SDO new front grille & other products - Page 8 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old March 11th, 2016, 12:01 PM
The Dro
Dro
1988 Ninety
Question... Are all ROW the same?
I don't remember needing this "hole" to open up the hood of my shitbox
Old March 11th, 2016, 12:04 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
on a stock grill you could probably sneak you fingers under there
------ Follow up post added March 11th, 2016 12:07 PM ------
Yes, as Pedro said...(though final product will be form-rolled to match the grille surround bend). Picking them up from powdercoat *hopefully* end of next week.
I'll take one of those
Didnt see the option for them on your site
Old March 11th, 2016, 12:46 PM
It just depends on which "hood release" option you have...essentially either:
1) in-cabin bonnet pull
2) manual release lever at the actual bonnet (see prior post with Doug & I exchanging pics)
Many folks swap to & from either setup, so may not be dependent on year so much as prior owner or personal preference.
------ Follow up post added March 11th, 2016 12:48 PM ------
I'll ping you when I get them back from powdercoat....which *should* be the end of next week.
Old March 11th, 2016, 01:17 PM
The Dro
Dro
1988 Ninety
I have 1)... It's a choke cable.
Old March 12th, 2016, 09:57 PM
Any progress on the Z logo spare cover?
Old March 16th, 2016, 09:28 PM
Latest small project installments are done and "ready" to go...details as follows (the "cutout" front grilles are done as well, just need to find time to photograph & upload them for ordering):
10.5" DEMISTER/DEFROST VENT TRIM (set of 2, to fit the "earlier" 1983-~1988 trucks)
These are replacements for the front dash windscreen demister/defrost vent trim pieces, as the factory vents tend to warp/distort over time from heat & sun damage. They are a direct replacement for factory part number #MTC6040, which are the shorter 10.5” long vents that fit model year 1983-1988 Defender 90/110/127 ONLY (please note these will NOT fit the larger 14.5” #BTR912 vent from the later trucks from 1989-on, please see our other available larger set for these vehicles). ALSO a suitable replacement for factory part #395871 for the Land Rover Series III vehicles from 1973+ (except Lightweight) with the black plastic dash.
Pricing is $130 retail, or $117 with the ‘Defender Source’ 10% discount applied. These units are DONE, in-hand, and ready to ship! Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/inter...t-trim-10.html
ID:	145154 Click image for larger version
ID:	145155 Click image for larger version
ID:	145156 Click image for larger version
ID:	145157 Click image for larger version
ID:	145158 Click image for larger version
ALUMINUM GRILLE BADGE MOUNT (Bolt-On with "Land Rover" green & gold emblem, OR also an option for a silver & black emblem)
Solid aluminum Badge Mount designed to bolt directly onto our Aluminum Defender Front Grille, and features the genuine Land Rover Green & Gold oval emblem decal #DAG100330 inset directly onto the badge mount (or the alternate black & silver #DAG500140 ). Crafted from solid billet aluminum and powdercoated black, comes with stainless-steel mounting hardware for an easy and quick install. Measures approximately 3-1/2" wide x 1-13/16 tall x 1" deep.
While designed specifically for our Aluminum Defender Front Grille, this unit can ALSO be used as an upgraded replacement for the factory grille badge mount #MXC6402 (that originally came on the plastic factory front grille for the Defender). When ordered as a stand-alone unit this will come with longer 1" mounting bolts required for fitting to the factory plastic grille (versus the 1/2" mounting hardware that is included to specifically fit the SDO Front Grille)
Pricing is $100 retail, or $90 with the ‘Defender Source’ 10% discount applied ($85/$76.50 when purchased with the SDO Front Grille). These units are DONE, in-hand, and ready to ship! Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
GREEN & GOLD EMBLEM: https://www.seriesdefender.com/badge-mount-green.html
BLACK & SILVER EMBLEM: https://www.seriesdefender.com/badge-mount-black.html
ID:	145161 Click image for larger version
ID:	145162 Click image for larger version
ID:	145163 Click image for larger version
ID:	145164 Click image for larger version
ID:	145165 Click image for larger version
ID:	145166 Click image for larger version
ID:	145167 Click image for larger version
ID:	145168 Click image for larger version
ID:	145169 Click image for larger version
ID:	145170 Click image for larger version
SOFT-TOP CLIPS (not a new product...but "back in stock" after a small hiatus)
CNC Milled Aluminum Soft Top Clips for retaining the rear window tailgate crossbar rail. These will fit any model Defender 90 that utilizes a soft-top, generally either the factory top or any similar aftermarket tops (as long as they still retain the rear window crossbar rail - which most do).
