Spacer in between bearings - Defender Source
Go Back   Defender Source > Community Announcements & Support > Support & Suggestions
Old July 16th, 2014, 06:46 AM
Divesnowboy's Avatar
Divesnowboy
shaun
2007/110/TD4
Hello all, bought my 52mm CV socket to tight and torque the wheel hub nut. Though there is a spacer that came with the new bearings that I installed, is this correct, does the assembly require a spacer in between the bearings?
There are also two spacers on the hub shaft end with the circlip, now only one goes back on, hence the question on the bearing spacer.
Thanks in advance.
DSB
Old July 16th, 2014, 10:04 AM
Divesnowboy
shaun
2007/110/TD4
scratch the last, I was talking out of my arse. Of course you need a spacer!
Now I've popped out the abs plug mount, I think I'm in trouble, some weird bearing inside that's off to one side. :-(
ac
Wheel Bearings and stub bearings Naplm00 Defender Technical Discussions 9 March 11th, 2011 10:17 PM
TIMKEN Carrier Bearings Part Number mhansen Defender Technical Discussions 1 August 17th, 2006 12:48 PM
Stubbed... stub axle bearings and seal thewap Defender Technical Discussions 2 June 29th, 2006 08:07 AM
DBA disks, EBC's & bearings thewap Defender Technical Discussions 6 June 7th, 2006 01:44 PM
Pre load of diff bearings. andersoriginal Defender Technical Discussions 9 October 10th, 2003 04:08 PM
