300tdi Conversion for Auto V8 D2 - Defender Source
Go Back   Defender Source > Classifieds > The Vendors Loft
Old September 22nd, 2015, 07:31 PM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
Discovery 300tdi auto kit for Discovery 2
Full engine with harness , full engine bay kit with all hoses, pipes, radiator pack, auto gearbox with transfer box complete , full bulkhead harness with dash unit front & rear prop-shafts
3450 Plus Shipping.
How to do the conversion:-
Gearbox/transfer box
Remove old gearbox bolt replacement 300 auto back in the same place has was the V8 auto, no mods needed just bolting in.
Engine
Remove old V8 engine remove/cut off engine mounts on chassis, fit 300tdi engine to replacement auto box bolt up, before welding on 300 engine mounts to chassis, fit replacement radiator with the frame & intercooler as 1 unit, fit fan cowling to radiator frame, fit fan to engine adjust height of engine until fan fits into fan cowling, now allow a little height to the engine & weld engine mounts to the chassis; after engine is tested on its mount, check that the fan still fits into cowling, now fit all water hoses, intercooler hoses, air filter box etc.
Wiring harness for engine
You can use the old engine harness from the V8 engine, some wires to do not to content & use the ecu to run the rest of the cars electrics; all depends if you still have air bags fitted & height control, Rev counter wire to alternator, if it does not work then wire to speed control switch on bell housing speed sensor, the other way to wire is to remove the dash harness completely & fit the 300tdi harness & clock pod & use the 300 engine harness, I hope this info helps.
Inquiries to globallandrovers@gmail.com or call 240 249 0507.
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old December 16th, 2015, 11:36 AM
globallandrovers
Julian Kotting
Now 10% cheaper until the 31st December 2015.
Old March 28th, 2016, 11:37 AM
globallandrovers
Julian Kotting
Bump, we also have available TD5 manual and Auto Kits for converting Discovery 2's to TD5. Kits are 4450.00 each
300tdi, conversion, tdi, v8
Arles Blue ST - $19,500 OBO Auto Conversion rijosho The Flea Market 29 January 20th, 2013 10:34 PM
Auto Conversion Idle Help mpsteil Defender Technical Discussions 12 February 10th, 2010 03:55 PM
Tdi/auto Conversion. How Much? mountainviewrover Misc. Chit-Chat 39 May 10th, 2008 10:33 PM
93 D110 auto transmission conversion bcourtney Defender Technical Discussions 37 June 8th, 2007 08:37 PM
Manual To Auto Conversion willtillery Defender Technical Discussions 2 September 22nd, 2004 10:12 PM
