Replacement Footwell Trim Panels - Page 5 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old June 3rd, 2011, 07:27 AM
Josh's clutch is actually thicker and even stronger with the vertical orientation. Even his massive calves can't break that.
I doubt A/C is a factor. If you can't insert the trim top first behind the door catch, you'll need to trim there.
Then bend the bottom tabs down, insert it top first, then bend the bottom tabs up to hold the bottom. If it makes you feel better I still have not gotten around to installing mine
Originally Posted by pendy
I'm here for the D's
Old June 3rd, 2011, 03:31 PM
I'll give that a try tonight probably and post up the results. I love how the only instructions were "remove pedal rubber" ... like no $hit.
Old June 3rd, 2011, 03:38 PM
bjf's Avatar
bjf
barry f
94 ST #395
I gave you real instructions. Remove the trim at top to make it easier
Old June 3rd, 2011, 07:41 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Originally Posted by jefhuf View Post
Josh, pretty sure that you are going to have to trim out for your door arm. In my '94 I didn't have this problem. In this pic you can sorta see how I mounted mine. I used the small piece of angle trim that is held in with a few of the steering column surround screws and then used the tabs at the bottom...worked great!
Guys I had not seen this post in a while and just getting up to speed, Joshua as Jeff mentioned, the trim piece at the top holds the panel in place and once this is correctly in place will clear the door check strap slider.
Old June 3rd, 2011, 08:27 PM
I finally installed it. I did have to cut the top left side to get it to clear the door check, and rounded the edge off a little with a hammer so that it wouldn't be sharp (I don have a lot of fancy grinders and stuff). Looks better now, but what a pain in the ass to install!
ID:	39360   Click image for larger version
Old June 3rd, 2011, 10:26 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
no disrespect to Horsey but it was pretty easy on my truck...don't want to tarnish Tom's product because I think it is pretty good!
Old June 3rd, 2011, 10:33 PM
bjf's Avatar
bjf
barry f
94 ST #395
Did you take top trim out to install? I never had an issue. The door check issue I can understand
Old June 3rd, 2011, 10:50 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I just loosened the screws/trim. I actually installed those while I was doing some work on the dash so it all tied together nicely. I also made myself a set of side panels at the same time so the floorboard would be totally wrapped
Old June 3rd, 2011, 11:23 PM
No disrespect intended...perhaps I am the first with a '95, A/C, and in particular those door checks who has installed one of these on the driver's side. Jeff, if you look at your door check:
http://www.defendersource.com/forum/...0&d=1307064519
vs. mine:
http://www.defendersource.com/forum/...0&d=1307147168
you'll notice that I have an entire channel that it slides along, and this appears to be the main reason why this was so much trouble to install. 1994s could not "lock" open, but these '95s can, because of the channel and s bracket that locks it in place with the door open. I did have to remove the trim panel, and it was a little closer to fitting, but still would not work without trimming the footwell trim; definitely more than the "Instructions: remove pedal rubber" that came with it. It does look nice, but would look way nicer if I didn't have to resort to hacking the shit out of it, attempting to fit it 10 times, and scratching it in the process. One last critique would be that the accelerator section of the footwells could be beefed up a little or a little thicker on that edge, as that appears to be the Achilles heal with regard to its strength...it bent back almost any time I handled it.
Old June 3rd, 2011, 11:26 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
X2. Piece of cake on the 110. Great product!
Chance
Old June 3rd, 2011, 11:42 PM
Bludog66's Avatar
Bludog66
Scott Hoskin
1994 Defender 90 ST #1108
X3 - Very easy on my '94. Great product Tom!
Old June 3rd, 2011, 11:45 PM
Has anyone else with a '95 or '97 installed one of these? Was it without issue?
Old June 6th, 2011, 08:19 PM
taylo951
Matt Taylor
1985 D90 TD5
Did these ever get made for RoW RHD trucks? With A/C?
Old August 11th, 2011, 05:22 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I just installed a set on my '94 with the SW style doors on it. I can concur with Horsey's assessment, they do require some minor trimming in order to fit with the SW door check mechanisms. Not hard with a hacksaw at all, and otherwise were a fantastic fit.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 11th, 2011, 05:30 PM
Thanks Hans. Good to know I wasn't the only one who needed to trim off the top a bit.
Old August 11th, 2011, 09:08 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
-Hans
Hans,
How much was needed to trim off the top left side, I can make sure moving forward this can be incorporated to all panels.
Horsey, thanks for bringing this up to start with....
Old August 16th, 2011, 04:19 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
i have a 95 and I did just the pass footwell and removed the top trim piece as im not sure I could have gotten it in anyother way - it fit passed the door hold piece without issue though
Name:	Photo Aug 16, 1 15 57 PM.jpg
Old August 17th, 2011, 06:15 PM
jhhorse
joe heins
1995 defender 90
I have a 95 and have both the driver and passenger side, both pieces went in but not without some manipulation and slight bending to get behind the door trim. Once in they stay there though.
Old August 22nd, 2011, 01:51 AM
Hans's Avatar
Hans
Hans Haase
When I get a chance, I'll snap a photo and take some measurements. Should be able to do that in the next day or so.
-Hans
My oil line fix
Old April 9th, 2012, 02:41 PM
Abeer's Avatar
Abeer
Amarveer
94 D90 ST
Tom,
Are these still available? I just ripped out the cardboard in my drivers side this morning with my boot.
ac, defender, footwell, panels, replacement
Used D90 Interior Trim Panels Wanted Manimal Wanted 5 January 4th, 2010 06:16 AM
Metal footwell trim / finishers cabell Wanted 3 January 6th, 2009 08:20 PM
Footwell Trim Replacement 61rover Defender Technical Discussions 10 November 20th, 2007 12:57 AM
Defender footwell trim mattarm Wanted 0 June 19th, 2007 01:07 AM
How to ship lasalle headliner and SW trim panels? Chris Cox Defender Technical Discussions 4 March 23rd, 2005 08:07 AM
