SDO new front grille & other products - Page 4 - Defender Source
Go Back   Defender Source > Classifieds > Vendors
Old May 22nd, 2015, 01:59 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Dammit...just installed my fender vents, rear window mounts and console piece....now I have to spend more....damn that grille looks nice!
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old June 2nd, 2015, 07:31 PM
A few of the next round of products are done and *finally* back from powdercoat...I did a couple of links elsewhere but figured I'd put it all here in one spot as well. Here's a recap of the new items that are now ready and complete:
SEAT BACK TRIM RUBBING STRIP (set/2)
These are the plastic strips that screw to the back of the front seats (mostly in the NAS ST trucks), but *technically* fit any model year Defender up to 2007 (original part #MWC6106PCB). It essentially keeps the seat back material from rubbing/tearing on the NAS cage or anything else behind when in the fully reclined position. This falls into the “more of an annoyance” category since these tend to break/crack at the screw-hole mounting points over time (I guarantee anyone that has these in their truck, go look at them and they are cracked/broken). These replacements are CNC milled from one-piece solid bar aluminum, and powdercoated black for a durable finish.
Pricing (for the set of 2) is $95 retail, or $85.50 with the ‘Defender Source’ 10% discount applied. These units are DONE, in-hand, and ready to ship!
Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/inter...ing-strip.html
ID:	122116 Click image for larger version
ID:	122117 Click image for larger version
ID:	122118 Click image for larger version
ID:	122119 Click image for larger version
ID:	122120 Click image for larger version
ID:	122121 Click image for larger version
ID:	122122 Click image for larger version
ROW LOWER DASH SWITCH PLATE
This is an upgraded replacement for the lower dash switch panel by the drivers’ knee, and on the ROW trucks house the interior & dash lights, hazard switch, etc (similar to original part #MTC2640). However, unlike the factory part, the switch plate cutouts on this replacement have been modified and configured to hold (3) Carling switches instead of the factory switches (but still fitting the switch panel to the mounting space allotted). Many find the change over to Carling switches a worthwhile upgrade, and frankly after discovering the astronomical price of the genuine ROW Hazard Switch (part #PRC2278) and the shoddy construction of the interior & dash light switches - going Carling and never looking back has been a blessing to many of us, and I know others will benefit from this upgrade as well. This replacement switch panel is CNC milled from one-piece solid bar aluminum, and powdercoated black for a durable finish.
Pricing is $45 retail, or $40.50 with the ‘Defender Source’ 10% discount applied. These units are DONE, in-hand, and ready to ship!
https://www.seriesdefender.com/face/...panel-row.html
ID:	122124 Click image for larger version
ID:	122125 Click image for larger version
ID:	122126 Click image for larger version
ID:	122130 Click image for larger version
ID:	122127 Click image for larger version
ID:	122128 Click image for larger version
ID:	122140 Click image for larger version
NAS LOWER DASH SWITCH PLATE
This is a new part to add a lower dash switch panel by the drivers’ knee, which on the NAS trucks this area contains only the smaller dash lights dimmer switch. The factory dash dimmer switch is notorious for failing (which leaves it in the dim / "barely visible" position), and does not offer a Carling Switch configuration. However, this switch plate has been modified and configured to hold (3) Carling switches instead of just the single factory switch (but still fitting to the mounting space allotted). This switch panel is CNC milled from one-piece solid bar aluminum, and powdercoated black for a durable finish.
PLEASE NOTE: this upgrade may not be for everyone as it does require *some* cutting of the vinyl wrapped on the factory dash as well as enlarging or cutting a portion of the metal skin behind the vinyl portion of the dash. BUT to reiterate as mentioned above, many find the change over to Carling switches a worthwhile upgrade, and after years of continuous issues with the dash dimmer switch...going Carling is worth the peace of mind.
https://www.seriesdefender.com/face/...panel-nas.html
ID:	122131 Click image for larger version
ID:	122132 Click image for larger version
ID:	122133 Click image for larger version
ID:	122134 Click image for larger version
ID:	122135 Click image for larger version
ID:	122137 Click image for larger version
ID:	122138 Click image for larger version
Old June 3rd, 2015, 01:43 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Jason,
Does the new NAS Switch plate come with blanks if you don't have enough to fill three spots?
