posting? - Defender Source
Go Back   Defender Source > Community Announcements & Support > Support & Suggestions
Old September 30th, 2003, 12:16 AM
posting?
how can you tell if there are new posts??
Old September 30th, 2003, 06:29 AM
Primaryd90's Avatar
Primaryd90
At the left of each topic, there are grey folders. When a new post has been added that you have not seen yet, it will turn yellow with a red star. You can see the differant icons at the bottom of the forums main page and each page will have a guide at the bottom of what any folder or icon on that page means.
CVC
Old September 30th, 2003, 09:00 AM
all the folders always are yellow with a red star
Old September 30th, 2003, 09:12 AM
They look grey unless there is a new message for me.
Old September 30th, 2003, 09:14 AM
hit Home at the top of the page then scroll down to the bottom there is a picture of each folder type with a description.
Old September 30th, 2003, 09:26 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
You may have to wait 15 minutes for the information to be refreshed in your cookie. I think the board is set to refresh one's account cookie information every 15 minutes. I will look into seeing if thats adjustable either at lunch time or when I get home tonight.
It does the same for me and I notice it change around that timing.
CVC
Chris von C
[/size]
Old September 30th, 2003, 09:37 AM
you can also click on Mark All Forums Read at the bottom of the page.
Old September 30th, 2003, 12:20 PM
thanks for your help, my folders are still yellow with a star. t
Old September 30th, 2003, 12:57 PM
Primaryd90's Avatar
Primaryd90
Try going into your User control panel (User CP button at the top of the forum) and go into "Edit options". Make sure that both: "Automatically login when you return to the site? (uses cookies)" and "Browse board with cookies?" are set to "Yes".
This will also keep you logged in the next time you visit. The issue of everything always being marked as unread is usally when you are not logged in or unregistered and if your security settings are set to high in your browser.
Let me know if that does it. If not, I will look into it more tonight when I get home.
CVC
Old September 30th, 2003, 02:12 PM
thanks I always am logged in. I adjusted my security options hopefully that will help with the cookie problem.. I never had trouble like this with the old site in terms of seeing where new posts had been and new threads etc. thanks for your help, you are most generous in keeping this place going thanks a lot.
Old September 30th, 2003, 02:21 PM
still yellow with stars
Old September 30th, 2003, 02:42 PM
okay so if I long out and log back in the folders turn grey. so when there is a new post and I read the thread shouldnt the folder turn back to grey??? Am I the only person with this problem?
Old September 30th, 2003, 02:52 PM
It does the same for me Phillip. But if I leave the site and come back in 30 min the folders I read turn grey.
Old September 30th, 2003, 02:55 PM
okay I see. thanks for the info. I guess it will be something that the forum god will have to adjust on the program? how come the old BB would immediately show what new posts there were and that I had read them?
Old September 30th, 2003, 03:01 PM
The old bord did not do that for me. The new icon would stay there but the link would change color indicationg that I had been there. Then if someone posted something the link would change back indicating someone posted and the link had changed.
Old September 30th, 2003, 06:54 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Hi Phillip,
If you click the link at the top of the thread or forum that says "mark thread as read", are the folders still showing up as unread after it refreshes?
Thanks.
Chris von C
[/size]
Old September 30th, 2003, 07:23 PM
yeah it will make the star go away. I just log in and log out once I go thru the most recent posts then log back in and that makes those damn stars go away. I will just continue to do that. Chris thanks a bunch for your help and your continuious work here on the www.d-90.com.
Old September 30th, 2003, 07:30 PM
Primaryd90's Avatar
Primaryd90
Ok.. good so you have a bit of a work around at least. I will still look into it and see if there is something I have overlooked.
CVC
Old September 30th, 2003, 09:12 PM
thank you
Old September 30th, 2003, 09:20 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Ok... as a follow up I found some more info.
The read/unread status, who is online display, as well as other features that are user account specific are controlled by your cookies and the cookie timeout settings of the boards software.
The default timing is set for 15 minutes meaning that the information will not refresh unless there is 15 minutes of inactivity on your account. The only way to get it to refresh everything right away would be to log out and then back in again.
If you just want to clear the Unread mark from post you have already been in, you can use the "Mark all threads read" option on the forums main page or if you are in a sub forum use the "Mark this forum read".
- CVC
Chris von C
[/size]
Read first before posting! chrisvonc For Sale - Parts 1 March 8th, 2009 10:50 PM
**Read first before posting!!** chrisvonc For Sale - Vehicles 2 February 21st, 2009 04:26 PM
Posting pictures! TwisteD90 Support & Suggestions 0 October 5th, 2003 11:16 AM
