Indicator fault - Defender Source
Go Back   Defender Source > Community Announcements & Support > Support & Suggestions
Old October 21st, 2013, 05:13 PM
Peachy
Jason
1984 defender
Smile Indicator fault
Hi can anyone help me? I hAve a 84 110 defender with an intermittent indicator fault,some days it works others it doesn't! I have replace the relay and steering column switch with new components and it still plays up! Should I check anything else. Cheers.
Old October 21st, 2013, 06:00 PM
Check the connectors to the bulbs for corrosion and other reasons bulbs don't get juice
Old October 21st, 2013, 06:12 PM
pull the hazzard switch ... if it's slightly depressed the indicators don't work ... assuming you have a square hazzard switch like a NAS truck.
Old October 21st, 2013, 07:57 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
I tackled this problem in my landy. You have a problem with the hazard switch. This problems is pretty infamous with defenders. The hazard switch routes the power to the indicators as well. First check if any bulbs are burned out. If all is working, then that just means you have a faulty hazard switch. You can just buy one on eBay. Good luck!
Also check out this website, it helped me (one)tons. :D haha get it, one tons (110).....sorry
http://forums.lr4x4.com/index.php?showtopic=25376
ID:	82585 Click image for larger version
Old October 22nd, 2013, 02:20 PM
Peachy
Jason
1984 defender
Thanks for replies I will try it 2 moro.
