Announcing Five Tiktaalik Defender Products - Page 3 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old December 19th, 2014, 10:49 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
1995 NAS Defender 90
A small change of plans.
I did a brief cost analysis this afternoon and I have decided to postpone the production of the Large Headlight Guard set. Hitting the pause button on this product allows me to do two things: 1. I'll be able to fulfill your current orders sooner and, 2. I will be able to start the development of the Heritage Grill design. The large headlight guards are very expensive to make because the grills are cut out of a very large solid piece of 3/4" aluminum. Since no one has pre-ordered any at this time I would prefer to focus on prototyping the Heritage Grill instead. I will still proceed to finalize the prototypes for photography so we can see the final result and the design is finalized so it is possible that it can be made available as a built to order item.
So in the light of the above decision heres the new rough schedule. Final prototype parts (Golden Samples) will have finished the tumbling process this weekend. Beginning of next week we will assemble them and if the assembly goes smoothly I will place another order at the Laser cutting vendor to cover all the products that have been ordered so far. So the schedule should be expedited a bit by running things in parallel. By the time the prototypes comes back from the anodizer and are photographed your orders should already be in production. I feel pretty good about this. Feedback welcome.
Last item. I have received a couple orders of the aluminum headlight surrounds. This designs is 17% funded at this time, in order to pay for tooling. I'm really looking forward to these so I'm hoping to drum up some more pre-orders by providing you with some better photography of the current prototypes. Stay tuned.
Discount Quantity Status:
Small Guard set: 17 sets left at discount price.
Rear Guard set: 18 sets left at discount price.
OEM Grill: 15 sets left at discount price.
Headlight Surround set: 22 sets left at discount price.
Tiktaalik Bottle Opener: 17 sets left at discount price.
Tiktaalik™
Old December 20th, 2014, 12:12 AM
cbfritz_03
Carmen
none
If I could suggest. Guys if your girl has no idea what to get you for a present...ask for these! And girls vice versa. They are so well made and are going to look great on the truck. Would make an awweesome preeseent!!
"happy happy,,,"
Old December 21st, 2014, 11:26 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Thanks for the plug, Carmen.
Everyone's support is appreciated.
Tiktaalik™
Old December 22nd, 2014, 10:47 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Final Round
Here are some photos of the final round samples. The fit is now dialed in so that all parts tap snugly together. Because the different components now mechanically intersect they will be a lot more rigid and strong because it is not only the weld holding them together. The little squares on the front will be plug welded and sanded down then off to the anodizer where they will be blasted and hard anodized. Note that the mounts on the large guard should be installed in the opposite direction.
ID:	109828   Click image for larger version
ID:	109830   Click image for larger version
ID:	109832   Click image for larger version
Old December 31st, 2014, 10:55 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Prototype Updates - OEM Grill
Not a lot happening over Christmas and New Year and my fabricator is moving this week so the samples won't be welded up until next week unfortunately. The delays are killing me. During the test fit session I also noticed a required adjustment for one of the Rear Guard mounting brackets which will unfortunately delay this design slightly. In the light of this it is looking like the Small Guards and OEM Grill will be ready to ship first. I'm hoping that once my fabber is done welding them together next week that I can pull the trigger on your orders, get materials ordered and cut and get things moving.
Here's a closer look at each of the products starting with the OEM Grill prototype. They neglected to bend the mounting bracket which is why it is just laying on the floor. The slots in the vertical cross bars is to accommodate an accessory mounting bracket that I have designed so that you can mount lights etc directly to the grill itself. Shown is also a close up of the jig-saw puzzle interlock construction. I'm super-stoked about this design.
ID:	109834   Click image for larger version
ID:	109836   Click image for larger version
Tiktaalik™
Old December 31st, 2014, 11:39 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Carl:
How close to stock is the 'thickness' or 'depth' of the grille? I/e/ if measured from front to back as mounted on the vehicle? The light tabs on my A-bar touch the stock grille, so I doubt it'll fit if it's stock or deeper.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old December 31st, 2014, 11:49 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Update - Headlight Surround
Here are some photos of the very first prototype I did for the Headlight Surround. A couple of important things to note.
1. The marker/turn lamp holes are skewed to the right. This has been fixed.
2. This surrounds sits inside the lip of the recess on the front wing. It does not have a lip that overhangs the lip like the plastic version.
3. The final design will have the same reveal feature around the headlight. The hole on the prototype is larger because this feature is missing but on the final design (as CAD shows) this feature will be incorporated.
Unlike the other designs this one required (expensive) tooling before we can even see the first prototype from the factory. The fabrication process will be a combination of stamping and machining. It is critical to receive enough pre-orders for this one so we can get the tooling started (and start seeing samples). If you're thinking about it, I highly encourage you to pre-order so we can see this product come to life. These surrounds will ship bare, sandblasted aluminum, ready to be painted, powder coated or anodized. I have yet to test it on a Series but it should fit them as well.
