SafariDust Rear Speaker Boxes - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old February 20th, 2011, 11:13 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
These are made out of Aluminum and come primed with self etching primer.
Fully custimized to your needs, If you need the seatbelt cutout please let me know, if you intent is to use as a spacer for tuffy boxes also specify this as well.
These are built for soft tops and will need verification if they will work on SW, so with this being said I'm asking for one(1) volunteer if you have a NAS 90 SW please email me with your information.
$95.00 a pair
ID:	35974   Click image for larger version
Old February 20th, 2011, 12:41 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
At first glance I think they would be too deep to fit with the inward facing jump seats found in a SW.
I can get a better pic if it would help.
Old February 20th, 2011, 03:19 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
James,
Here are the side & top pictures, can you verify the clearance?
Also they idea behind extending the speakers out was to allow space for a 12v plug and courtesy lights to come on when you open the doors, of course I'm just talking for my own rig, but you get the idea.
ID:	35977   Click image for larger version
Old February 20th, 2011, 04:07 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Super psyched about these...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old February 20th, 2011, 05:25 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
You can run bigger speakers a tweeter, etc
Old February 20th, 2011, 05:40 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
They will fit a '94 ST, correct?
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old February 20th, 2011, 06:18 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Yes, perfect fit....
Old February 20th, 2011, 07:07 PM
NoVaKevin
Kevin
sold#1469
what size speaker are these made for?
Old February 20th, 2011, 08:19 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
These are for the stock size 5 1/2, although they will except are larger size.
Old February 20th, 2011, 08:30 PM
James Pierce
James Pierce Jr.
Definitely won't work with inward facing seats found in a SW. As you can see in the pic below the stock speaker housing only protrudes about 1/2" from the body. With my JL 6" component speakers in the stock housing this only leaves about 1/2" between the grill and the seat bracket.
Sorry about the pic, it's dark out.
Old February 21st, 2011, 02:13 AM
jbarks1's Avatar
jbarks1
John B
1995 Defender 90
Do you think a 6x9" speaker would fit in there and look decent? How do they attach to the body? Thank you.
Old February 21st, 2011, 07:49 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Thank you James,
So it would seem that with inward facing seats they would not fit.
John,
The housing size is: 10" H x 10" W (I subtracted unusable space)
Not to worry I'm already working on a set for SW with inward facing seats, I have jigs to work from and actual body panels... I just did not have those seats and placement in the SW
Old February 21st, 2011, 12:56 PM
jbarks1's Avatar
jbarks1
John B
1995 Defender 90
Hey Tom,
Thanks for the speedy reply. I'm definitely interested as it sounds like these will work for 6 x 9's. Just curious how these attach to the body. Do you bolt them in? Do they just sit in there flush without any retainers or straps? Do I need to fabricate a bracket after I receive them?
Thanks, these look really cool.
Old February 21st, 2011, 03:03 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Originally Posted by jbarks1 View Post
Hey Tom,
They use the original speaker mounting bolts, no extra holes required....I would recommend to use new bolts with large washers.
Tom
Old February 21st, 2011, 05:07 PM
wantone
Rick Thompson
94 ST #1222
i have a ST with the rear bench seat, will I need to notch these for the seat belt that runs up to the roll bar and over? i am super stoked about these! BTW, the kick panels i got from you recently for the driver and passenger side were perfect! Thanks!
i just re read the original post.... oops!
Old February 21st, 2011, 06:15 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Many thanks to everyone for positive feedback...
Old February 22nd, 2011, 12:51 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Are the speaker holes 5 1/2 or 5 1/4 inch????
Seems like most speakers are 5 1/4"
Old February 22nd, 2011, 06:53 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I measured my old stock set & they were 5 1/2, but really the speaker size and placement is one of the last steps we do, so at that point we can custom make what you need no worries.
Old March 4th, 2011, 05:45 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
some folks were asking for the seatbelt cutout, we just processed a few orders today so I snapped a picture.
The cutout for the seatbelt has been riveted to the box, should your configuration in the future change you can always remove the top (2) rivets and cover the holes again.
Old March 4th, 2011, 06:37 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Will this fit a 97 SW?
Rear Speaker Boxes & Seat Belt Y LRNAD90 Wanted 2 June 1st, 2006 03:01 PM
Rear Speaker Boxes mlw911 Defender Technical Discussions 3 June 17th, 2004 08:24 AM
ST rear speaker enclosures TDI Guy Wanted 4 April 16th, 2004 10:46 PM
