NAS 94 Part Out 100% must go....... - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old July 25th, 2012, 06:08 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
We are parting the NAS 94 burn victim. First off everything that is painted black is poorly painted............
First off there are no interior parts that we plan to sell. The roll cage is here but the padding is burned off and the A-hoop is AWOL.
Items such as the tire carrier will be listed here first and all will be OBO after a few days the items will be listed on Ebay. I have yet to decide what to do with the motor and gear box?
Cool items that seem to good
1. Chassis (Engine mounts are moved back but we can fix) otherwise nearly perfect $1000.00
2. Tire Carrier is all there but needs to be blasted and re-coated $450.00
3. Capings are good $150.00 for the pair
4. Left Outer wing is good $75.00
5. Both wing tops and fronts are new but badly painted $450.00 for the set
6. Fuel tank could be OK, gonna check it $600.00 if above average
7. Inner wings are good but poorly painted black $75.00 ea
8. Bonnet is good (td5 Type) $450.00
More to follow but here is a sneak peak
2450 North Forsyth Rd
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 06:24 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
heater box? I'm in if you have it available.
AndrewT
'93 NAS D110 #437
Old July 25th, 2012, 06:27 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
PM sent.
SafariHP's Avatar
SafariHP
1983 Defender 110
Missing but we have new.....
AndrewT
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 06:53 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Cappings
Pics of cappings... interested......
Old July 25th, 2012, 07:02 PM
COphinest's Avatar
COphinest
Joshua Lipsey
2013 Defender 110
I'll take the left wing top/front and left Outer wing! I'll call tomorrow.
Do you have a matching right outer wing?
------ Follow up post added July 25th, 2012 04:04 PM ------
What brush hard is that in the background?
Old July 25th, 2012, 07:23 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Wings is wings.
The right outer skin has some small dents visible on the inside but looks perfect on the outside. Still working to take pics but here you go.
ID:	54659   Click image for larger version
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 07:24 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Poor images. They are partially stripped bare but straight and not rusted other than slight surface rust.
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 07:39 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Few more images of the wings. Just noticed that the left wing has an extra hole in the front for a marker light that should not be there but it will be covered by the headlight trim. The inners are painted with some sort of Bed Liner type stuff
ID:	54662   Click image for larger version
ID:	54664   Click image for larger version
ID:	54666   Click image for larger version
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 07:43 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Also NAS 94 Front Wing Panels
$135.00 Each , very good condition. Some burnt off paint and a melted head light bowl but seem to be good to go and include the side panels.
ID:	54669   Click image for larger version
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 07:44 PM
COphinest's Avatar
COphinest
Joshua Lipsey
2013 Defender 110
I'll take them. I'll give you a call tomorrow.
Thank you,
Old July 25th, 2012, 07:45 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Thank you,
Wings are licked and spit on. HA HA
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 07:56 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
do you have an NAS brush bar?
Old July 25th, 2012, 08:02 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Left it behind as it was damaged and the truck was full sorry.
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 08:14 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
More items
Here are some more items.
Chassis (Engine mounts are wrong) but we can fix very very good from what I can see $1000.00 Stripped Bare
94 NAS Side Body Cappings $50.00
Steering Shaft $50.00
Steering Column $125.00
Used hinges (seem OK) $20.00
Used Pedal Box $55.00
Light Guards (some peeling) $40.00
NAS Door Frames (In need of repair) free plus shipping
Fuel Pedal Assembly $50.00
ID:	54674   Click image for larger version
ID:	54676   Click image for larger version
ID:	54678   Click image for larger version
ID:	54680   Click image for larger version
ID:	54682   Click image for larger version
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 08:19 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Side body cappings licked at 150.00 not the rear corner ones just the hockey stick sides.
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 08:22 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Licking the hinges, the gas pedal, the steering shaft and the cage.
Thx
Ian
Old July 25th, 2012, 08:26 PM
COphinest's Avatar
COphinest
Joshua Lipsey
2013 Defender 110
I'll take the nas door frames
Old July 25th, 2012, 08:31 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Your nuts but OK. Might have a skin around someplace but I think I left them there.
Winter Park, FL
(407)517-4983
Old July 25th, 2012, 08:41 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Few more items and then I am done as I still have to put this stuff away for the day.
1. NAS Swing Tailgate that was taken apart for some reason that I can't say. needs to riveted back together. $250.00 (overall good condition)
NAS Trim (by the tailgate) 10.00 ea
NAS Tub Supports $6.00 ea
Pair R and L me thinks door strikers $23.00
NAS Air Cleaner Assembly $150.00 (trumpet goes with the box sorry)
Vent Flaps $100.00 for the pair
200 TDI Fuse Panel Cover $20.00
Rear Bench Seat Bracket Set (very good) $75.00
ID:	54684   Click image for larger version
ID:	54686   Click image for larger version
ID:	54688   Click image for larger version
ID:	54690   Click image for larger version
Winter Park, FL
(407)517-4983
nas, part
94 AC Fan Speed Resistor Location and Part Number Please Raleigh D90 Defender Technical Discussions 2 March 24th, 2012 11:47 PM
94 NAS project in CT 6500obo Gtidevil For Sale - Parts 75 January 28th, 2012 08:13 PM
NAS 94 Tail lights pacificwildfire Wanted 4 October 29th, 2011 04:46 PM
Diagnostic for 94 Def 90 NAS Charles LF Defender Technical Discussions 1 October 2nd, 2009 11:07 AM
Safety Device NAS D90 roof racks return (part 4) ECR Misc. Chit-Chat 77 March 24th, 2009 11:01 PM