ID:	109840   Click image for larger version
ID:	109842   Click image for larger version
Tiktaalik™
Old December 31st, 2014, 11:51 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
This is a great question, Paul. I know some of us have a very tight fit between grill/bumper/winch. The intent was that it would be the exact dimensions of the stock grill. To be sure though I will measure post up dims today.
Originally Posted by Paul K View Post
Carl:
Paul.
Tiktaalik™
Old December 31st, 2014, 11:58 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
That grill is beautiful.
Carl, what color will the final product be? Black? Silver?
Old December 31st, 2014, 11:59 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Update - Large Headlight Guard
Here are some photos of the Large Headlight Guard design that I decided to shelf for now. It's a pretty bad ass design though so I may resurrect it one day. The Horizontal bars look great with the horizontal bars of the grill. The with of the grill is the same as the Headlight Surround design and the top and sides line up with the surround when mounted.
ID:	109849   Click image for larger version
ID:	109851   Click image for larger version
Tiktaalik™
Old December 31st, 2014, 12:01 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Hard Anodized Black. It should look very similar to the stock grill when done.
Tiktaalik™
Old December 31st, 2014, 12:05 PM
jrose609's Avatar
jrose609
Jason Rose
Perfect thanks!
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Update - Rear Lamp Guards
Here are some photos of the rear lamp guard fitted. I ran into a minor issue that needs adjustment when test fitting it yesterday. The bottom portion of the brackets that are bent need a re-alignment of the mounting holes. No big deal just an unforseen time delay. When bending parts it can sometimes be a trial and error process, especially if there are critical hole locations that needs to line up. Last photo shows the first prototype (bottom) and the latest (top). I beefed it up a bit and added the interlock construction.
ID:	109853   Click image for larger version
Tiktaalik™
Old December 31st, 2014, 12:22 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Finally.
The bottle opener definitely needs more user testing Below is the status of what is left at discount pricing. As mentioned I hope that the Small Guards and OEM Grill will begin production next week. The Headlight Surrounds are 17% funded for tooling so spread the word so we can make it a reality!
A big thank you to everyone so far who have pre-ordered products, sight unseen for the most part. Your patience and support are appreciated. You are the reason these concepts and prototypes are allowed to become reality. I will do my very best not to disappoint. I have even received custom double wall boxes for shipping the OEM Grill in as there weren't anything available that fit well. Lastly, even if you're not ordering, spreading the word throughout the community or on other forums would be very helpful. I got banned on LR4X4 just for posting a mention!
Tiktaalik™
Old December 31st, 2014, 12:35 PM
kgottehrer
Kevin Gottehrer
1997 D-90 SW
Stuff looks fantastic!!! Can't wait to get the Real Lamp Guards and Grille on my rig!!!
Old December 31st, 2014, 12:59 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Thanks Kevin! Me too!
Tiktaalik™
Old January 12th, 2015, 08:13 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
The final samples of the Small Light Guards and OEM Grill have been delivered to me and approved. Tomorrow I will be placing an order with the laser cutter to cover all your orders of Small Guards and OEM Grills. I will post some additional photos tomorrow as well. Unfortunately the Rear Lamp Guards are delayed as I am redesigning the mounts for improved fitment. I will update shortly on the new design changes.
Tiktaalik™
Old January 13th, 2015, 04:24 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Lookin' good! Pm'd.
Old January 13th, 2015, 11:47 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
OEM Grill - Prototype Approved.
Here is the final OEM Grill Prototype. I will be placing an order with the laser cutter today to cover all current orders. I'm thrilled about this design. Its lightweight but very stout. The production units will be hard anodized black.I'm curious how many of you would be interested in the accessory mounting bracket.
ID:	110869   Click image for larger version
ID:	110871   Click image for larger version
ID:	110873   Click image for larger version
ID:	110875   Click image for larger version
Tiktaalik™
Old January 13th, 2015, 12:00 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Small Guard - Prototype Approved.
Small Guards have been plug welded from the back and sanded. I will be placing an order with the laser cutter today to cover all current orders. The production units will be hard anodized black.
ID:	110882   Click image for larger version
ID:	110884   Click image for larger version
Tiktaalik™
OJOP Quick Release Battery Connectors - Tiktaalik Group Offer Tiktaalik The Vendors Loft 163 February 22nd, 2015 01:30 PM
Introducing Tiktaalik Tiktaalik The Vendors Loft 37 July 27th, 2014 08:25 AM
Dyna products for Defender ditskovich Defender Technical Discussions 6 December 7th, 2009 05:32 AM
AMSOIL Synthetic Products javelinadave The Vendors Loft 0 January 5th, 2004 05:13 PM
