European trailer plug to flat 4 harness - Page 2 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old July 17th, 2013, 09:02 AM
cjbenway's Avatar
cjbenway
Chris Benway
1984 LR 90 ( Hedrick Rover )
I used the adapter 7 pin to 4 flat, with no other conversion equipment. (ROW to a U.S trailer)
It works mostly. I get lights, brakes and turn signals on the trailer with my Rover lights off. However when the truck lights are on I lose brake lights. ....so it kinda works, but not fully. You need the electronic conversion box I guess.
Old July 17th, 2013, 11:32 AM
Your confusion is understandable.
The EEC trailer wiring system is different (IMHO better) than the US system.
Over there, there is a single standard, seven pin system, while here we have 4 pin, 5 pin, 7 flat, seven round and probably a few variations not listed. Additionally, in the EEC trailers have separate turn and brake signals, which isn't the case in North America.
Sometimes you will see a vehicle in Europe with two Euro style trailer connections. The second unit provides power from the towing vehicle for lighting inside the RV/caravan, fridge, an additional ground, reversing lights and caravan batteries.
The one you mention, looks right for your needs. Call Eric at AB xtn 231 to confirm
Old July 17th, 2013, 11:51 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Originally Posted by Manimal View Post
Currently I have nothing on both defender and trailer side. I plan to completely replace the wiring on the trailer with what will likely be a us harness and plug. I have nothing installed on my 300tdi harness for towing (that I know of). Am I better off going with the 9439A kit from AB then? Confused.
Yes you would need the 9439A providing your 300TDI has a plug behind the RH taillamp for it.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 17th, 2013, 01:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Pretty sure there are no plugs. There may be a stray bullet connector or two that don't connect to anything. Could that be it? PO made a mess out of the wiring. It actually had trailer break system when I got it but I removed it completely as it was poorly installed and was corroding.
Eric
Old July 17th, 2013, 04:58 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
the 9439A plugs in behind the taillamp to a factory plug. there is the harness end
Eric Riston
Old August 1st, 2013, 12:27 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Eric.
I received the 9439A kit but my 300tdi harness does not have the male version of the plug that comes with the kit. Where can I get one?
Old August 1st, 2013, 12:35 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Eric.
ebay uk...
I may have one laying around somewhere, will have to look and see when back in the shop.
Old August 1st, 2013, 12:40 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Brian. Is this it? Or this one?
Old August 1st, 2013, 08:24 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
It is neither of those those are the UK trailer end not the car end.
Eric Riston
Old August 1st, 2013, 08:45 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Ok. Anyone have a name or part number for the car end plug?
Old August 1st, 2013, 03:32 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
I didn't think it was available separately, part of the harness
Defender Parts, Service, Restoration, and Training
Old August 1st, 2013, 03:36 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Must have been removed from mine then by PO. Let me know if you find one laying around. Otherwise I'm just going to have to remove it and wire it in. Thanks!
Old August 1st, 2013, 04:14 PM
Hella manufactures the tow socket for virtually every euro auto manufacturer. The tow package wiring is an add on option for defenders as well as other Rover models and you can buy the rover version or the hella universal one from most any purveyor.
for example:
http://www.paddockspares.com/pm1137-...trics-kit.html
http://www.lrseries.com/shop/product....html?search=7 pin socket&page=1
http://www.johncraddockltd.co.uk/lan...der-to-98.html
Just the socket is available seperately as well
http://www.ebay.com/itm/Quality-Prod...item2ec8b25ec1
Old August 1st, 2013, 05:11 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Doug. Just a little background: I bought the 9439A Flat 4 Wiring Kit from AB. Turns out my 300tdi harness does not have the male plug that is supposed to connect to the plug in the kit (see image) so I would have to either find one or cut the plug and hardwire it in. I am looking for the male end of this plug. I assume what we're looking at here in the image is the female end.
Name:	Screen Shot 2013-08-01 at 2.07.03 PM.png
Old August 12th, 2013, 09:02 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Any suggestions what I should do about the plug on the AB trailer harness? Since I don't have the male end in my 300tdi harness should I just cut it off and hard wire it? Does anyone have a spare make plug?
Old August 12th, 2013, 09:09 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
If you decide to cut your plug from the AB kit side, I'd love to get it off your hands.
And... Might feel biased, but I'd look for the European plug (if there is one such thing) or do a proper splicing to keep everything tight and out of water's harm.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 12th, 2013, 09:43 PM
I have never seen that particular plug/kit. but I deal with 25+ year old trucks and wiring ...
Old August 12th, 2013, 10:51 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Like this...
Old August 12th, 2013, 11:21 PM
That looks much smaller than the UK plug. Is it an ex MOD vehicle?
Old August 12th, 2013, 11:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Yes!
Where do I get one of those?
Originally Posted by Mybluett View Post
Like this...
Help! need STC934 glow plug harness cabell Wanted 29 May 6th, 2015 08:05 AM
EFI harness plug rover4x4 Defender Technical Discussions 4 December 6th, 2009 08:04 AM
Trailer harness plug and/or connector type spoolin440 Defender Technical Discussions 14 October 8th, 2006 04:37 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
Do I have a trailer wire harness or not!! P1CR Defender Technical Discussions 2 April 7th, 2004 07:54 PM
