European trailer plug to flat 4 harness - Page 3 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old August 13th, 2013, 12:13 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by Manimal View Post
Yes!
Where do I get one of those?
I'll bring it down to you. We are headed to Mogfest this week and will be down your way Wednesday.
Old August 13th, 2013, 12:41 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Brian!
Old August 15th, 2013, 12:03 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
...and thats a negative. Leave it to the brits to make the plugs nearly identical except one is a mm or two smaller in diameter. I suppose I'll be snipping the plug. Thanks for the help Brian!
Old August 15th, 2013, 01:25 AM
Must be the whir worth sized version....,
Old August 15th, 2013, 08:37 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Which side will you snip? Truck harness or AB module side? Still interested to get the AB plug side.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 15th, 2013, 08:45 AM
I know it's probably no help, but I just cut the end off the AB thing, crimped bullets on the wires and plugged it in to the Series lighting. Hardest part was threading it up into the tub.
Loic I may have saved the plug, so if I find it it's yours.
Old August 15th, 2013, 11:21 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Bill, you have the male plug? If so yes, thank you!
Old August 15th, 2013, 12:19 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
I'm pretty certain that he will have the same left over plug that you do...
As an alternative I have the other side of the plug I brought down for you - so I suppose you could rewire the adaptor to add it to the AB side.
If you can find a half day this weekend you should come out to MogFest. I think it's only an hour SW of Portland.
Help! need STC934 glow plug harness cabell Wanted 29 May 6th, 2015 08:05 AM
EFI harness plug rover4x4 Defender Technical Discussions 4 December 6th, 2009 08:04 AM
Trailer harness plug and/or connector type spoolin440 Defender Technical Discussions 14 October 8th, 2006 04:37 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
Do I have a trailer wire harness or not!! P1CR Defender Technical Discussions 2 April 7th, 2004 07:54 PM