This is an upgraded replacement for your weak, plastic, factory rear window retaining clips for your rear crossbar that can crack and break over time - leaving your rear window literally flapping in the wind. These aluminum replacements will solve your problem and/or prevent your future problems (if you haven’t had it happen yet…it will). The "original" plastic clips were included in the factory part #LRNA71713 "Tailgate Kit for the Defender 90 Soft Top".
Pricing is $85 retail, or $76.50 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/soft-top-clips.html
ID:	145173 Click image for larger version
ID:	145174 Click image for larger version
Old March 23rd, 2016, 05:55 PM
Pics of the "cutout" version #2 of the Front Grille...this is before they go to be form-rolled (to match the curvature of the Defender grille surround):
The "cutout" version of the Front Grille is officially back from powdercoat...looking good, I snapped some quick pictures below. Still need to do some "proper" photography but it gives an idea.
Just did a very small batch for these to gauge interest, and *essentially* based on those folks that expressed interest it looks like ~approximately 1/2 of them may be spoken for. We'll see how demand goes if it necessitates it being a continued product....but for now first-come-first-served .
Those that did express interest should have either an email or pm from me at this point, and those folks are first-in-line with priority being offered to them for purchase....
ID:	145750   Click image for larger version
ID:	145752   Click image for larger version
ID:	145754   Click image for larger version
ID:	145756   Click image for larger version
ID:	145758   Click image for larger version
Old March 24th, 2016, 07:50 AM
Also upon request in this round....I did have a couple of folks that had custom ordered "bare" aluminum standard front grilles (either for people that may want a color change and/or do custom paint, or may want to clear anodize them to keep them the aluminum color). I did leave a few extra units above & beyond bare as well, so if anyone has a need for a bare unit let me know:
ID:	145813   Click image for larger version
Old April 4th, 2016, 06:03 PM
Got the "removable" Solihull Badge option worked out...which mounts over the cutout hole to hide the latch from view when not in use.
The unit is mounted with some custom magnets designed to bolt through the octagonal holes, retained at the back, and with a riveted piece of flat-bar steel on the backside of the Solihul Badge. Pretty slick, and thanks for Uncle Douglas for the inspiration!
It is extremely sturdy when mounted, and you can either swing it down from either side for quick-access to the manual bonnet latch - or completely remove it with firm pressure to pop the entire badge right off.
ID:	146632   Click image for larger version
ID:	146634   Click image for larger version
ID:	146636   Click image for larger version
ID:	146638   Click image for larger version
ID:	146640   Click image for larger version
ID:	146642   Click image for larger version
ID:	146644   Click image for larger version
Old April 4th, 2016, 08:21 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I want one, must sell my heritage grill, unless you take trade ins?
Its funny, I have an aero brake on my tri bike that uses magnets in almost the same way.
Old April 4th, 2016, 08:55 PM
No trades Kramer ....I'll shoot you an email.
Old April 4th, 2016, 09:34 PM
Save one for me Jason.
Originally Posted by pendy
I'm here for the D's
Old April 30th, 2016, 04:53 PM
Thanks Lav - got it mounted today after fixing (hopefully) coolant and fuel leaks.
Old April 30th, 2016, 07:10 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Looks Great!!!!
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old April 30th, 2016, 08:31 PM
When are we going to see SDO NMO antenna mounts, ham HT racks, morse key plinths ...
Old April 30th, 2016, 10:50 PM
well...
you "can" mount the radio bodies in the SDO Under console box and the radio head on the SDO Dash Bar
a morse key plinth... Jason you going to have to come up with something!!
95' D90 - daily driver..
Old May 1st, 2016, 08:45 PM
Brian - NICE! Love the gratuitous SDO hat shot in there...looks great.
Old May 2nd, 2016, 08:24 AM
Originally Posted by Ncrover725 View Post
Looks Great!!!!
thanks doodes...it's in the running for the nicest thing on the truck
Old May 2nd, 2016, 08:36 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Grill engaged
My heritage grill was nice, this grill is really,really nice!
Plus I won't dread opening the hood so much.
The craftsmanship is unbelievable.
Old May 3rd, 2016, 01:44 PM
ha ha = i thought the same thing
looks great
Workshop Manual & Parts Manual & other shtuff... norros For Sale - Parts 5 April 3rd, 2014 09:25 PM
2 New manufactured Products From Safari HP SafariHP The Vendors Loft 0 November 5th, 2013 02:22 PM
Puma New take-off extended front grille panel Macker For Sale - Parts 1 May 15th, 2013 09:58 PM
Return of a popular bumper and other protection products ECR The Vendors Loft 206 April 3rd, 2012 09:45 PM
NAS & Momo Steering Wheels & other small stuff don For Sale - Parts 9 March 6th, 2012 09:55 PM
