Mantec Like Spare Wheel Carriers $349.00 plus shipping - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old December 29th, 2010, 08:10 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
Just received several Africa Spec Wheel Carriers that are made by the same company that makes Mantec Carriers. These look the same or very close as I don't have one to compare the new ones to.
I've installed several of these and they operate perfectly. Sorry will not fit on a NAS tailgate without a custom made bracket.
Old December 29th, 2010, 10:47 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
What custom bracket is required? Does anyone have a pic?
Old December 30th, 2010, 07:54 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Should fit a NAS SW, but for the ST you'll need to modify the supplied bracket to fit around the bends in the tailgate.
Semper Fi!
Old December 30th, 2010, 06:26 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Wolf Fab is correct. The supplied bracket will not work with a tailgate as the center of the tailagte is recessed. On a SW the door is flush with the back of the tub. One would have to fabricat a bracket that accounts for the recess of the tailgate skin. Easy to do but not supplied.
Old December 30th, 2010, 07:15 PM
Rugbier's Avatar
Rugbier
Gustavo
Do this mount on existing holes or do you need to drill areas on a ROW truck?
NO SIGNATURE
Old December 30th, 2010, 07:16 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Frame holes are good but you will have the drill into the door and into the tub for the new brackets.
Old December 30th, 2010, 11:43 PM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
I have one on my SW. Great product!
My Rover doesnít leak oil, she is marking her territory.
Old December 31st, 2010, 12:08 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
pics on the SW???
Old December 31st, 2010, 09:22 AM
bjf's Avatar
bjf
barry f
94 ST #395
I put one on my 110 and just as an FYI you need to drill the rear crossmember, the body through capping and some holes in door where the existing mount would be. If you have a stock door and not a td5 these work great and are worth it. The design matches the mantec I had. Mantec has since updated the lower hinge mount so it doesn't cover the body. Really just a cosmetic thing.
Old January 1st, 2011, 02:59 PM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Here are some photos of mine installed. I had no problem installing it. Just ask Steve how easy it was for me to install.
ID:	34416   Click image for larger version
Old January 1st, 2011, 03:32 PM
SafariHP's Avatar
SafariHP
1983 Defender 110
Michael your the man. I know you were here in spirit.
carrier, mantec, shipping, spare, wheel
spare wheel carrier Astroswin Defender Technical Discussions 3 October 18th, 2006 08:14 AM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
Rear Spare Wheel Carrier DiscoDino Defender Technical Discussions 5 May 21st, 2005 04:35 AM
Discovery I Steel "wagon" spare wheel... RedRhinoProducts Wanted 0 December 8th, 2004 08:10 AM
Swing away tire and gas can carriers lrnasd90 Defender Technical Discussions 63 June 21st, 2004 08:33 AM
