A few LEDs - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old October 31st, 2013, 02:12 PM
RoversNorth
RN
2012 Land Rover Defender
A few LEDs
Trying to move through some stock on clear(with different colored LEDs) lamps here. Happy to do $20/per for a set of 5 or more.
LED6590 Clear lens stop/tail lamp 2.75" Reg $29.95 Now $22.50
LED6186 Clear lens rear directional lamp 2.75" Reg $29.95 Now $22.50
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old October 31st, 2013, 02:20 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Can you put an original lens on them if you prefer the Factory Look? I don't care for the White Lens' but like the base.
Old October 31st, 2013, 02:24 PM
RoversNorth
RN
We do carry the red and amber versions if that helps:
http://landroverparts.roversnorth.co...2fTAIL-LED-RED
http://landroverparts.roversnorth.co...ONAL-LED-AMBER
Rovers North
Old October 31st, 2013, 02:30 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Thank you, but I still prefer my OEM lens' is it possible to still use them?
Old October 31st, 2013, 02:33 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
I went yo your website and I don't see the specs on these. Anybody use these and has a picture in the dark, and also compared to stock how much brighter.
If we buy 8 are they a better deal, what about the needed relay?
Old October 31st, 2013, 02:36 PM
RoversNorth
RN
Not with these bases unfortunately.
------ Follow up post added October 31st, 2013 02:38 PM ------
What kind of specs are you interested in? They are quite bright, I'd compare them to stock but every Defender in our yard is now running LED lights.
5 & up is all $19.99
Rovers North
Old October 31st, 2013, 02:43 PM
Way brighter...
Old October 31st, 2013, 03:07 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The pictures do not do the unit justice, but they look identical to the factory lights, just in LED form.
Have a set on our 110... nice and bright and reliable.
I was sick of fixing the stock poor quality grounding on the early units that prevent the bulb(s) from glowing.
RDavisinVA
Old October 31st, 2013, 03:21 PM
Are the waterproof? edit: forget it... It is stated on the site page...
Old October 31st, 2013, 03:45 PM
Ben01
Ben
Defender
lights turned, wrong phot before
Old October 31st, 2013, 03:47 PM
Ben01
Ben
Defender
these are actually slightly brighter (or seem that way) than the colored sealed beam leds.
Old November 1st, 2013, 12:18 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
"Quite bright" is a little obscure.
What is the lumens output?
Ideally that should be posted in the specs.
Rigid industries, JW Speaker etc all declare the lumens output.
Old November 1st, 2013, 01:09 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Do you also have the front clear (white) side marker and turn signal lamps? I'm interested in a front set if you can provide lumens spec for them.
Old November 1st, 2013, 10:02 AM
RoversNorth
RN
As we are not the light's manufacturers we are not able to rate them, but I will attempt to find their lumen output.
http://landroverparts.roversnorth.co...KING-LED-CLEAR
http://landroverparts.roversnorth.co...489&type=0&eq=
I believe these are what you are looking for? I will do my best to get the lumen output.
Rovers North
Old November 1st, 2013, 10:20 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Carl:
While your question has merit, be aware that it does not fully take into account the general brightness of the LED units themselves under the lens which is what others will see... while the light output on the scale won't reflect the internal brightness which is what these lights "bring to the visibility table". In other words, they are brighter in output, but the numbers will not do justice as to just how bright they appear when you look at them. On our early 110 the brake lights are factorial in visibility.
Hope this helps.
RDavisinVA
Old November 1st, 2013, 10:34 AM
What are the lumens output(s) of all of our stock lights?
There are some shots of my LEDs in my registry entry.
http://www.defendersource.com/forum/...ad.php?t=35786
Old November 1st, 2013, 12:12 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
That's why anyone serious about this will measure and publicize both Raw and Effective Lumens.
Raw is the output without loss occurred by lenses, etc.
Effective is the actual measured output after all losses.
I just think its a bit of a pointless discussion if you don't have numbers to compare products with because 'similar' products can range from $200 to $2000. If specs aren't publicized you wouldn't know that one puts out 1500 lumens and the other one 20 000 lumens. A world of difference. You won't have accurate apples to apples comparizon by saying 'they're bright' or 'they're really bright' There's tons of cheap crappy LED's out there and of course they won't publicize specs.
That said I really like these RN LED lights as they appear close to stock and they are fully waterproof. I replaced all my stock lights with drop in replacement LED bulbs from superbrightleds and they are very bright (my parking lights are 220 lumens) but that didn't fix the crappy waterproofing foam seal the stock lights have. The foam seals degrade and compress and will eventually let in water.
Could you imagine comparing motors (etc, etc) without referencing horsepowers or torque?
Specs matters that's all I'm saying. Otherwise you'll never be able to make educated decisions when comparing products and price points.
Originally Posted by rdavisinva View Post
Carl:
Hope this helps.
Old November 1st, 2013, 12:16 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Are those before/after photos of stock vs RN LED?
Nice steel wheels Josh! I must not have paid attention as I thought you still had boosts.
Looks really great.
What size are those tires and where did you get them.
I have a set of steel rims waiting for install.
Old November 1st, 2013, 12:34 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I'd be in for a complete set of 8 in the proper colors (red/amber at rear and clear/amber up front).
Assuming they are plug-n-play (no relays or other wiring required).
Is there a validation code for this deal, or should I call?
Old November 1st, 2013, 12:39 PM
i'm also interested in a complete set in proper colors as well.
(same as jackie)
95' D90 - daily driver..
RDX LED's? Jbullis Smaller Projects 9 October 9th, 2013 05:51 AM
LED's installs - Lets see 'em JimC Defender Technical Discussions 73 August 30th, 2012 12:05 AM
Safari Dust LEDs CDeWan Defender Technical Discussions 1 May 4th, 2011 09:36 AM
Adding leds for engine infos JFD Defender Technical Discussions 0 April 30th, 2010 03:56 PM
