Wipac NAS LED light set - Page 4 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old February 24th, 2012, 02:13 PM
MattGuyver_007's Avatar
MattGuyver_007
Matt VA
1995 D90 SW
Yes, of course weatherproof heat shrink but I stand by my 4" length. (Figured that was obvious and why I attached the link.) I still recommend solder over crimping though.
I went a step further and filled the space between the body and the back of the LED lights with great stuff pond sealant which keeps the mud and rocks flying up from the rear tires from collecting between the light and the body. As Josh said, anything in that area takes a beating. The great stuff is easy to clear away if you ever have to remove the light(s) but this is doubtful if done right the first time.
Old February 24th, 2012, 02:44 PM
So probbaly slide one of these (or another trusted source) 3/16" sleeves (if that's the right size) on per wire cut down to desired length
http://www.go2marine.com/product/206...e&WT.mc_id=gb1
then make your connection between each stock wire and each LED wire with one of these heat-shrink butt connectors
http://www.boatmania.com/electrical/...onnectors.html
then move the sleeve back over your butt connection, and heat-shrink that bad boy over it. Or solder and repeat last step.
Old February 24th, 2012, 03:57 PM
Fivespddisco's Avatar
Fivespddisco
Justin Monnin
96 D1
Guys
Those light are coming off when the truck goes in for paint. Dont punish me for putting them in to take pictures and use the romp.
For expedition tested Rover gear Check out
716-898-8153
Old February 24th, 2012, 04:23 PM
Fivespddisco
Justin Monnin
96 D1
I received the flashers today. Ill test them out this weekend and if they are good Ill send them out.
716-898-8153
Old February 24th, 2012, 04:28 PM
Fivespddisco
Justin Monnin
96 D1
Originally Posted by MattGuyver_007 View Post
with great stuff
I dont know about the Pond version but the great stuff is highly flammable. I know a guy that lost his shop when a it stared on fire in a customers truck. They used it to fill holes in the body work. A spark from a his grinding wheel started the whole thing.
716-898-8153
Old February 24th, 2012, 04:29 PM
Justin, all we really want to see are your butt connectors.
Old February 24th, 2012, 04:35 PM
Fivespddisco
Justin Monnin
96 D1
Originally Posted by rijosho View Post
Justin, all we really want to see are your but.
I know
716-898-8153
Old February 27th, 2012, 12:15 AM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Thanks again for the wiring info. Worked like a charm. Got everything wired up well this past weekend. My turn signals are flashing fast, you'll have to let us know how the new relay works with the LED's.
Old February 27th, 2012, 11:19 AM
Fivespddisco
Justin Monnin
96 D1
Works like a dream!
716-898-8153
Old February 27th, 2012, 12:54 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Cool, how can I get one from you?
Old February 28th, 2012, 09:23 AM
Fivespddisco
Justin Monnin
96 D1
I will send you one.
716-898-8153
Old February 29th, 2012, 04:29 PM
Fivespddisco
Justin Monnin
96 D1
Flashers shipped today. Thank you for the orders.
716-898-8153
Old March 16th, 2012, 05:07 PM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
Found a shot - posting the pic instead of the link.
Is there anything special required to be done to install these in the ROW positions ?
Old March 16th, 2012, 06:04 PM
If your ROWs are 95mm DIA I'd say likely no, as that's what I believe these are.
Old March 19th, 2012, 01:54 PM
ersatzknarf
Frank
'96 hybrid
Hi Josh,
Actually, I was referring to the photo in your post #9 . . .
Old March 19th, 2012, 02:30 PM
Originally Posted by ersatzknarf View Post
Hi Josh,
OK then I'd start by drilling 3 holes - one large one for the wires to go through, then 2 small ones to hold the light and bezel, and runn appropriate wiring to that location if you do not already have a light there. Other than that, not quite sure of your question I guess.
Old March 20th, 2012, 09:23 AM
ersatzknarf
Frank
'96 hybrid
Okay, will try again. Maybe Justin knows. I see by the photo in post #9 that these will go on a ROW car. Aside from needing a plinth, is there anything else that needs to be done to install these in the ROW lamp locations ? Thanks.
Old March 20th, 2012, 09:31 AM
I would say no. It doesn't look like the even cut the capping to put the light there. Looks pretty simple to me. They're lights, so they don't need backing plates or anything like that.
Old March 20th, 2012, 04:19 PM
ersatzknarf
Frank
'96 hybrid
Thanks. Maybe Justin knows...
Old April 13th, 2012, 06:12 PM
Fivespddisco
Justin Monnin
96 D1
No.
Just put them up there.
------ Follow up post added April 13th, 2012 06:13 PM ------
You got it.
That is all they do at the factory.
716-898-8153
ac, ht, nas
need to borrow a set of SW & ST NAS rear Speaker Housing SafariHP Misc. Chit-Chat 6 August 19th, 2011 08:31 PM
Safari Dust LED light kit? tebby Misc. Chit-Chat 10 January 5th, 2011 01:01 AM
NAS D110 Third Brake Light Jon_Winningham Wanted 2 August 13th, 2010 11:31 AM
Reverse led light part # needed FlaD90 Defender Technical Discussions 5 July 16th, 2010 08:35 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
