Prom 9631 Defender 90 - Defender Source
Go Back   Defender Source > Community Announcements & Support > Support & Suggestions
Old September 29th, 2014, 03:25 PM
blakes
Blake
1995 Defender 90
I need a new part, prom 9631 for a 1995 Defender. Does anyone know where I can find one?
Old September 29th, 2014, 03:31 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
http://www.discoweb.org/forums/showthread.php?t=4574
Old September 29th, 2014, 04:06 PM
blakes
Blake
1995 Defender 90
Prm 9630
I've tried Rovers North and landoverparts.com and dealerships with no luck, anyone have another parts source?
Old September 29th, 2014, 06:32 PM
There is zero chance that the PROM is causing your problem in Texas in September. Your thermostat is likely stuck open. Could also be a fault with the temp sensor, but highly unlikely.
Old September 29th, 2014, 06:39 PM
the rover shop
shayne young
And don't put an autozone sensor in there...where is your temp guage reading..if your thermostat has been removed or isnt closing off fully then you will get that code as the temp sensor sees that the engine never gets up to correct operating temperature and hence never comes of "choke"..this would be affirmed by the temp guage needle staying lower than centre position on the guage... If you have changed the temp sensor make sure you changed the right one..it is in the front left section of the intake manifold..
90, defender, defender 90
Defender Prom Chips sparks Defender Technical Discussions 3 January 18th, 2014 05:52 PM
Prom Chips sparks Wanted 1 January 17th, 2014 06:47 PM
PROM version MAX711 Defender Technical Discussions 4 April 13th, 2013 03:14 PM
Computer Chip aka PROM from a 94-95 disco or RRC evilfij Wanted 3 August 3rd, 2009 11:57 AM
