Wipac NAS LED light set - Page 2 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old January 27th, 2012, 03:55 PM
Fivespddisco's Avatar
Fivespddisco
Justin Monnin
96 D1
Originally Posted by oilburner View Post
Awesome! That way you can use good connectors (weatherpack etc)!
Agreed
For expedition tested Rover gear Check out
716-898-8153
Old January 29th, 2012, 11:53 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
I want to order a set but couldn't find them on your website. Are they up yet or do I need to call?
Old January 30th, 2012, 07:31 PM
Fivespddisco
Justin Monnin
96 D1
I will get them listed today and send over the link.
Thank to you.
716-898-8153
Old January 30th, 2012, 08:30 PM
KKilo23's Avatar
KKilo23
Kenny
Justin how do these compare to the trucklite/robolite LED lights?
Old January 30th, 2012, 09:06 PM
Fivespddisco
Justin Monnin
96 D1
Here is the link
Thank you for the order.
http://lucky8llc.com/Products.aspx?ProductID=7212
------ Follow up post added January 30th, 2012 09:08 PM ------
I do not know about the other lights. Sorry
716-898-8153
Old February 11th, 2012, 09:27 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
So I went to install these lights on my 1997 SW and I was disappointed to find out these are not plug and play. The brake light would light up but would not get brighter with the brakes. The turn signal was flashing really fast. So it looks like these are going to need a load resister. I had to unwire what I had installed and put the old ones back on. I was able to leave the back up light installed as that was the only one that would operate normally.
Here is the instructions that came with the lights, it has the part numbers for the load resisters
http://www.paddockspares.com/media/downloadable/sld.pdf
Old February 12th, 2012, 12:30 AM
How about the front lights?
Old February 12th, 2012, 10:26 PM
Fivespddisco
Justin Monnin
96 D1
I am sorry but they do not come with the plug ends because some trucks use the pin style and other use the clip.
I think you have it wired incorrectly or you have a ground issue. I put them in my 90 please see pics below.
Same here. I will order some resister with the next batch and send them out FOC to everyone that ordered.
------ Follow up post added February 12th, 2012 10:27 PM ------
I have some extra yellows coming and a extra Reds if people want to put the fog option on the back.
716-898-8153
Old February 12th, 2012, 10:29 PM
Fivespddisco
Justin Monnin
96 D1
Here is a pic of the running lights on in the day light.
716-898-8153
Old February 12th, 2012, 10:30 PM
Fivespddisco
Justin Monnin
96 D1
This is the running light and revers inside the shop with no lights on.
716-898-8153
Old February 12th, 2012, 10:32 PM
Fivespddisco
Justin Monnin
96 D1
This is the brake light and revers light inside the shop with no lights on.
716-898-8153
Old February 12th, 2012, 10:33 PM
Fivespddisco
Justin Monnin
96 D1
All 3 lights at the same time.
716-898-8153
Old February 12th, 2012, 10:35 PM
Fivespddisco
Justin Monnin
96 D1
I am sorry about the quality of the pictures. If I took them straight on it would wash out the photo.
716-898-8153
Old February 12th, 2012, 10:46 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Not having the clip end is no big deal. I can wire it up fine. What I mean by not plug and play is that I wasn't able to order the kit and install it right away. I was pretty excited about these because I have wanted LED lights for a while.
I was able to get the brake light to light up. Its just that when I pushed on the brakes they didn't get brighter. I assume that it will needs a resister like the indicator light. When I wired the original lights back up everything worked as it should. I left the LED reverse light hooked up as that worked fine.
Old February 12th, 2012, 10:52 PM
Something is wired wrong.
Old February 12th, 2012, 11:00 PM
Fivespddisco
Justin Monnin
96 D1
I think you have the wires backward. The brake light wired in revers. Ill take a pic the wire need and post it up for the recored.
Sorry you are having an issue.
716-898-8153
Old February 14th, 2012, 12:29 AM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Me having issues isn't just isolated to wiring brake lights!! Thanks for the help, a pic of the wiring would help a lot. I observed a green wire, black/red wire, and a black wire.
Old February 14th, 2012, 10:45 AM
MattGuyver_007's Avatar
MattGuyver_007
Matt VA
1995 D90 SW
I wouldn't recommend installing resistors because it's another connection prone to water penetration and/or failure. Furthermore, part of the allure of LED technology is the low current draw so when a resistor is installed you are no longer taking advantage of the low current draw- you're simply turning the energy into heat.
SOLUTION: I just installed LED's (both front and rear) and then ordered the LED bulb Flasher unit from superbrightleds.com for $12.95 which solves the problem correctly. (They ship wicked fast too.)
FYI- the flasher unit is part #CF13GL-02 and I highly recommend ordering a couple of interior LED's while you're at it- they make a huge difference and worth every penny of the $14.95
Old February 14th, 2012, 10:54 AM
You can get electronic flasher relays at any auto parts store.
Old February 14th, 2012, 11:00 AM
MattGuyver_007
Matt VA
1995 D90 SW
If you find one that actually works with these LED's please post the part number. I tried 4 different ones from NAPA, AutoZone, etc... thinking the same thing and each had their own problems but suit yourself.
ac, ht, nas
need to borrow a set of SW & ST NAS rear Speaker Housing SafariHP Misc. Chit-Chat 6 August 19th, 2011 08:31 PM
Safari Dust LED light kit? tebby Misc. Chit-Chat 10 January 5th, 2011 01:01 AM
NAS D110 Third Brake Light Jon_Winningham Wanted 2 August 13th, 2010 11:31 AM
Reverse led light part # needed FlaD90 Defender Technical Discussions 5 July 16th, 2010 08:35 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
