Limited Alu-Box Group Buy Event - Page 2 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old August 27th, 2014, 09:34 PM
atlcruiser
david
many
Originally Posted by javelinadave View Post
Is your email not working? I sent you a few emails in the past few months and never heard back.
it is....pls try again
Terrence Anderson
Shipping Manager
URBAN LAND CRUISERS LLC
+44 404 915 1281
Atlanta, GA USA
URBAN LAND CRUISERS + ROVERS LTD
1st Floor, 2, Woodberry Grove
London
N12 0DR
UNITED KINGDOM
+44 020 8133 1557
Company Registration No. 09003009
Our new Vehicle Sales site:
Old August 27th, 2014, 11:49 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
1995 NAS Defender 90
List updated
A042 - 8 at special pricing
1 - Davis M.
2 - Andrew P.
3 - Andrew P.
4 -
5 -
6 -
7 -
8 -
A073 - 8 at special pricing
1 - Davis M.
2 -
3 -
4 -
5 -
6 -
7 -
8 -
A081 - 6 at special pricing
1 - Davis M.
2 -
3 -
4 -
5 -
6 -
------ Follow up post added August 27th, 2014 08:57 PM ------
I have a correction to make. The A042 and A073 actually are the same width and height. I had incorrectly the A042 as being longer. It isn't. The only difference between the two is the height. Both are 58cm x 38cm. Good news because it means the two different models are stackable with each other. Ignore my incorrect diagram. I will update it tomorrow.
Originally Posted by Tiktaalik View Post
I took some measurements of my D90 tub. Its empty with the exception of dynamat with a rubber mat over it. The tub is approx 90cm wide x 22cm tall x 121cm deep. Keep in mind that the tub depth varies greatly depending on what junk you have installed. I have NAS roll cage behind the seats as well as a dog guard so I get quite a bit less usable depth.
I have put together some rough layout options based on the tub and box dims. Please understand that this is a rough and unconfirmed guess-timation until I've confirmed with the real deal. None of the cases will sit exactly flush with the wheel arches. The one that comes closest is the A042. It is 24 cm tall and the wells are 22cm tall. It sticks up 0.8". I'm hoping that Toby can enlighten us further here. Stay tuned.
Tiktaalik™
Old August 28th, 2014, 10:58 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
D90 Layout options!
I built the cases in CAD using the correct dimensions so here's a closer look at layout options. Top row is A042, Middle row is A073 and bottom row is A081 shown both from the front and the rear. This makes much more sense than my previous drawings. All three models it turns out, fit the rear of a D90 extremely well. The one caution though is that if you have an internal (NAS or otherwise) roll cage or dog guard you need to measure your own vehicle to be sure. This is by no means a guarantee, just an approximation. I'm going to take some photos of Toby's A042 and A073 boxes in the back of my D90 tonight and post up so stay tuned!
Name:	A042 Front.jpg
ID:	101736   Click image for larger version
Name:	A073 Front.jpg
ID:	101738   Click image for larger version
Name:	A081 Front.jpg
ID:	101740   Click image for larger version
Tiktaalik™
Old August 28th, 2014, 11:14 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
The wheel arches are much too narrow for any of these boxes. Alu-Box has an 164 liter box that may fit but that would be a special order and is not included in this group buy.
how about on top of the wheel arches? How much does it stick out/overhang?
Tiktaalik™
Old August 28th, 2014, 11:55 AM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Excellent work/marketing! Thanks for the visualization! Awaiting cost on Friday....
Old August 28th, 2014, 11:58 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Hey, I'm helping myself just as much as I'm helping you guys. I'm just trying to figure out which size/model I prefer for my D90.
Tiktaalik™
Old August 28th, 2014, 12:07 PM
Remember non-NAS trucks have bulkheads, so that interferes with the front boxes in your layouts. also what out for the rear door stay, handles and such.
Old August 28th, 2014, 12:11 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Exactly. There are many unknowns which I cannot account for so it up to each individual to measure their own truck and decide the layout that suits them. Just posting these images as a general guide or best case scenario. I'm going to play around with Toby's boxes tonight to get a better idea.
Tiktaalik™
Old August 28th, 2014, 12:23 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Which one is the 42 liter model?
Old August 28th, 2014, 12:26 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Click on the images so that they open in a separate window. If you look at the name of the image (bottom left corner) it'll say which one it is. The top row is A042. It's the ones that almost are flush with the wheel arches.
Tiktaalik™
Old August 28th, 2014, 12:38 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Just confirmed the bulkhead difference. Without bulkhead the tub is approx 121cm deep. With bulkhead it is 116cm deep so the bulkhead reduces the depth by 5cm (2"). Since its a pretty tight fit to begin with that may interfere with having 4 cases in the tub. If you have a ROW D90 you may want to take accurate measurements before you order a set of 4 or more. That said it'll still fit two and a stacked set of two just fine.
Tiktaalik™
Old August 28th, 2014, 01:03 PM
mud ruts's Avatar
mud ruts
Chris Ray
97 Disco
If a special order comes up for the boxes on the wheel wells I'm in!
Mud Ruts Off-Road Rover Repair shop 614.301.1574
Old August 28th, 2014, 01:12 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
We can certainly look into the wheel well boxes - the length may be an issue as they are quite long.
Old August 28th, 2014, 01:21 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'll measure. Hang tight.
Old August 28th, 2014, 01:30 PM
mud ruts's Avatar
mud ruts
Chris Ray
97 Disco
It could be 2 that fit next to each other end to end.
Old August 28th, 2014, 01:39 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Box is 56l
125 cm x 27 cm x 21 cm
No problem for a 3-door 110, but too long for a 90
D-90 ROW well platform measures
112 cm x 35 cm (bottom) or ~26 cm (dropped from the inside capping)
Alternately there are smaller boxes - which two will fit side by side in a 90 without side seats
19l
53cm x 23cm x 19cm
Old August 28th, 2014, 01:49 PM
tpond
Toby Pond
110
Box is 56l
19l
53cm x 23cm x 19cm
Those are cool!
Old August 28th, 2014, 02:01 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Brian is right. I just measured as well. You're going to be hard pressed to find something perfect for the wheel arches without going custom because the dimensions are a bit odd. The issue with the wheel arches is that they requires a very narrow box. If I were to design a box for the D90 wheel arches I would probably make it 105cm long x 25cm deep x 28cm tall. Now, we could ask Ole if they would be willing to make a custom box for us but that would require a certain amount of people wanting to order it.
Box is 56l
19l
53cm x 23cm x 19cm
Tiktaalik™
Old August 28th, 2014, 02:33 PM
The "Troy" boxes were always a great choice for the wheel wells. Made to fit. http://www.defendersource.com/forum/...ead.php?t=7496
Old August 28th, 2014, 05:08 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Updated order list.
Only 3 left of the A042.
6 left of the A073.
4 left of the A081.
1 - Davis M.
2 - Andrew P.
3 - Andrew P.
4 - Buzz C.
5 - Buzz C.
6 -
7 -
8 -
1 - Davis M.
2 - Buzz C.
3 -
4 -
5 -
6 -
7 -
8 -
1 - Davis M.
2 - Buzz C.
3 -
4 -
5 -
6 -
Tiktaalik™
event
Exmoor limited edition cubby box bneri Defender Technical Discussions 8 July 23rd, 2014 12:24 PM
LINKING Event Calendar and Hitting the trail or an Event rijosho Support & Suggestions 3 August 7th, 2013 12:24 PM
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
GROUP BUY - HD Seat Covers from UK, All Models... RedRhinoProducts The Vendors Loft 0 December 10th, 2004 10:48 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
