Restrictor plate removal - Defender Source
Go Back   Defender Source > Community Announcements & Support > Support & Suggestions
Old October 21st, 2013, 11:50 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
Hello, I have a 1983 land rover 110 county SW with a 4 speed 3.5l v8 engine. I expected the landy to be slow when I bought it but I would prefer a bit more power. I heard that these v8s had destructor plates limiting it to 113 bhp from 134bhp. If so, how would I be able to tell and how would I be able to remove it. Thanks
Old October 22nd, 2013, 12:01 AM
I believe uncle Douglas fitted an edelbrock carb and manifold to Trey's truck. Sorry I can't help on the restrictors.
Old October 22nd, 2013, 10:19 AM
Landyman1's Avatar
Landyman1
Landyman
did it help with the acceleration?
Old October 22nd, 2013, 10:29 AM
I found no restrictor plates under Treys carbs. Yes the edlebrock manifold and carb made a huge difference for his truck. The engine was designed by GM to run with a 4bbl. The primary issue with these engines is that they are low compression.
Old October 22nd, 2013, 11:10 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Look between the carb body and the inlet manifold, you should see the carb body-gasket- black plastic isolator - gasket and inlet manifold. if there is a extra gasket and a metal plate showing the restrictor plate is still there fitted.
But I somehow doubt it will be, as that's the first thing many people pull out. I did.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 22nd, 2013, 11:58 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I to have the edelbrock intake and a holley 4 barrel carb. Can't comment on before and after as mine came with the holley.
Unknown Author
716-898-8153
Old October 23rd, 2013, 12:00 AM
Landyman1's Avatar
Landyman1
Landyman
I'm pretty sure I have stromberg carbs. Do you think switching to SUs will help?
Old October 23rd, 2013, 12:23 AM
Landyman1's Avatar
Landyman1
Landyman
Also, how hard would it be to replace the intake manifold and carbs with edelbrock kit. If I were to do so, which specific parts will I need?
Old October 23rd, 2013, 06:52 PM
Landyman1's Avatar
Landyman1
Landyman
From the Edelbrock site: Buick/Rover 215 V8 PERFORMER ROVER (idle-5500 rpm) Designed for Rover 3500cc V8s (1968 & later) and 1961-63 Buick and Oldsmobile aluminum 215 V8s. Manifold not equipped with EGR. Will not work with OEM carburetors (except Carter AVS). Applications Part # Performer Rover (non-EGR) #2198* Carburetor Recommendations: Edelbrock Performer Series carb, 500 cfm (see Carbs & Accessories) Installation Notes: Recommended intake gasket: Fel-Pro #MS96002. Manifold height: A-5.00", B-5.92" (measured to engine block); Carb pad height: 5.46" see A/B Measurements. Port exit dimensions: .88" x 1.54". Throttle Bracket #8036 will fit and accepts GM style throttle, kickdown and cruise control cables. http://www.edelbrock.com/automotive_...ormer-v8.shtml Do some google searches as there are some various tuning tips, and also talk of running a 390 Holley instead of a 500. There are also various mods to the 500 to make it optimal. -Jeff
how does this setup stand up to off-roading. I read somewhere that because these engines have such a low compression, these carburetors can't stand up to to the reliability of a stromberg. I've considered SUs but I've heard that they are very sensitive.
Old October 23rd, 2013, 07:21 PM
Edelbrock is a Weber/Carter and the modification is the installation of springs on the needle valve to prevent high angle fuel starvation.
The Holley is, well, a Holley.
Old October 23rd, 2013, 08:06 PM
I think you already answered your own question, you are looking to replace your zenith/strombergs. Have you worked on them ? I have and I hate them. I noticed a signifigant bump in both power and economy when we switched his truck to the edlebrock setup.
Old October 23rd, 2013, 08:17 PM
Landyman1's Avatar
Landyman1
Landyman
do you off-road a lot? Have you encountered any problems?
Old October 23rd, 2013, 11:11 PM
bish1865
Bruce Bishop
1985 Defender 110
I took out the restrictors on my Stage1 and it woke the engine up. They are located under the carbs and held in place by a snap ring. They look like they have three pencil size holes in them. They're not hard to remove I did it in about 20 minutes.
Old October 23rd, 2013, 11:26 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
I have a 3.5 with the Edlebrock setup. I have off roaded a fair bit. The carb works well.
I think the restrictor plates were only a Stage One thing.
Firemanshort
1980 Stage One 109
Sterling, VA
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Upper door removal and instal thelandroverguy Defender Technical Discussions 3 July 22nd, 2004 08:50 AM
