Front Wheel Bearing replacement - Defender Source
Go Back   Defender Source > Community Announcements & Support > Support & Suggestions
Old July 4th, 2014, 09:22 AM
Divesnowboy's Avatar
Divesnowboy
shaun
2007/110/TD4
Hey all, currently replacing my landy's front wheel bearings. I've removed the four bolts from the brake caliper assembly. However the brake fluid pipes remain. Must I also unplug the feed pipe at the top, that is, in between the two top caliper bolts, so that the whole brake assembly comes off? I didn't want to get into losing fluid but I guess I may have to...
Any advice on getting the caliper assembly off is welcome, thanks in advance.
DSB
2007 Defender 110.
Old July 4th, 2014, 09:32 AM
use pipe wrench to squeeze on brake pads and close the caliper pistons. then you can lift caliper off and hang it with a coat hanger without cracking your pipes.
Mark Kellgren
KM4BOR
Old July 4th, 2014, 09:44 AM
87 D110 (Ruby)
yep - just hang the caliper - no need to remove pipes
Old July 4th, 2014, 09:49 AM
Divesnowboy
shaun
2007/110/TD4
The pipe in between the top horizontally place bolts, that comes away with the whole assembly right?
That top plate with the two said bolts doesn't want to slide either....
Old July 4th, 2014, 09:53 AM
just noticed its a 2007. may be different. have abs? I'll defer to others.
Mark Kellgren
KM4BOR
Old July 4th, 2014, 10:00 AM
Divesnowboy
shaun
2007/110/TD4
Yeah, ABS is in...Click image for larger version
Old July 4th, 2014, 10:05 AM
Disconnect the ABS sensor wire and pull the caliper with the bracket from the top of the swivel housing and hang to the side.
Old July 4th, 2014, 10:13 AM
The thing between the bolts is not a pipe (I don't think), but the wire for the ABS sensor. The upper plate looks like it has another bolt on the side to release it.
Old July 4th, 2014, 10:49 AM
Divesnowboy
shaun
2007/110/TD4
Ta
Cheers Red, nice work. Thanks to all naturally.
Should get this done tomorrow, beer O'clock!
Old July 5th, 2014, 08:55 AM
Divesnowboy
shaun
2007/110/TD4
abs sensor
so it was an ABS sensor. Disassembled the housing, sensor's the long silver tube thingy there at the back.
The inner bearing, should it sit flush on the bearing face of the housing, pressed in tight with the seal, or should there be play in between the seal and bearing?!
Name:	brake pipe1.jpg
ac, wheel
Bearing replacement/Hub Seal Darby Defender Technical Discussions 2 January 17th, 2013 05:37 AM
stuck wheel bearing sflash868 Defender Technical Discussions 12 September 2nd, 2009 10:05 AM
wheel bearing D90user Defender Technical Discussions 15 April 17th, 2006 09:35 PM
Rear wheel bearing damage potential?? Neo Defender Technical Discussions 8 November 28th, 2004 11:58 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
