KAM Ring and Pinion $328 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old October 30th, 2009, 11:35 PM
Fivespddisco's Avatar
Fivespddisco
Justin Monnin
96 D1
Rover Dog is very proud to announce the Official Release of KAM gears in the USA. You may ask yourself, Why is this so important to the Land Rover community? Well, we have 8 game changing reasons that are sure to change your mind.
1) Reverse cut fronts!
2) The same price for standard and reverse cut gears!
3) (4.10) and (4.75) gears for you P-38 Lovers!
4) Not 1, not 2, but 3 choices of classic Rover gear ratios for you! (3.8) (4.10) (4.75)
5) Dyno static tested by Land Rover Engineers to be stronger then stock, (3.8) 70% (4.10) 25% (4.75) 50%
6) Each gear set is matched and lapped-in by a Gleeson lapping-in machine for optimum set up
7) All gear set are made from certified steels, dedicated drop forgings and carefully controlled heat treatments.
8) Best of all they are only $328 a set!
We at Lucky 8 are striving to be your first choice for Land Rover drive train. Let us know what we can do to earn your business
for more info http://lucky8llc.com/Search.asp?Manu=KAM
For expedition tested Rover gear Check out
716-898-8153
Old October 31st, 2009, 09:28 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Great to see this here.
legend in my own mind
Old October 31st, 2009, 09:35 AM
Fivespddisco
Justin Monnin
96 D1
Thank you Jim
716-898-8153
Old October 31st, 2009, 10:46 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Damn good price!
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Need 3.54 ring and pinion [alone] RedRhinoProducts Wanted 3 November 28th, 2005 09:19 AM
GBR 4.75 Ring & Pinion RedRhinoProducts For Sale - Parts 1 January 25th, 2005 02:16 PM
center section, ring and pinion, locker for sale vlocci For Sale - Parts 3 September 1st, 2004 01:35 AM
Stock OEM Ring and Pinion plus Diff kpracer For Sale - Parts 0 July 22nd, 2004 01:47 AM
ring & pinion krisp Wanted 2 April 23rd, 2004 12:46 PM
