Input/interest in LT230 increased capacity sump cover - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old October 20th, 2015, 11:11 PM
Project I've been toying with, a sump cover that adds ~21oz in extra capacity to the LT230. It's a straight bolt-on to replace the rectangular flat inspection cover with the unit shown below.
It certainly can't hurt to have an extra 5/8-3/4 of a quart in the LT230, as I know some folks intentionally jack up the rear of their Defender when filling the LT230 so they can slip a quart or so extra in there for sloshing around. This unit would alleviate that hassle, and allow for extra capacity automatically.
Anyhow, just figured I'd float it out there to gauge the interest level in such an item before I decide on whether to proceed with a run of them....the floor is open to input!
ID:	132903   Click image for larger version
ID:	132905   Click image for larger version
Old October 20th, 2015, 11:18 PM
I assume you know these are already made?
http://roamerdrive.com/ds_sumpcov.html
Old October 20th, 2015, 11:24 PM
Global Roamer Corporation
Well, I do now . Looks like that one is cast maybe rather than milled? Also looks like it doesn't fit the V8, which this one will (with many folks on here obviously rolling in NAS trucks).
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
not to rain on your parade…don't understand your V8 comment, I have one on my D2 and my 200tdi 110...
From the global roamer guy's…
Name:	Screen Shot 2015-10-20 at 8.21.37 PM.png
Old October 20th, 2015, 11:25 PM
Not raining...see above comments re: V8 .
------ Follow up post added October 20th, 2015 11:30 PM ------
re: V8 comment, I'm just reading left-to-right, top-to-bottom, grouping words together to make a sentence directly from their website:
"This cover fits all Defender models with diesel engines, but will not fit V8 models due to exhaust interference issues."
Take Tylenol for any headaches. Midol for any cramps.
Old October 20th, 2015, 11:37 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
really…didn't read it or notice because I already have 2 installed on my trucks and installed one on a 110 with a v8 conversion (14cux with auto box), but we did a custom exhaust.
so take a midol...
Old October 20th, 2015, 11:42 PM
really…didn't read it or notice because I already have 2 installed on my trucks and installed one on a 110 with a v8 conversion, but we did a custom exhaust.
so take a midol...
Custom exhaust routing I'm sure would change the ability to fit, but I think 99.9% of people on here are running a stock exhaust with a V8. So...back to my original point, on their own website it states it won't fit with a (stock) V8 exhaust. I'd say that leaves the discussion still open (and Midol-less on this end : ).
Old October 20th, 2015, 11:59 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Gotcha...the custom work was done with a hammer...
Go for it, I like the stuff you do
Old October 21st, 2015, 12:10 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
I'm interested.
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old October 21st, 2015, 12:36 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Might be interested--depends on price, I suppose....
Old October 21st, 2015, 05:17 AM
Ray_G's Avatar
Ray_G
Ray Gerber
I'd be in for Coyote, I'd wanted to go the route Mongo did but didn't want to BFH my exhaust..y assumption is a D1 & D90 V8 exhaust routing will be close enough to make it work.
Old October 21st, 2015, 06:47 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
If you can compete with their price I am in. I have been wanting to put one on for a while. I would rather give you my business.
Old October 21st, 2015, 08:10 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Not debating that extra oil capacity is good (certainly from the standpoint of heat removal), but the idea of jacking the rear up when filling isn't just to put more oil in the case, it is to raise the oil level in the case, to help with splash lubrication to the input gear splines located toward the top of the case. Not sure that adding capacity will help with this, as the oil LEVEL will still be the same, no?
~Scott T.
'95 D-90 ST - AA Yellow
Old October 21st, 2015, 08:22 AM
correct
Old October 21st, 2015, 08:39 AM
Add a threaded port/bung for an oil temp gauge sender please.
Old October 21st, 2015, 08:43 AM
87 D110 (Ruby)
JASON - i'd be in. Wouldn't that sump be the lowest point in the TC? Would it make sense to put a drain plug in it if that is the case....not under the truck (of course ) but just asking.
Either way I would take 2
Old October 21st, 2015, 08:44 AM
winner winner chicken dinner mine has been overfilled since 40k miles, at almost 90k the input is perfect, as for the rest of the driveline well its a crapshoot
Old October 21st, 2015, 08:51 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Or in my case, I know it will be low within a few months time due to parking brake lubrication---so I like to overfill it so there will be plenty of oil for the brake drum!
Rent my
Old October 21st, 2015, 09:36 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Put cooling fins on it... it'll make the truck go faster
Old October 21st, 2015, 09:45 AM
If this could also be designed to make the bottom of the tcase level with the ground and sturdy enough to provide a level surface so I can use a tranny jack without an adapter to install/remove the tcase, that would be worth it alone. maybe you could even incorporate some adapter features on the bottom to aid in tcase in jack usage.
And the expo thing to do is put a bottle opener on it. Come on now, keep up!
Mark Kellgren
KM4BOR
lt230, ac, cover
NAS Defender R380 with BMW Diesel input shaft + 1.2 LT230 Chip For Sale - Parts 6 April 30th, 2016 01:49 AM
LT230 input side thread holes Overlander Defender Technical Discussions 10 June 8th, 2013 01:03 PM
Increased limits chrisvonc Support & Suggestions 7 January 17th, 2008 08:17 PM
Increased limits chrisvonc Community News & Announcements 0 January 15th, 2008 12:42 AM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
