SDO Intro pricing: stainless hardware kits, 2nd row window vents, skid plates & more
kit window
8K views 41 replies 22 participants last post by  nathanwind
#1 · (Edited)
Had to order in a bunch of additional items for a customer project I'm working on assembling parts for....and some of which were items from Nakatanenga (in particular their stainless hardware kit, their window vents, door opening angle kit, skid plates, and a bunch of other goodies). Anyhow, I was very impressed with the quality once it arrived - VERY impressed. This led to talks with Peter Hochsieder over there, and as such I'm happy to announce that SDO will be acting as a Stateside liaison and carrying a bit of their product line (and hoping to expand that offering going forward as well).
I ordered in a preliminary shipment on spec, and have a much larger order going in shortly - and wanted to pass along some discounted "intro/preliminary pricing" to the DefenderSource folks as well on this opening order as a gesture of good faith both to them as well as the community here. Anyhow, here’s a few of the items that either will be inbound or are already here as well as the discounted initial pricing on orders from now through next Monday 4/25 (you’ll notice that there is the discounted “intro” price…and THEN the 10% DefenderSource discount on top of that price…that is NOT a typo!):
Defender 110 SW / 130 CC Stainless Hardware Kit (Exterior)
This stainless steel bolt/screw hardware kit fits a 110 Station Wagon or 130 Crew Cab configuration, and contains approximately 430 pieces. This it the only stainless kit for the Land Rover Defender that comes complete with the GENUINE Land Rover door bolt head configuration. The kit includes the stainless hardware for bonnet hinges, load area bars/reflectors, front grille, headlight surrounds and wingtop vent air intake covers, door pillar & a-pillar, side door hinges, back door hinges, rear crossmember, spare tire carrier, rear body mount crossmember tabs, bonnet buffer screws, and anti-seize paste packets.
Pricing is $200 retail ($175 “intro price”), or $157.50 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/defender-110-sw-130-cc-stainless-bolt-screw-kit.html
Defender 90 SW Stainless Hardware Kit (Exterior)
This stainless steel bolt/screw hardware kit fits a 90 Station Wagon configuration, and contains approximately 380 pieces. This it the only stainless kit for the Land Rover Defender that comes complete with the GENUINE Land Rover door bolt head configuration. The kit includes the stainless hardware for bonnet hinges, load area bars/reflectors, front grille, headlight surrounds and wingtop vent air intake covers, door sill inside, a-pillar, side door hinges, rear crossmember, spare tire carrier, rear body mount crossmember tabs, bonnet buffer screws, and anti-seize paste packets.
Pricing is $175 retail ($150 “intro price”), or $135.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/defender-90-sw-st-stainless-bolt-screw-kit.html
Defender 2nd Row Rear Door Window Vents (set of 2)
Defender Rear Door Window Vents (set of 2) are perfect for allowing air circulation without compromising security or allowing water to enter. They are extremely easy to install, just roll down the rear window, place the Vents, and roll the window back up....there are NO modifications required to install these units.
Pricing is $100 retail ($90 “intro price”), or $81.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/rear-window-vents.html
Defender Stainless Steel Vent Hinge Pins
A set of 4 Defender Stainless Steel Vent Hinge Pins, this kit contains (4) total pins/screws with (10) total nuts - 2 extras are included as a bonus. These Vent Hinge Pins will fit all pre-2007 model year Defenders.
Pricing is $35 retail ($30 “intro price”), or $27.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/defender-stainless-steel-vent-hinge-pins.html
Rear / 2nd Row Door Opening Angle Kit for Land Rover Defender 110 / 130
This stainless steel door opening angle kit allows you to open the rear / second row doors on a Defender 110 or 130 Crew Cab to a maximum angle of 95°. This provided more convenient ingress and egress for passengers, but also more room to access and load gear in and out of the rear doors (coolers, fridges, storage cases, etc). Easy installation with no drilling required, as it bolts to the original mounting points. Fits all model years of the Land Rover Defender 1983-present.
Pricing is $135 retail ($100 “intro price”), or $90.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/door-opening-angle-kit.html
Defender Aluminum Steering Guard / Skid Plate and Mounting Brackets
Aluminum Steering Guard / Skid Plate and Mounting Brackets, fits ALL model years of the Land Rover Defender from 1983 to present. The units are constructed from 1/4" (6mm) aluminum high-strength alloy, and the side mounting brackets are 1/4" (6mm steel) that are galvanized and then powder coated black. Skid Plate is available in either silver anodized, or an optional black powder coated version.
