“Kick panels” Cardboard replacement - Page 5 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
View Poll Results: Select year and A/C option that best fits your D90
1994 – 1995 With A/C 45 42.45%
1994 – 1995 Without A/C 28 26.42%
1997 With A/C 26 24.53%
1997 Without A/C 8 7.55%
Multiple Choice Poll. Voters: 106. You may not vote on this poll
Old April 27th, 2004, 09:41 PM
DBZ2009's Avatar
DBZ2009
Z
ex-1994 D90/ 2 j**ps
Dave,
I've actually been in Charleston(with the 90). I'm winding down the year here and will get back to you about ordering the kick panels when I get some time to start playing around with mods.
Joe
- did you pick up your new ride at LR Nashville or privately?
Old April 27th, 2004, 10:00 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Hi Joe,
LR Nashville
It was a certified white 99 series 1 Discovery SD with 40K on the clock.
Old April 28th, 2004, 12:04 AM
DBZ2009's Avatar
DBZ2009
Z
Hope they didn't break your bank!
Z
Old May 5th, 2004, 03:54 PM
jbird
Justin Bird
94 D-90 ST
Kick Panel - Availability
Are these still available?
Old May 5th, 2004, 04:37 PM
bugula
Keith DuFresne
'94 AA Yellow 90
Re: Kick Panel - Availability
yeah, i missed the boat on this too and my driver's side kickplate's starting to fall apart.
Old May 5th, 2004, 09:47 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Keith,
What year of D90 do you have? I still have kick panels in stock for the 1997 driver side and 1995 and up non A/C passenger sides.
If you are looking for a 1994 - 1995 drivers side I am currently out of them, but I will make more once I sell a few more of the 1997 driver side kick panels.
thanks,
Old May 6th, 2004, 02:46 PM
bugula
Keith DuFresne
'94 AA Yellow 90
i've got a 94 w/o AC, so i'll keep watching this thread for your update! thanks!
Old May 24th, 2004, 04:22 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
I (finally) installed my drivers side panel on the '97. It took maybe 10 minutes....pretty simple. No issues.
Old June 28th, 2004, 09:09 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I went to install mine but ran into a possible mounting issue (granted, I only dealt with it for 5 minutes as I was in the middle of cleaning a shed). My 94 has these rather large bolt heads as well as the clutch spring in that upper channel that when the plate is installed, force the top of the plate downward, pulling the channel out. I will look more at it this week but has anyone else seen these huge bolt heads there? Other than that, I agree that is only a 10 minute job.
Chris von C
[/size]
Old June 28th, 2004, 09:23 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Hi Chris,
Can you get a picture of the large bolt heads? I did not see anything like you describe when I test fit the panels on the 94, 95 and 97 D90's that I had access to.
I am sure we can find a way to get it installed
Old June 28th, 2004, 09:36 AM
chrisvonc's Avatar
chrisvonc
Chris von C
Sure thing... I will take some pictures tonight when I get home.
Chris von C
[/size]
Old June 28th, 2004, 12:59 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Dave,
What's the link to your product site again?
Old June 28th, 2004, 01:16 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
www.slickrockfabrication.com
Old June 29th, 2004, 07:37 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Here you go, a little grainy but you should be able to see the 2 bolt heads.
ID:	944   Click image for larger version
Chris von C
[/size]
Old June 29th, 2004, 11:47 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Hi Chris,
Kind of hard to tell from the pictures that you posted, but the bolts and spring look the same as the ones on the 94 & 95 that I tested the panels on.
Here are some pictures of the 94 that I tested, if you look close you will see the spring and the bolt heads in there.
Hopefully the pictures will help
Feel free to IM or PM me
Name:	DSC00030 (Small).JPG
ID:	947   Click image for larger version
Name:	DSC00028 (Small).JPG
Name:	DSC00029 (Small).JPG
Old June 30th, 2004, 07:28 AM
chrisvonc's Avatar
chrisvonc
Chris von C
You know what... your spring goes to the left, mine goes to the right up under the channel which is causing the problem. I am wondering if it was switched at one point while some work was being done or something. I'll see if I can switch it and try refitting.
thanks
Chris von C
[/size]
Old June 30th, 2004, 08:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Chris, you can put it on either side. It won't cause a problem.
Legend in My Own Mind.
Old June 30th, 2004, 12:07 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Kind of odd,
One that I tested it was on the right and one was on the left. The panel fit both of them regardless of the side that the spring was installed on.
Are you missing the foam that goes in between the dash and the kick panel? Without the foam in place it might not keep the panel spaced out the proper distance from the dash.
Just a thought
Old July 22nd, 2004, 10:07 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Just checking on any updates regarding a 94/95 Driver's side panel.
Whenever these are ready I want/need one.
If you need a 'group buy' I'm sure others will chime in.
Cheers,
Nicholas
Old July 22nd, 2004, 10:15 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Hi Nick,
Guess I underestimated the demand
But I will have more done soon
ac, panels
Jump seat cardboard replacement advice GaryBaxter Defender Technical Discussions 5 August 14th, 2007 02:57 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
