Td5 Rubber Floor / Tunnel Cover & kick panel mat FS - Page 2 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old June 27th, 2008, 03:55 PM
Originally Posted by Overlander
can it be done without disconnecting refridgerant lines?
If someone knows a way, then I'm all ears.
Its easy to take out, just pull the vents to access the screws, pop the fascia off, and then remove the condensor blower assembly. Doing this withouth disconnecting the lines? No so sure.
Old June 27th, 2008, 08:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
I dont have the AC. Was wondering more about the hood pull. Any pics of one installed on a NAS vehicle?
Old June 30th, 2008, 01:41 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
Barry
The bonnet release cable is the only difference. Would suggest the Td5 cable anyway. Just have to poke a hole in the proper place for the T handle. I suggest the TD5 one anyway. Moves the release into the passenger left foot well with a lever instead of the T.
I installed on an old 94 NAS. Droped the facia away from the dash to allow tucking and cut off about 6 inches in the top to allow installation without removing the AC. Complete removal of the AC takes 30 minutes if the hoese break clean but requires recharging once installed.
Old June 30th, 2008, 07:16 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I'm in the process of installing probably the same AC that Mark has. You'd be hard pressed to remove it without breaking the lines somewhere. There's a hard line that goes from the evaporator (underdash assy) to the filter drier, and another hard line going from the filter drier to the condenser. You could maybe loosen up the mounts for the filter drier and condenser, and get a little more movement of the underdash assy. But then you'd risk damaging the hard lines as well. As Stephen mentioned, it looks like you can get enough coverage without removing the AC.
Old June 30th, 2008, 07:54 PM
Thanks Ryan, good insight.
Old July 2nd, 2008, 08:34 AM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks Safari Rover. I don't have AC but my hood cable is on the left side of the passenger foot well. I have no problem making the update if it makes sense. How do you change where the hood cable is if the mount is welded on there?
Old July 3rd, 2008, 08:43 AM
SafariHP's Avatar
SafariHP
1983 Defender 110
Barry you should be OK with the way yours is mounted.
cover, fs, rubber, td5
NAS Style Used Rubber Kick Panel Set SafariHP The Vendors Loft 8 March 16th, 2010 09:17 PM
Used Rubber Kick Panel Mat for R380s SafariHP The Vendors Loft 12 January 6th, 2009 08:32 PM
TD5 Sytle Seatbox Cover FS SafariHP The Vendors Loft 3 September 5th, 2008 10:18 PM
Trunnel cover rubber floor mat k4rovers Wanted 0 November 13th, 2005 07:28 PM
94 ST Fuse Panel Cover mfreeman17 Wanted 0 June 28th, 2004 01:30 AM