Pricing is $300 retail ($275 “intro price”), or $247.50 with the ‘Defender Source’ 10% discount applied (black powdercoated version available for +$50). Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/aluminum-steering-guard.html
A bunch of other items are either inbound as well or can be special ordered, such as:
Stainless Steel 7" Headlight Mounting Rings for Land Rover Defender (Pricing is $65 retail ($55 “intro price”), or $49.50 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$15).
Stainless Steel Headlight Mounting Screw Kit for Land Rover Defender (Pricing is $40 retail ($35 “intro price”), or $31.50 with the ‘Defender Source’ 10% discount applied).
Defender Galvanized Steel Heavy Duty Tie Rod / Track Rod Guard (Pricing is $150 retail ($125 “intro price”), or $112.50 with the ‘Defender Source’ 10% discount applied).
Defender Stainless Steel Spare Tire Carrier for Station Wagon (Pricing is $950 retail ($900 “intro price”), or $810.00 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$75).
Defender Aluminum Rear Ladder for Station Wagon 90/110 (Pricing is $160 retail ($150 “intro price”), or $135.00 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$20).
Lots of other items will soon be available or can be special ordered upon request...if there's anything in particular you're looking for let me know.
See less See more
26
#5 ·
McMaster has a phenomenal return policy :).
Oh yeah, will place an order for sure. Did you receive the seat cushion?
Eddie
Eddie - yes, foam is here....admittedly with attending URE and Rovers At Wintergreen the past 2 weeks, it's still on the bench and in the box! But the plan is to rebuild the seat *hopefully* this weekend (though I now have a broken diff to remediate as well, so we'll see which takes priority : ).
#13 ·
Order placed. Thanks!
#16 · (Edited)
Folks - thanks for the orders, response was WAY better than expected :). That said, first round of shipments going out this week....the rest of the orders will ship promptly (likely toward the latter part of next week) once the "larger order" arrives. I'll keep everyone posted, and automated tracking should come via email once your individual orders are physically outbound to you....
LASTLY, keep in mind that the "intro pricing" described above is still good through this Monday 4/25....
#31 · (Edited)
Quick update(s)....the "main" order was delayed a little longer than anticipated, but the balance of everything should be here this coming week, and any remaining open orders will ship out immediately.
Also, a couple of additions/updates that we've been working on in-house to complement the original above stainless kits as well:
Defender INTERIOR Stainless Hardware Kit
This is an INTERIOR stainless steel bolt/screw hardware kit to fit a Land Rover Defender 90/110, and contains approximately 360 pieces. The kit includes stainless hardware for: Lower Dash, Instrument Panel, Heater Controls & Center Dash, Dash & Visors, Demister/Defrost Vents, Windshield Pillars, Driver Side End Cap, Tray Trim, Door Panels (ST), Check Strap & Cover, Kick Panel Trim., Floor Pans, Door Sills, Rear Fender Brackets, Seat Rail Bolts, Rear Door Trim (if applicable). This is an extrapolation of the old stainless kits that Tony was doing awhile back, and is a nice complement to the 90/110 kits that we carry.
Pricing is $125 retail (Or $112.50 with the ‘Defender Source’ 10% discount applied). Use the coupon code "D90" at checkout to get the automatic 10% discount...photos/description available here:
https://www.seriesdefender.com/interior/defender-90-110-interior-stainless-bolt-screw-kit.html
Defender 90 ST (NAS) Stainless Hardware Kit (Exterior)
This stainless steel bolt/screw exterior hardware kit fits a NAS 90 Soft Top configuration, and contains approximately 485 pieces total. This expands on the 90 SW kits listed previously and includes the stainless hardware for bonnet hinges, load area bars/reflectors, front grille, headlight surrounds and wingtop vent air intake covers, door sill inside, a-pillar, side door hinges, rear crossmember, rear body mount crossmember tabs, bonnet buffer screws, anti-seize paste packets. But it ALSO includes the stainless hardware for the NAS ST Rear Brake Light Bar, Rear Tailgate Door Lock, Rear Tire Carrier Upper Hinge, Rear Tire Carrier Pivot Point, and Rear Tire Carrier Rubber Stops/Bumper.
Pricing is $225 retail (Or $202.50 with the ‘Defender Source’ 10% discount applied). Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/defender-90-st-stainless-bolt-screw-kit.html
#34 ·
Meant to post up some pics, but did an install the other week on the Steering Skid Plate/Guard on a customer/board member/friends 90...came out really nice, and tied in visually with the octagons on the SDO Front Grille as well!
Top
