi-Lift jack
Pul Pal ground anchor
Max Axe tool
Shovel, bow saw, chain saw
Kinetic recovery rope
Fire extinguishers
Emergency first aid kits
Extensive tool kit, electrical kit, parts kit, fluids, service manual, tarp, Maglight flashlights
Rain gear, rubber boots, food, water, & cell phone (just in case!)
