Parting out a 97 Wagon - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old August 1st, 2010, 01:07 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
No Roll Cage, dash etc limited body stuff. Drove the truck into the shop. 78k on the clock if I recall before disassembly.
This is mostly an electrical part out but there are various other bits.
ECU w Cover Engine Bay plus looms
Dash Loom
Engine Loom
Frame Loom (cut in half - Frame was crunched in a bad place)
Engine Fuse Panel
ABS ECU
$4000.00 for Complete Electrical
Steering Wheel and Column $400.00
Auto Brake Pedal Box $125.00
Firewall $1200.00
Windsreen Frame (no glass) $50.00
Many more parts to be listed......
Post requests and I will see what I have.
Old August 1st, 2010, 02:04 PM
bamanuke's Avatar
bamanuke
mike hall
'97 alpine white sw # 0127
how bout the a/c trinary pressure switch on top of the drier? i ordered a new one from autopartswarehouse and it was not the correct switch so i've had to send it back.thanks,
Old August 1st, 2010, 04:42 PM
jakethesnake's Avatar
jakethesnake
Jake
95 D-90 ST
Fender flares?
I need the front passenger side.
Old August 1st, 2010, 05:08 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Rear Bench Seat Belts and all associated brackets? Licked if available....
Jerod
Old August 1st, 2010, 05:51 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
sorry none of the above. mostly just electrical.
Old August 1st, 2010, 06:30 PM
specops1526's Avatar
specops1526
Beluga '97 90
Center Console?
PM sent too.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old August 1st, 2010, 06:44 PM
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
I will take the steering column and wheel.
What kind of shape is the exhaust system in? Looking for the entire set up for a 4.0 (y-pipe with CATs all the way to the exhuast tip.
Navy. It's not just a job, it's a job on a ship.
Old August 1st, 2010, 07:10 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Sorry for the premature ummmm post. Be better if I list whats here and whats not.
Key and Switch w break away bolts and clamp $125.00
Fuel Tank Vent and Evap lost setup $30.00
Charcoal Cannister and PS Res $100.00
Switch Stalk Complete $150.00 (white Plug)
Sun Visors $50.00
Air Cleaner Assembly $79.00 Complete x 2
Fuel Filler Neck $10.00
Air Intake Pipe $30.00 x 2
MAS $125.00
Auto Diff Lock Cover (foam is hard) $30.00
Beather pipe EVap $15.00
Vent Handle Pair $35.00 x 2
Factory Amp $40.00
97 Cluster (Speedo Unknow) w tech $250.00
Washer Bottle Brackey $10.00
Overflow Bracket $10.00
Steering Column Surrond $25.00
Complete Looms, ECUs, Etc $4000.00
ECU and ECU Loom $2000.00 (different set)
Steering Column and wheel $400.00
Y Pipe w O2 Sensors (unknown) $400.00
Took images of all will post in my used section and link here so I don't have to post twice (if that is OK with board rules). You guys get a better price of course.
Console was installed in another truck recently so it is gone.
Old August 1st, 2010, 10:39 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Damn shame about the center console. Why cant there be a decent alternative???
Old August 1st, 2010, 10:48 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
The one from across the pond works OK. They did a good job building but finished with crap hardware.
Old August 2nd, 2010, 07:42 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
Do know have any information on where to get the center console. I need to replace mine as well.
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old August 2nd, 2010, 07:08 PM
surf110's Avatar
surf110
Ze
130 Project
Crash. Check this out:
http://www.ashcroft-transmissions.co...&productId=121
Old August 2nd, 2010, 09:54 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
I,ve used several. Ok with the make but damn if they did not finish with the worse hardware available. Replace the hardware and the unit works for about $800.00.
Old August 3rd, 2010, 12:38 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
Thanks guys. Wonder what shipping will be like?
Old August 3rd, 2010, 05:06 PM
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
Safari Rover, have you posted the pics to your website? I searched but only saw the 110 bodies. Thanks.
Old August 3rd, 2010, 09:43 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
How about the white plastic ECU cover?
-Ren Ching
Old August 3rd, 2010, 10:02 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Hey Stephen I need the grommet that goes between the door and the body the the speaker wire run through. How much? and how much for a set of doors if I pick them up?
Old August 3rd, 2010, 10:09 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Sorry man I am keeping the doors I have left to use on my own projects. Down to 10 sets or so. Should have a grommet around. Will keep an eye out.
------ Follow up post added August 3rd, 2010 10:10 PM ------
Sorry that goes with the ECU that goes with the wiring, etc. I know there is a burn 90 out there that needs this stuff.
------ Follow up post added August 3rd, 2010 10:12 PM ------
Working on the images. Taking longer than I thought to get them all up. I will be at DTRA and Belvore soon are you on post. Send me an email and I will zip and send the lot.
Old August 3rd, 2010, 10:41 PM
Stephen,
Got an email that you are shipping me the two pallets of parts. Please send them to the same address-Cabell has the fork lift @ his place.
Cheers,
Doug
Old August 3rd, 2010, 10:45 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Roger that. Waiting on the final payment and then they are on the way. Your getting the auto padding fromt this post as well.
Originally Posted by 130Tdi View Post
Stephen,
Cheers,
Doug
97, part
97 Wagon Numbering gtg067i Defender Technical Discussions 4 December 2nd, 2009 09:42 AM
Parting 97 Disco 1 enjoi1968 For Sale - Parts 3 July 31st, 2009 12:28 PM
Parting '97 D90 Station Wagon charles kellogg The Vendors Loft 13 May 30th, 2007 03:11 AM
97 D90 Wagon $29,500 OBO hayser For Sale - Vehicles 2 December 10th, 2005 11:40 PM
Interior roll cage pads for 97 Wagon kevincdoyle Wanted 1 March 29th, 2004 09:25 PM