Nick
Old June 3rd, 2015, 01:49 PM
Originally Posted by 97-D90-736 View Post
Jason,
Nick
Nick:
It doesn't come with any blanks per se, but below is the Carling #RCV-39000001 that I've used personally when this need arises.
SIDE NOTE: I've actually been still *working* on getting setup as a Carling dealer, and the goal being to carry some of their basic switches...off-on, off-on-on, on-off-on, hazard, some ARB switches, and the blanking plugs. I'll circle back with them to see if there's been any progress, but for now I just generally source mine from places mentioned above or MUD UK. But hopefully I can change that down the road...
Old June 3rd, 2015, 02:35 PM
97-D90-736
Nick Vogel
Thanks. Gonna hold tight and see if you cant get a license. Huge fan of one stop shopping.
Old June 3rd, 2015, 02:41 PM
How many blanks do you need?
Old June 4th, 2015, 03:05 PM
97-D90-736
Nick Vogel
ill need 2.
Old June 5th, 2015, 06:35 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Jason,
Might be worth looking into the Carling switch that replaces the Rear Washer Wiper. Mud UK has it, but they make it sound like it was a special switch just made for them.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old June 5th, 2015, 06:48 PM
Chris B
72 + D1 drivetrain =?
I used these guys for switches OTRATTW :: Switch w/Rocker :: Contura II & III
Old June 28th, 2015, 02:05 PM
One of our international customers just sent these pics of the SDO Front Grille installed, and it looked so damn good I had to pass it along:
Name:	sdo grill install1.jpg
ID:	123832   Click image for larger version
Name:	sdo grill install2.jpg
Name:	sdo grill install3.jpg
ID:	123834   Click image for larger version
Name:	sdo grill install4.jpg
Name:	sdo grill install5.jpg
ID:	123836   Click image for larger version
Name:	sdo grill install6.jpg
Old June 29th, 2015, 09:34 PM
Working on a new badge mount for the "factory" Land Rover oval decal (to fit part #DAG100330). That way, there's the retro cast-aluminum Solihull badge option...but also a newer Land Rover decal option for those that want to stick with the more traditional badge mount:
ID:	123947   Click image for larger version
Old June 29th, 2015, 09:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
Nicely done
Old June 29th, 2015, 10:37 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
You have to admit this is damn good!
Old June 29th, 2015, 10:55 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2516
Working on a new badge mount:
I would say rather that you've perfected it! That looks freakin' outstanding!
"Barry is correct!"
Old June 29th, 2015, 11:24 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Jason, I saw your products at the NW Overland Rally this past weekend. Looks top notch!
Old June 29th, 2015, 11:48 PM
Thanks Carl! Much appreciated, that obviously means a lot coming from you as well .
Old June 30th, 2015, 12:30 AM
Originally Posted by bjf View Post
Nicely done
Thanks gents!
Old June 30th, 2015, 05:30 AM
Stormer's Avatar
Stormer
JP
2008 RRSC
Better than great. I think fantastic.
"These are the best traveled nuts on d-90 . . ." ABrooks
Old July 1st, 2015, 01:34 AM
D90Overkill
David Frank
1995 ST #2516
Ooooh! Everything so shiny! Make me want to touch. Must resist! Fear the restraining order.... ;-)
"Barry is correct!"
Old July 1st, 2015, 10:08 AM
D90Overkill
David Frank
1995 ST #2516
And to boot, those Hella horns look to do the trick! Flip style fair lead and your in business. That's a sweet setup altogether!!!
"Barry is correct!"
Workshop Manual & Parts Manual & other shtuff... norros For Sale - Parts 5 April 3rd, 2014 08:25 PM
2 New manufactured Products From Safari HP SafariHP Vendors 0 November 5th, 2013 01:22 PM
Puma New take-off extended front grille panel Macker For Sale - Parts 1 May 15th, 2013 08:58 PM
Return of a popular bumper and other protection products ECR Vendors 206 April 3rd, 2012 08:45 PM
NAS & Momo Steering Wheels & other small stuff don For Sale - Parts 9 March 6th, 2012 08:55 PM
