Defender SW door teaser - Page 2 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old May 15th, 2010, 12:02 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I am going to need a couple! Or more.
legend in my own mind
Old May 15th, 2010, 02:58 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Do we know/have a cost on doors yet?
Weldon
Old May 25th, 2010, 06:17 PM
I for one am dying for more information...
Old May 25th, 2010, 07:17 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Hmm, I'm pretty interested as well, then i guess I could sell the ST ones I have.
Robert Deniro
Old May 25th, 2010, 08:20 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Interested in at least one pair... maybe two
Legend in My Own Mind.
Old May 26th, 2010, 11:39 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Now if we could only find a source for cheap/er 110 middle doors.
Semper Fi!
Old May 26th, 2010, 01:08 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
G-
No way. I thought I could just put the roll up windows on my ST for the winter, Will they not fit?
Old May 26th, 2010, 02:40 PM
Originally Posted by Birdman View Post
G-
They'll fit fine. You just have to swap out the door strikers for station wagon ones. That's easy on a 95 ST, the holes are already there. You also have the correct door checks, so those connect right up.
Only thing might be to figure out what to do with the accordion gasket which carries the speaker wire to the door panel, since most of the MDT doors don't seem to have speakers. You might have to cut and add them if you are looking to have speakers.
SW doors are a tremendous upgrade in noise reduction.
Old May 26th, 2010, 02:51 PM
I think that's called a dongle?
Old May 26th, 2010, 03:35 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
OK, what about a '83 110 pickup cab with the removable door tops? New striker plates as well?
Chance
Old May 26th, 2010, 05:11 PM
Rugbier's Avatar
Rugbier
Gustavo
All you have to do is make me an offer
NO SIGNATURE
Old May 26th, 2010, 08:13 PM
Wolf Fabrication
Sterling Archer
'08 D3
Let's see, I already owe you $$ and the wife has cut off all LR funds. So how does $8, some chapstick, pocket lint, and some scratched sunglasses sound?
Or I can weld you some crazy lawn ornament out of all the left over LR part I have?
Semper Fi!
Old May 26th, 2010, 10:47 PM
Yep, definitely. If you've got any door with a lift-up handle (basically the same as the soft top - antiburst), you need strikers that go with the push-button handle-type doors.
Old May 26th, 2010, 11:04 PM
Rugbier's Avatar
Rugbier
Gustavo
you might be onto something there...... In Baltimore's Hampden area there are the " Artist " making sculptures out of hubcaps, and people go and admire them.... so maybe we create a LR Memorial in my front yard
...Or I can weld you some crazy lawn ornament out of all the left over LR part I have?
NO SIGNATURE
Old May 27th, 2010, 09:12 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Cool, thanks. Curious to see what these price out at. Everybody tells me I should keep the cool two piece doors, but windows that open all the way, latches that work and door panels that aren't falling apart sound pretty attractive. Guess I'm gettin' old.
Chance
Old May 27th, 2010, 09:53 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Chance,
The new doors are going to seal better, cut down on noise, should last longer than the old style and you can roll down the windows.
Only downside that I am aware of is that the push button doors can have the button freeze and if you have a ST it looks better with the door tops off compared to the SW style.
Old May 27th, 2010, 11:21 AM
On that note, I seem to be the only one that doesn't know what the differences are between the new style roll up doors, and the older (my style) doors. Can someone highlight for me please?
Old May 27th, 2010, 11:43 AM
the new doors are are all steel and galvanized
Old May 27th, 2010, 12:00 PM
The main difference is that the old doors have frames welded up from channel and the new doors have pressed steel one-piece frames. The new doors are also designed to accomodate motors for power windows and solenoids for power locks. The window regulators are different and not interchangble with the old style. New doors also have seals on the bottom like soft top doors whereas older trucks will have seals on the sill and nothing on the bottom edge of the door.
Its worth noting that the doors panels don't exactly swap between the two either. There are lots of other minor improvements like the vapor barriers being molded foam instead of being just crap plastic.
Old May 27th, 2010, 01:29 PM
crystal clear now, thanks.
door
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
For Sale: 1997 Land Rover Defender 90 SW WLDKGDM For Sale - Vehicles 10 January 20th, 2009 02:49 PM
1997 Defender ST wanted will consider SW ron Wanted 8 January 25th, 2006 12:20 PM
1997 Defender 90 SW for sale by original owner Defender-90 For Sale - Vehicles 5 June 17th, 2005 09:13 PM
