SDO Intro pricing: stainless hardware kits, 2nd row window vents, skid plates & more - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old April 19th, 2016, 06:05 PM
Had to order in a bunch of additional items for a customer project I'm working on assembling parts for....and some of which were items from Nakatanenga (in particular their stainless hardware kit, their window vents, door opening angle kit, skid plates, and a bunch of other goodies). Anyhow, I was very impressed with the quality once it arrived - VERY impressed. This led to talks with Peter Hochsieder over there, and as such I'm happy to announce that SDO will be acting as a Stateside liaison and carrying a bit of their product line (and hoping to expand that offering going forward as well).
I ordered in a preliminary shipment on spec, and have a much larger order going in shortly - and wanted to pass along some discounted "intro/preliminary pricing" to the DefenderSource folks as well on this opening order as a gesture of good faith both to them as well as the community here. Anyhow, here’s a few of the items that either will be inbound or are already here as well as the discounted initial pricing on orders from now through next Monday 4/25 (you’ll notice that there is the discounted “intro” price…and THEN the 10% DefenderSource discount on top of that price…that is NOT a typo!):
Defender 110 SW / 130 CC Stainless Hardware Kit (Exterior)
This stainless steel bolt/screw hardware kit fits a 110 Station Wagon or 130 Crew Cab configuration, and contains approximately 430 pieces. This it the only stainless kit for the Land Rover Defender that comes complete with the GENUINE Land Rover door bolt head configuration. The kit includes the stainless hardware for bonnet hinges, load area bars/reflectors, front grille, headlight surrounds and wingtop vent air intake covers, door pillar & a-pillar, side door hinges, back door hinges, rear crossmember, spare tire carrier, rear body mount crossmember tabs, bonnet buffer screws, and anti-seize paste packets.
Pricing is $200 retail ($175 “intro price”), or $157.50 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exter...screw-kit.html
Defender 90 SW Stainless Hardware Kit (Exterior)
This stainless steel bolt/screw hardware kit fits a 90 Station Wagon configuration, and contains approximately 380 pieces. This it the only stainless kit for the Land Rover Defender that comes complete with the GENUINE Land Rover door bolt head configuration. The kit includes the stainless hardware for bonnet hinges, load area bars/reflectors, front grille, headlight surrounds and wingtop vent air intake covers, door sill inside, a-pillar, side door hinges, rear crossmember, spare tire carrier, rear body mount crossmember tabs, bonnet buffer screws, and anti-seize paste packets.
Pricing is $175 retail ($150 “intro price”), or $135.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
ID:	147637 Click image for larger version
Defender 2nd Row Rear Door Window Vents (set of 2)
Defender Rear Door Window Vents (set of 2) are perfect for allowing air circulation without compromising security or allowing water to enter. They are extremely easy to install, just roll down the rear window, place the Vents, and roll the window back up....there are NO modifications required to install these units.
Pricing is $100 retail ($90 “intro price”), or $81.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exter...dow-vents.html
ID:	147641 Click image for larger version
ID:	147642 Click image for larger version
ID:	147643 Click image for larger version
Defender Stainless Steel Vent Hinge Pins
A set of 4 Defender Stainless Steel Vent Hinge Pins, this kit contains (4) total pins/screws with (10) total nuts - 2 extras are included as a bonus. These Vent Hinge Pins will fit all pre-2007 model year Defenders.
Pricing is $35 retail ($30 “intro price”), or $27.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exter...inge-pins.html
ID:	147645 Click image for larger version
Rear / 2nd Row Door Opening Angle Kit for Land Rover Defender 110 / 130
This stainless steel door opening angle kit allows you to open the rear / second row doors on a Defender 110 or 130 Crew Cab to a maximum angle of 95°. This provided more convenient ingress and egress for passengers, but also more room to access and load gear in and out of the rear doors (coolers, fridges, storage cases, etc). Easy installation with no drilling required, as it bolts to the original mounting points. Fits all model years of the Land Rover Defender 1983-present.
Pricing is $135 retail ($100 “intro price”), or $90.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exter...angle-kit.html
Name:	TOEWDEF-T-r-ffnungswinkel-f-r-Land-Rover-Defender-110130CC-T-r-ffnungswinkel2-kl-6-WZ.jpg
ID:	147647 Click image for larger version
Name:	TOEWDEF-T-r-ffnungswinkel-f-r-Land-Rover-Defender-110130CC-T-r-ffnungswinkel2-kl-2-WZ.jpg
Defender Aluminum Steering Guard / Skid Plate and Mounting Brackets
Aluminum Steering Guard / Skid Plate and Mounting Brackets, fits ALL model years of the Land Rover Defender from 1983 to present. The units are constructed from 1/4" (6mm) aluminum high-strength alloy, and the side mounting brackets are 1/4" (6mm steel) that are galvanized and then powder coated black. Skid Plate is available in either silver anodized, or an optional black powder coated version.
Pricing is $300 retail ($275 “intro price”), or $247.50 with the ‘Defender Source’ 10% discount applied (black powdercoated version available for +$50). Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exter...ing-guard.html
ID:	147649 Click image for larger version
ID:	147650 Click image for larger version
ID:	147651 Click image for larger version
A bunch of other items are either inbound as well or can be special ordered, such as:
Stainless Steel 7" Headlight Mounting Rings for Land Rover Defender (Pricing is $65 retail ($55 “intro price”), or $49.50 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$15).
Stainless Steel Headlight Mounting Screw Kit for Land Rover Defender (Pricing is $40 retail ($35 “intro price”), or $31.50 with the ‘Defender Source’ 10% discount applied).
