Td5 Rubber Floor / Tunnel Cover & kick panel mat FS - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old June 24th, 2008, 03:59 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
New in the wrapper for LHD. Covers the tunnel and floor plus the kick panel in front of the floor mats. Images coming.
$275.00 for the front kick panel piece and 150.00 for the floor / tunnel cover mat.
Will fit NAS trucks with an R380
Located in Orlando FL
Old June 24th, 2008, 05:22 PM
you have my attention. how does the fit compare to an R380 designed version for an R380?
Old June 24th, 2008, 06:32 PM
Pat's Avatar
Pat
Patrick M.
D90 '96 300Tdi 5 speed
Interested in the Td5 Rubber Floor / Tunnel Cover
e-mail sent
Old June 25th, 2008, 07:42 AM
SafariHP's Avatar
SafariHP
1983 Defender 110
Updated post
Here are the pictures. Some installed on the floor over NAS floor and seat base parts. The floor mat / tunnel cover is insulated over the floor boards. The foam for the kick panel area is at least an inch thick in some areas. Held in place by the metal strips that hold in the standard cardboard kick panel trims.
ID:	14028   Click image for larger version
ID:	14030   Click image for larger version
Old June 25th, 2008, 09:00 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
should be the same....td5's use the same R380 and floor as the tdi.
Old June 25th, 2008, 09:09 AM
Pat's Avatar
Pat
Patrick M.
I'll take the Rubber Floor / Tunnel Cover
Old June 25th, 2008, 10:31 AM
Pat's decisiveness wins the day. Stephen, if you had said R380 tunnel cover, I would have been first in line. I was about to buy one anyway from RN. Knowledge is power.
Old June 25th, 2008, 12:27 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
MArk and Patrick
These sold before I caould get back to my computer. Have three more on the way. Drop me a PM if intersted will put your name on them. Did you guys want just the tunnel / floor covers or the whole set?
Old June 25th, 2008, 01:09 PM
just tunnel for me, but interest depends on timing. My uncovered tunnel is covered in shiny Damplifier sound killer right now and I'm tired of looking at it. When do you expect them in, and what's the shipping estimate to 28277?
Old June 25th, 2008, 01:17 PM
Pat's Avatar
Pat
Patrick M.
Just the the tunnel / floor covers
Old June 25th, 2008, 03:51 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
5 on the way. Will PM details. Later
Old June 25th, 2008, 07:05 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have one of these sets.. They are great. They also help with noise reduction. THey work perfectly in an NAS truck..
DO you have the seat box cover that matches the set?
Legend in My Own Mind.
Old June 25th, 2008, 09:21 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Seat box covers are coming also. Should be here early next week.
Old June 25th, 2008, 11:36 PM
surf110's Avatar
surf110
Ze
130 Project
I'll take one tunnel/floor cover. Do they make matching ones for the middle floor on a110?
Old June 26th, 2008, 03:14 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
surf110
Have one with your name reserved.
Old June 26th, 2008, 04:19 PM
how about that 28277 shipping estimate?
Old June 26th, 2008, 05:17 PM
bjf's Avatar
bjf
barry f
94 ST #395
This looks great. How does the passenger side work wiht regards to hood opener? I know on my 94 it is on the right but some 95s it is on the left. then there are trucks with AC. . .
Old June 26th, 2008, 11:10 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Stephen - I would like to see pics and a price on the seat box covers too. Thanks for the info on the floormats - all that stuff is looking ratty on my '95 and you offering looks durable and neat.
Old June 27th, 2008, 01:14 AM
Barry - you just gotta drill holes in the right places and dismount the AC to install the mat. You can of course cut out a place for the AC, but that kind of defeats the purpose by removing a large section of the insulation.
Old June 27th, 2008, 02:54 PM
How is that done? I didn't install my A/C and don't know how to dismount it. can it be done without disconnecting refridgerant lines?
cover, fs, rubber, td5
NAS Style Used Rubber Kick Panel Set SafariHP The Vendors Loft 8 March 16th, 2010 09:17 PM
Used Rubber Kick Panel Mat for R380s SafariHP The Vendors Loft 12 January 6th, 2009 08:32 PM
TD5 Sytle Seatbox Cover FS SafariHP The Vendors Loft 3 September 5th, 2008 10:18 PM
Trunnel cover rubber floor mat k4rovers Wanted 0 November 13th, 2005 07:28 PM
94 ST Fuse Panel Cover mfreeman17 Wanted 0 June 28th, 2004 01:30 AM
