Crate 300tdi engine 5750.00 + shipping - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old June 1st, 2016, 05:34 AM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
300tdi Turn-key rebuilt engines. These engines are totally rebuilt from the ground up and also come with the following new and (reconditioned) parts:
Injector pump (recon)
injectors
lift pump
water pump
turbo (recon)
alternator
starter motor
timing assembly and belt
new clutch
Viscose fan
Serpentine belt.
We can deliver worldwide.
Any inquiries to julian@globallandrovers.f9.co.uk or globallandrovers@gmail.com
We can provide references for people in the USA who have had our engines.
30 day lead time ex works.
Shipping is normally between 450-650.00
We also offer Crate TD5 engines and Crate 200tdi engines.
www.globallandrovers.com
tel: 1 240 249 0507
Additional products:
Take out repower kits
300tdi repower kits for Defender, Discovery 1/2 and RRC from 2850.00 plus shipping
TD5 repower kits for Defender and Discovery 2 from 4450.00 plus shipping
Shipping of kits is from 650-850
10% discount for trade.
ID:	150705   Click image for larger version
ID:	150707   Click image for larger version
ID:	150709   Click image for larger version
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old June 1st, 2016, 07:19 AM
Naplm00
Matthew
Looks great. I'm not in the market to buy but for others:
Do you replace the Rings/hone
Do you replace the cam bearings and line bore for the original or fresh cam (200tdi)?
Is the flywheel machined?
Old June 1st, 2016, 09:53 AM
globallandrovers
Julian Kotting
Cylinder Block:
Pistons are removed inspected cleaned & checked, the cylinder bores are checked for size, ovality and parallelism and are rebored or honed as required, new pistons with rings or new piston rings are now fitted, the con rods are inspected for wear and refitted to the pistons, new big end bearings are fitted, the oil pump is inspected and cleaned and refitted.
Camshaft & followers are removed and inspected for any damage, cleaned and then refitted,(replaced as necessary). Cam shaft bearings are checked for wear and replaced as required, new oil seals are fitted with gaskets.
300tdi, engine, shipping, tdi
300TDI crate motor source? lrna04 Defender Technical Discussions 41 March 12th, 2013 11:57 PM
Storage Crate for Fiberglass Top Montgo1715 For Sale - Parts 10 November 3rd, 2008 03:03 PM
Anyone need a crate? Free! themaxx Misc. Chit-Chat 0 December 8th, 2007 08:18 AM
Crate coming West from RDS - who wants in? JimC Misc. Chit-Chat 0 November 22nd, 2006 03:50 PM
Best way to have crate shipped from UK? Chris Cox Defender Technical Discussions 1 August 16th, 2004 10:38 AM
