European trailer plug to flat 4 harness - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old October 1st, 2010, 03:40 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Atlantic British is now making the European trailer plug to flat 4 harness that would of been in the factory wiring harnesses in the 1990's through early 2000's.
http://www.roverparts.com/Parts/9438.cfm?bc=ab
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old October 1st, 2010, 04:55 PM
Finally, one that is LONG enough to be of use. It took me forever to find one when I was looking. The one that comes in the genuine kit is really short.
Old October 1st, 2010, 04:59 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Wow that was unplanned. I bought my wife a 96 P38 and it had one in the back we just copied that one.
Eric Riston
Old October 1st, 2010, 05:49 PM
I have discussed this before on D-90.com
The new genuine "kit" sold is the one for a DI/RRC/D90 is really a DI part. The correct old syle D90/D110 one (and, as you note, the p38a one) has the proper long cable to reach from the side mount. On a DI or RRC the plug is right next to the hitch so you can get by (barely) with the short one.
Old October 4th, 2010, 01:32 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Ron
Thanks for the info the web should be all updated tonight with the cars this fits
Eric
Eric Riston
Old October 22nd, 2010, 09:52 AM
phoenix37's Avatar
phoenix37
john
This does NOT fit a range rover classic plug. Just showed up and I need to send it back.
Old October 22nd, 2010, 11:47 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
What about adding (or replacing) a North American style 7-blade plug to the rear? does each European pin and associated wire correspond with one of the NA blades?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 27th, 2010, 04:51 AM
phoenix37's Avatar
phoenix37
john
Eric you may want to update your website to reflect this doesnt work on the classic Range Rover.
Old October 27th, 2010, 08:43 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
According to http://www.etrailer.com/faq-wiring.aspx the 7 pin flat plug is just an extension of the 4-pin. Don't think that will help much with the euro standard.
John, what did not work with the classic? The euro plug is "standard" just the euro->us adaptor is something added to the truck. The euro to 4-pin adaptor is simply a plug converter nothing much to it.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 27th, 2010, 09:08 AM
phoenix37's Avatar
phoenix37
john
The 7 pin plug on my classic is much smaller than the one on this kit. This one worked but the other one has a bigger 7 pin plug.
http://www.roverparts.com/Parts/9439A.cfm
Old October 27th, 2010, 12:35 PM
MonLand
Loic Fabro
I think there is a misunderstanding. The "new" part is basically an extension cord + euro trailer plug->us 4-pin converter. You can't use this without the adaptor that takes the tail light and stop light signal and convert them into a single signal (in Europe stop light and tail lights -have- to have a separate bulb).
The part (9439A) you gave us a link to does -not- use the euro trailer plug, instead it takes the internal rover trailer harness, mix the tail/stop light signal together -and- outputs 4-pin plug.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 27th, 2010, 01:02 PM
phoenix37's Avatar
phoenix37
john
aha! that explains it.
Old October 27th, 2010, 01:09 PM
Yup, sorry if I contributed to the misunderstanding. I assumed you had the genuine kit and lost this adaptor, not that you had some aftermarket kit that fell off completely.
Ron
Old October 27th, 2010, 01:16 PM
phoenix37's Avatar
phoenix37
john
Yeah i lost the whole assembly and thought this would be a cheap replacement. Oh well I learned something new.
Old October 27th, 2010, 03:14 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
gotcha, So i'd need something with smarter wiring to combine the signals regardless.
I only asked bc I have a 3' long 7-blade to 4-pin flat adapter left over from my mom's old suburban, and the universal 7-blade flat mount plugs are about $15 @ autozone.
~2008 GTI TSI
Old September 6th, 2011, 10:09 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
On my '95 D90 I have the 7-pin Euro plug, which is connected directly to the 7-pin wiring harness in the right side wheel well. There is no converter box. I also have the adapter that Eric lists here in this post, which is from my '98 P38.
When I connect the trailer all of the lights work except for the brakes, which makes sense given Euro standard of a separate connection for the brakes. Instead of installing a converter box is it possible to jump the brake wire into the left/right signal wires inside the 7-pin end of the adapter above? I haven't tried it yet, but it seems like it should work.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old July 17th, 2013, 12:40 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Does this kit work if it want to connect it to my 300tdi harness to run a us flat 4 trailer?
Old July 17th, 2013, 06:51 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
This will only work if you already have the European 7 pin plug installed. If so, then it works great. I use it on my P38.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old July 17th, 2013, 08:42 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Yes if you have the European 7 at the trailer hitch this will get you to a 4 flat at the trailer.
Eric Riston
Old July 17th, 2013, 08:47 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Currently I have nothing on both defender and trailer side. I plan to completely replace the wiring on the trailer with what will likely be a us harness and plug. I have nothing installed on my 300tdi harness for towing (that I know of). Am I better off going with the 9439A kit from AB then? Confused.
Help! need STC934 glow plug harness cabell Wanted 29 May 6th, 2015 08:05 AM
EFI harness plug rover4x4 Defender Technical Discussions 4 December 6th, 2009 08:04 AM
Trailer harness plug and/or connector type spoolin440 Defender Technical Discussions 14 October 8th, 2006 04:37 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
Do I have a trailer wire harness or not!! P1CR Defender Technical Discussions 2 April 7th, 2004 07:54 PM
