SDO Intro pricing: stainless hardware kits, 2nd row window vents, skid plates & more
Had to order in a bunch of additional items for a customer project I'm working on assembling parts for....and some of which were items from Nakatanenga (in particular their stainless hardware kit, their window vents, door opening angle kit, skid plates, and a bunch of other goodies). Anyhow, I was very impressed with the quality once it arrived - VERY impressed. This led to talks with Peter Hochsieder over there, and as such I'm happy to announce that SDO will be acting as a Stateside liaison and carrying a bit of their product line (and hoping to expand that offering going forward as well).
I ordered in a preliminary shipment on spec, and have a much larger order going in shortly - and wanted to pass along some discounted "intro/preliminary pricing" to the DefenderSource folks as well on this opening order as a gesture of good faith both to them as well as the community here. Anyhow, here’s a few of the items that either will be inbound or are already here as well as the discounted initial pricing on orders from now through next Monday 4/25 (you’ll notice that there is the discounted “intro” price…and THEN the 10% DefenderSource discount on top of that price…that is NOT a typo!):
Defender 110 SW / 130 CC Stainless Hardware Kit (Exterior)
This stainless steel bolt/screw hardware kit fits a 110 Station Wagon or 130 Crew Cab configuration, and contains approximately 430 pieces. This it the only stainless kit for the Land Rover Defender that comes complete with the GENUINE Land Rover door bolt head configuration. The kit includes the stainless hardware for bonnet hinges, load area bars/reflectors, front grille, headlight surrounds and wingtop vent air intake covers, door pillar & a-pillar, side door hinges, back door hinges, rear crossmember, spare tire carrier, rear body mount crossmember tabs, bonnet buffer screws, and anti-seize paste packets.
Pricing is $200 retail ($175 “intro price”), or $157.50 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/defender-110-sw-130-cc-stainless-bolt-screw-kit.html
Defender 90 SW Stainless Hardware Kit (Exterior)
This stainless steel bolt/screw hardware kit fits a 90 Station Wagon configuration, and contains approximately 380 pieces. This it the only stainless kit for the Land Rover Defender that comes complete with the GENUINE Land Rover door bolt head configuration. The kit includes the stainless hardware for bonnet hinges, load area bars/reflectors, front grille, headlight surrounds and wingtop vent air intake covers, door sill inside, a-pillar, side door hinges, rear crossmember, spare tire carrier, rear body mount crossmember tabs, bonnet buffer screws, and anti-seize paste packets.
Pricing is $175 retail ($150 “intro price”), or $135.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/defender-90-sw-st-stainless-bolt-screw-kit.html
Defender 2nd Row Rear Door Window Vents (set of 2)
Defender Rear Door Window Vents (set of 2) are perfect for allowing air circulation without compromising security or allowing water to enter. They are extremely easy to install, just roll down the rear window, place the Vents, and roll the window back up....there are NO modifications required to install these units.
Pricing is $100 retail ($90 “intro price”), or $81.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/rear-window-vents.html
Defender Stainless Steel Vent Hinge Pins
A set of 4 Defender Stainless Steel Vent Hinge Pins, this kit contains (4) total pins/screws with (10) total nuts - 2 extras are included as a bonus. These Vent Hinge Pins will fit all pre-2007 model year Defenders.
Pricing is $35 retail ($30 “intro price”), or $27.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/defender-stainless-steel-vent-hinge-pins.html
Rear / 2nd Row Door Opening Angle Kit for Land Rover Defender 110 / 130
This stainless steel door opening angle kit allows you to open the rear / second row doors on a Defender 110 or 130 Crew Cab to a maximum angle of 95°. This provided more convenient ingress and egress for passengers, but also more room to access and load gear in and out of the rear doors (coolers, fridges, storage cases, etc). Easy installation with no drilling required, as it bolts to the original mounting points. Fits all model years of the Land Rover Defender 1983-present.
Pricing is $135 retail ($100 “intro price”), or $90.00 with the ‘Defender Source’ 10% discount applied. Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/door-opening-angle-kit.html
Defender Aluminum Steering Guard / Skid Plate and Mounting Brackets
Aluminum Steering Guard / Skid Plate and Mounting Brackets, fits ALL model years of the Land Rover Defender from 1983 to present. The units are constructed from 1/4" (6mm) aluminum high-strength alloy, and the side mounting brackets are 1/4" (6mm steel) that are galvanized and then powder coated black. Skid Plate is available in either silver anodized, or an optional black powder coated version.
Pricing is $300 retail ($275 “intro price”), or $247.50 with the ‘Defender Source’ 10% discount applied (black powdercoated version available for +$50). Use the coupon code "D90" at checkout to get the automatic 10% discount...many more photos/description available here:
https://www.seriesdefender.com/exterior/aluminum-steering-guard.html
A bunch of other items are either inbound as well or can be special ordered, such as:
Stainless Steel 7" Headlight Mounting Rings for Land Rover Defender (Pricing is $65 retail ($55 “intro price”), or $49.50 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$15).
Stainless Steel Headlight Mounting Screw Kit for Land Rover Defender (Pricing is $40 retail ($35 “intro price”), or $31.50 with the ‘Defender Source’ 10% discount applied).
Defender Galvanized Steel Heavy Duty Tie Rod / Track Rod Guard (Pricing is $150 retail ($125 “intro price”), or $112.50 with the ‘Defender Source’ 10% discount applied).
Defender Stainless Steel Spare Tire Carrier for Station Wagon (Pricing is $950 retail ($900 “intro price”), or $810.00 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$75).
Defender Aluminum Rear Ladder for Station Wagon 90/110 (Pricing is $160 retail ($150 “intro price”), or $135.00 with the ‘Defender Source’ 10% discount applied….black powdercoat option available for +$20).
Lots of other items will soon be available or can be special ordered upon request...if there's anything in particular you're looking for let me know.
