Ukmotors ltd madness - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old June 2nd, 2011, 02:53 PM
ukmotorsltd's Avatar
ukmotorsltd
Andrew Ward
98 disco
We would like to show our appreciation for being a Vendor of the D-90 Source by creating a Vendor Monthly Madness starting right now.
JUNE 2011 MADNESS
CROSS-MEMBER REPLACEMENT
$ 850.00
NOTE: we will replace your Cross-member and this price does not include the cross-member or additional work / parts related to tank guard, however it does allow you to choose your type of cross-member that can be sourced through us or your favorite Land Rover parts supplier. Any additional labor will be at the rate of $ 70.00 per hour.
COMPLETE D-90 TUNE UP ( 1994 1995 )
$ 589.00
NOTE: we will replace your Plugs, Plugs Wires set your timing properly and base idle, change oil and oil filter as well as air filter. Any additional part needed such as Distributor Cap, Rotor or Coil will be quoted accordingly, HOWEVER no additional labor will be added
COMPLETE D-90 TUNE UP ( 1997 )
$ 589.00
NOTE: we will replace your Plugs, Plugs Wires, set base idle, change oil and oil filter as well as air filter. Any additional part needed such as Coil Packs will be quoted accordingly, and additional labor will be added
TUNE UP parts are OEM, if you desire aftermarket parts such as Magnacor or special oil requirement will incur additional charges
Call us to schedule an appointment or to simply say hello
( 717 ) 244-7250
Old June 2nd, 2011, 02:58 PM
Doesn't it say on your site that labor is $65 an hour?
http://www.ukmotorsonline.com/about.htm
"Our Labor Rate is $65.00 per hour, roughly half that of the typical Dealership rates."
Old June 2nd, 2011, 03:24 PM
ukmotorsltd
Andrew Ward
98 disco
Thank you for bringing this up, our WebMaster forgot to update the rate.
Will be corrected tonight
Thank you for your input
Old June 24th, 2011, 01:40 PM
ukmotorsltd
Andrew Ward
98 disco
Well,
First and most important, THANK YOU for the overwelming response.
Since June is about to end and due to major requests, we are extending the Madness throught July 2011.
Also, we would like to remind all of you who depart on Vacation, we will gladly pick your vehicle, perform the service while you are away, and have it ready for your return.
Call us to schedule your repairs
Thank you
Andrew
Old July 7th, 2011, 04:22 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Felton huh? That must be just down the road (judging by street # you might be next door eh?) from my old buddy Jeff at Octagon auto. Prime source for all that is odd in the world of exotic automobillia...........and cats.
Matt Browne
motor
405 Madness Grover Misc. Chit-Chat 4 December 16th, 2010 08:35 PM
Sailors tripm Misc. Chit-Chat 11 December 1st, 2008 05:57 PM
