Anyone looking for more storage? - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old May 5th, 2009, 03:55 PM
007's Avatar
007
Eddie Cline
We have started making MOLLE mount products and trying to see if anything like these type items would be of use on you guys rigs? (not the bags, the mounts for them)
I've already worked up a side window area version, but concerned with visibility issues
ID:	19300   Click image for larger version
ID:	19302   Click image for larger version
Best Damn Nets, Straps and Grips you can get your hands on!
Old May 5th, 2009, 09:15 PM
fleabus's Avatar
fleabus
Dan
None :(
I could use a MOLLE mount for the rear door panel on my SW, but how would you keep it from sagging?
-Dan
Old May 5th, 2009, 10:14 PM
007's Avatar
007
Eddie Cline
-Dan
As shown, that one can carry lighter bags well with grommets and SS screws. It would also be workable to make a steel horizontal insert. What do you guys want to carry if we did that style?
EDIT: And thanks for the props on the nets, glad the pups dig 'em!
Old May 5th, 2009, 10:38 PM
fleabus's Avatar
fleabus
Dan
None :(
You know... stuff for work:
Machete
Water Bottle
Marbles
Latex Gloves
Electrical Tape
Tube Socks
Etc.
I like the idea of a steel insert... the rear door panel on the SW is almost 2x the size of a wrangler so might be tricky to have a larger mount w/o any support in the middle. Also, depending on the body style there might have to be some funky cutouts for wiper motors, hinges, latches, etc. Alternatively, how about a more "universal" mount that just goes across the lower part as shown in the photo below? Looks similar to what you already have for the jeeps.
Old May 5th, 2009, 11:28 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I'd love a net that would fit behind the rear seats of a ROW 110 (so no roll bar for it to attach to) with MOLLE for the bottom third. Essentially a net dog guard with MOLLE at the bottom so that visibility is retained.
Old May 6th, 2009, 12:14 AM
Can you make a hammock so I can sleep on top of my roll cage?
Old May 6th, 2009, 10:31 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
I don't think you could fit much of anything on the side doors but being able to hook a bunch of crap to my rear door?... yea, I'd be all over that.
Old May 6th, 2009, 11:34 AM
JPRO576's Avatar
JPRO576
blueboy
'96 Discovery Tdi
Smile Nice stuff
We had a cutomer with a new fj cruiser come by our shop the other day and he had those in his truck. Way cool stuff. Would definately be interested in a rear door mount system for a station wagon.
Old May 6th, 2009, 12:01 PM
007's Avatar
007
Eddie Cline
Gotcha, is it possible to add footman loops to mount the net to?
That's no problem at all, although we do already made an overhead (part R.5 and several other sizes) that would work for that. The capacity is 800lbs and up.
http://www.raingler.com/merch88Rover.htm
Machete
Water Bottle
Marbles
Latex Gloves
Electrical Tape
Tube Socks
Etc.
So, what's behind that panel, suitable metal to mount to? If so, let's get some measurements going. :
Old May 6th, 2009, 12:21 PM
specops1526's Avatar
specops1526
Beluga '97 90
I kinda like these:
http://www.4wheelparts.com/prodDetail.aspx?groupID=545
http://www.4wheelparts.com/prodDetail.aspx?groupID=544
can you make anything similar to these?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 6th, 2009, 12:41 PM
007's Avatar
007
Eddie Cline
Originally Posted by specops1526
Something similar is in the works, although our quality would far exceed the ones you linked to,
Old May 6th, 2009, 12:58 PM
specops1526
Beluga '97 90
Cool, looking forward to seeing them!
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 6th, 2009, 03:02 PM
If you took this same idea, and added steel braded and shielded cable, running it sandwiched through all the webbing, you would have the first "soft" internal dog/security guard I've seen, and I would definitely buy that. you could even do the same with the all the rear SW windows, and have the expedition rear security area, all mollied up for extra utility. I think we're onto something here.
Old May 6th, 2009, 03:40 PM
007's Avatar
007
Eddie Cline
We've actually offered something very much like that a number of years ago. Besides being extremely difficult to manufacture, they just didn't sell well enough to continue. We sold the remaining stock for well below our costs to make them unfortunately.
Basically, the only real benefit is that it's harder to cut (need wire cutters) but the attempt to cut them damaged the outer coating and required replacement.
We use 1,000 lb. strength UV and saltwater grade web and materials through out. I recommend tying the ends up into a wrap and knot to really slow someone down that is trying to get into the rig. Really helps a bunch on the grab and run type theft.
Old May 6th, 2009, 04:27 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
I have a ROW 110 and an internal cage is being fabricated this week. I plan to install this webbing behind the second row to contain my dogs or pelican cases. Gave some thought to the metal mesh dog guards, but prefer the webbing. I had one bad nightmare about rolling into a creek and my dogs drowning because I couldn't get the rear door open. Call me paranoid, but like the idea of being able to cut the webbing, if need be. Mark
Old May 6th, 2009, 04:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
More info on the cage, please!
Old May 6th, 2009, 07:03 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Nothing fancy or elaborate. Just something to provide one-time protection in the event of highway roll-over or flop on the trail. Three hoops; behind front row similar to CT110, behind second row, and rear of truck. Horizontal bars along the roof line using Ballistic Fab connectors. All hoops connected to the frame, plus some bracketry to tie into the B-pillars, etc. Will pass on images / details if interested when I get the truck back. Matt @ Rockware is doing the work.
Old May 6th, 2009, 07:53 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Very interested in seeing as many pictures as you are willing to take, I'd love to get one into mine.
Thanks!
Old May 6th, 2009, 10:31 PM
tell Matt to take lots of pictures (post here) and keep his patterns
Old May 6th, 2009, 10:43 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
The overhead one would be pretty sweet in the back of the 90. How wide is it? I'm concerned for the headroom of the occasional backseat passenger.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Storage Box for the Holiday? Troys For Sale - Parts 4 December 16th, 2005 11:59 AM
D90 Storage Boxes chrisvonc For Sale - Parts 8 January 27th, 2005 02:19 PM
Tuffy Storage Boxes ronward Wanted 9 September 29th, 2004 01:33 PM
Lockable Storage in D-90 chach Defender Technical Discussions 16 May 4th, 2004 01:18 PM
Vehicle Storage near Denver nickt Misc. Chit-Chat 1 April 5th, 2004 05:16 PM