Defender Galvanized Steel Heavy Duty Tie Rod / Track Rod Guard (Pricing is $150 retail ($125 “intro price”), or $112.50 with the ‘Defender Source’ 10% discount applied).
Defender Stainless Steel Spare Tire Carrier for Station Wagon (Pricing is $950 retail ($900 “intro price”), or $810.00 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$75).
Defender Aluminum Rear Ladder for Station Wagon 90/110 (Pricing is $160 retail ($150 “intro price”), or $135.00 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$20).
Lots of other items will soon be available or can be special ordered upon request...if there's anything in particular you're looking for let me know.
Name:	BLERDEF-Bearlight-Edelstahl-Einbauringe-f-r-7-Land-Rover-Defender-Hauptscheinwerfer-IMG_2863-10-.jpg
ID:	147663   Click image for larger version
Name:	BLERDEF-Bearlight-Edelstahl-Einbauringe-f-r-7-Land-Rover-Defender-Hauptscheinwerfer-IMG_2863-8-W.jpg
Name:	BLERDEF-Bearlight-Edelstahl-Einbauringe-f-r-7-Land-Rover-Defender-Hauptscheinwerfer-IMG_2863-6-W.jpg
ID:	147665   Click image for larger version
Name:	STC1614VA-Befestigungssatz-Scheinwerfer-f-r-Land-Rover-Defender-mit-Edelstahlschraube-1-WZ.jpg
ID:	147667   Click image for larger version
ID:	147669   Click image for larger version
ID:	147671   Click image for larger version
ID:	147673   Click image for larger version
Old April 19th, 2016, 06:29 PM
bjf's Avatar
bjf
barry f
94 ST #395
Best stainless kit I have ever used. Factory heads on all bolts for the purest!
Nice pricing!
Old April 19th, 2016, 06:44 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Oh yeah, will place an order for sure. Did you receive the seat cushion?
Eddie
Old April 19th, 2016, 07:02 PM
C'mon Lav! - I literally received a hodge podge stainless kit i put together from McMaster Carr TODAY. This is way better!
PS - I'll call you on the pm.
Old April 19th, 2016, 07:06 PM
McMaster has a phenomenal return policy .
Eddie
Eddie - yes, foam is here....admittedly with attending URE and Rovers At Wintergreen the past 2 weeks, it's still on the bench and in the box! But the plan is to rebuild the seat *hopefully* this weekend (though I now have a broken diff to remediate as well, so we'll see which takes priority : ).
Old April 19th, 2016, 07:30 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
How bout a gas tank skid . Nice looking pieces...
Old April 19th, 2016, 07:32 PM
The Dro
Dro
1988 Ninety
Anyone interested in a pair of kidneys?
Old April 19th, 2016, 07:34 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Ummm... You need at least one to live...
Old April 19th, 2016, 07:35 PM
The Dro
Dro
1988 Ninety
LOL
I was kidding...
Old April 19th, 2016, 07:47 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
nope.....that's what dialysis is for!
That's some nice stuff, Jason.
Rent my
Old April 19th, 2016, 09:14 PM
Need the vent pins too. Please add 3 sets to the UD pile. Can we/you get a righteous deal on the 130 bed liners ?
Old April 19th, 2016, 10:14 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Vent pins ordered!
I had already ordered the Nakatanenga kit for a 90 ST a few months back BUT I never ordered the vent pins so this came at a good time!
Rent my
Old April 19th, 2016, 10:29 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Order placed. Thanks!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old April 20th, 2016, 03:52 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Order placed for SS hw kit and skid plate. Perfect timing, since I just took delivery of my D90 today! Thanks!
Old April 20th, 2016, 11:09 AM
Winston-Rover's Avatar
Winston-Rover
Mike Giovannozzi
95 D-90 ST
order placed. thanks!
Old April 21st, 2016, 01:33 PM
Folks - thanks for the orders, response was WAY better than expected . That said, first round of shipments going out this week....the rest of the orders will ship promptly (likely toward the latter part of next week) once the "larger order" arrives. I'll keep everyone posted, and automated tracking should come via email once your individual orders are physically outbound to you....
LASTLY, keep in mind that the "intro pricing" described above is still good through this Monday 4/25....
Old April 21st, 2016, 04:38 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
Do they make a nas kit, if so I'll buy for a 110 & a 90 st
Old April 21st, 2016, 05:56 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Better question is will the SW kit work for the ST
Old April 21st, 2016, 07:20 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
True but I need more bolts for the cage.
Old April 22nd, 2016, 10:18 AM
I'm verifying a couple of things, BUT yes the SW kit will work for a ST. *HOWEVER* it does not include the cage bolts for a 110 or 90.
And honestly....I don't recommend using stainless steel in a safety or structural application such as a safety cage like the NAS or SD cages. Those should always be grade 8 or higher (or metric 10.9 or higher) for maximum strength in a situation where your cage is actually "needed" (i.e. rollover, car accident, etc).
window, kit
SDO new front grille & other products nathanwind The Vendors Loft 180 October 14th, 2016 04:00 PM
SDO special: DPx Gear / folder & fixed blade knives nathanwind The Vendors Loft 29 February 23rd, 2016 08:54 AM
Stainless Hardware Kits Kexby The Vendors Loft 47 January 16th, 2014 06:45 AM
Stainless Hardware Kits Abrooks For Sale - Parts 5 February 23rd, 2012 07:57 PM
SALE Stainless hardware kits D90 brn24whl The Vendors Loft 0 November 17th, 2010 09:32 AM
