Limited Time (Truck-lite) LED Light Special - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old March 15th, 2012, 10:50 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Smile Limited Time (Truck-lite) LED Light Special
Get your Defender ready for summer
Set includes the following items: (Truck-lite)
(2) Turn Signal Lights
(2) Stop / Tail Lights
(1) Reveres Light
(1) Variable load Flasher unit
These lights are plug & play meaning remove your old lights + Flasher and plug in the new lights and supplied flasher and you are set.
$395.00
All orders must be placed before cutoff deadline of March 31th
Old March 19th, 2012, 09:35 PM
Ray Bone's Avatar
Ray Bone
Ray Bone
defender.
Do they fit the euro model? If it does, I like to have a set please. Thanks
Old March 19th, 2012, 10:04 PM
RedD90's Avatar
RedD90
JNH
'97 D90
31th?
Hicktonite
Old March 21st, 2012, 03:50 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I had there LED headlamps. If these things are anything like the headlamps, they will be an awesome upgrade.
Old March 22nd, 2012, 06:59 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Guys,
I have posted a limited offer and our website: http://safaridust.com/NAS-LED-Lights_c8.htm
You can process the order anytime before the offer expires, but we will place a bulk order after the offer expires.
Turn around time is 2 weeks to your door.
These will fit Defenders with the mounting plinths, the LED connector end plugs into the stock OEM unit, completly sealed and have a stock look to them.
Tom
Old March 22nd, 2012, 08:42 AM
maleger
Marc-Andre Leger
Is the LED flasher a 4 pin relay ?
Old March 24th, 2012, 09:03 AM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
I like these Led lights a lot. Do these plug and play for stock 93/94 lights? How thick are the lights? is there a way to mount them flush on a 93/94 with out drilling large holes in the body to accomodate the rear end of the lights? i.e. Im wondering if I could mount them flush to the body with minimal drilling and feed the wires through the existing holes from the OME 93/94 lights. Thanks - great lights
Old March 24th, 2012, 09:55 AM
This should help. It's in mm's:
Old March 24th, 2012, 01:57 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
How come nobody makes the square lights?
Robert Deniro
Old March 25th, 2012, 03:47 AM
They do, but they're 24 volt.
Old March 25th, 2012, 06:48 AM
maleger
Marc-Andre Leger
I bought some 1994 square LED lights, but it's a lot more expensive than the lights proposed here.
It is discussed here:
http://www.defendersource.com/forum/...616#post297616
Old March 25th, 2012, 04:39 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
How much more would it cost to replace the front two turn signal lights also?
Old March 25th, 2012, 09:06 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
sorry for the late reply, relay is 3 pin model...
There is also a write up on changing over to these lights from the 94 square lights and what additional connectors you will need.
Old March 26th, 2012, 01:53 PM
In case there was any question on this, these are the same LED lights as you see on the ECR site that they show as NLA, and at Tom's price you're basically getting the relay for free and the reverse LED at the same price as the others, which is a significant discount over the regular price!
Tom, I'm curious if you'd also offer a kit price without the reverse LED, since that's by far the most expensive piece in the kit, and how much that would be? Just trying to be frugal for tax season, since the reverse is rarely used.
Tom may have more info on this, but I thought if you supply the proper 4 pin you retain the trailer light capability.
And to Dana's point, I'm not sure the LEDs up front and in back have been perfected yet. In the front you'll likely need to put in some resistors right after the connections, and with that, some luck as well - it's worked on a few trucks, and not on others.
And the 1994 question - there are a few options for LEDs, but I think in most cases you need to shave down the bezels a little bit on the LED kits of the square 1994 style, and always confirm you're getting the 12V version.
Old March 26th, 2012, 04:47 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
You are correct, 4 pin is needed for trailer light...not sure on availability and are pricey...but I can check.
We can also put together a kit without the reverse light..
Price would be $285.00 with the standard 3 pin flasher included
New Kit Price will be up on the site, so you can choose kit price "A" or "B" according to your needs.
Old March 27th, 2012, 07:23 PM
keiphers's Avatar
keiphers
Keith
1997 D90 ST #647
Ordered, thanks! Now y'all need to offer a replacement kit for the front...
'11 RRS Supercharged
'97 Defender 90
Old March 28th, 2012, 09:41 PM
Rufus's Avatar
Rufus
Rufus
Josh thanks for posting the pics with the measurements - that is helpful. I will re-read the 94 install post again for these lights -but i don't remember if my question is covered in that post. I am wondering if you install these with the OEM plinths, if you can mount them relatively flush to the body w/o having to drill large holes to accommodate the back end of the lights. With a 94 I am trying to see if I can install these with minimal drilling. Again these are awesome lights. Will you offer this deal again in the future? Thanks
Old March 29th, 2012, 07:02 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I feel your concern, you would use the OEM plinths to install these lights. absolutely minimal drilling required, the hole only needs to be large enough for the connector plug to fit thru. On the 94 if I remember correctly theres only one hole which the wires run thru. The plinths line up correctly and the look and feel is a clean factory look...the spacing is correct and the single hole with the 94 line up but is little offset but well within the plinth center hole for the wires to run thru and still cover the factory hole.
I hope this helps.
Old March 29th, 2012, 11:25 AM
rich3890's Avatar
rich3890
Richard Nesbett
95 D90 ST
Just ordered a set. Thanks for the deal and I can't wait to get them in a few weeks.
rich
Old April 2nd, 2012, 11:10 AM
I ended up just going with the full kit. Let us know what you find on the 4 pin flasher relay.
ht
Reverse led light part # needed FlaD90 Defender Technical Discussions 5 July 16th, 2010 08:35 PM
First trip in the truck rijosho Misc. Chit-Chat 28 May 9th, 2010 09:12 PM
A Great Read... CDN90 Misc. Chit-Chat 6 December 16th, 2009 12:25 PM
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Light Weight needs a good home Kevin For Sale - Vehicles 2 February 6th, 2005 01:01 AM
