Garage build Thread - Defender Source
Go Back   Defender Source > Non-Technical Discussions > Artwork & Doodles
Old May 4th, 2016, 11:59 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Garage build Thread
I will be renovating my Garage over the next few months. I am not a fan of other garage sites so I will post here. I noticed on other threads some innovative door openers that really help my build out.
Over the next few months I will do the following:
1. New roof
2. New siding
3. Change from two doors to one large door
4. Add a side door to the garage
5. Add a large Window A/C unit
6. Run a sub panel (60 Amp)
7. Plywood the walls up to 4' then probably transition into Sheet rock
8. Add a small winch at the ceiling for lifting small items (up to whitetail deer size)
9. Adding Internet (WIFI booster)
10. Getting rid of other peoples Rover parts.
Old May 4th, 2016, 12:07 PM
rovertrader's Avatar
rovertrader
Dale
Sounds like a good plan, but help me to know how to accomplish #10 please.
Old May 4th, 2016, 12:30 PM
Originally Posted by rovertrader View Post
....how to accomplish #10 please.
One phone call to the local scrap dealer.
Old May 4th, 2016, 12:33 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I would spend some time thinking about the electrical power you need based on what you plan on doing in your garage. If you are going to have a big compressor, a lift, AC/heater, and a welder, then you will need 240v in addition to 120v, and probably more than 60amp service. I have both sockets around the garage, as well a several circuits on 30 amp breakers for the big power users. I have 100 amp service in the garage, and I have issues if the compressor kicks on while I am using the lift or welder. Much easier to fix before the dry wall goes on.
Angus
Old May 4th, 2016, 12:38 PM
tjfslaughter
thomas
Burbon
I only want to use two breakers from my main panel in the house, I was thinking a double 60 breaker would do the trick, this would send 60 Amps @ 240 to the garage. I am not a big compressor guy as my ears are already shot. My little compressor has done the job for me for the past 10 years (small portable Emglo). On the heat side I have a diesel fired heater that does the job, it sits outside and ducts into the space, I am also talking to a board member about a pellet stove so I can phase out the diesel heater.
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I would spend money adding heat before putting A/C in. But I'm guessing you have heat already. I usually work with the door open in the summer anyway.
Old May 4th, 2016, 12:42 PM
tjfslaughter
thomas
Burbon
I have a surplus military heater that will do the job until I can go pellet. It is 100kBTU.
Old May 4th, 2016, 12:44 PM
I prefer plywood for all the walls. Makes hanging things easier. You do have to be careful with building codes wrt to fire ratings though.
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Excellent. It sounds like you have a plan. One other thing to consider is putting outlets on the ceiling between the bays for pull down extension cord reels. I plug the battery tenders into them when storing a car in the bay and it keep from having cords all over the floor when working. Good luck!
Angus
Old May 4th, 2016, 12:48 PM
tjfslaughter
thomas
Burbon
Great idea, I also plan to put in hard piping with proper drains in for the air lines (galvy) around the perimeter.
Old May 4th, 2016, 12:56 PM
You can just use copper water tubing and fittings for the air lines. Cheap and easy.
Old May 4th, 2016, 01:02 PM
tjfslaughter
thomas
Burbon
Thanks for the thought. I get a steep discount at the local plumbing supply house, I will look into this. I am not a bad solderer either.
Old May 4th, 2016, 01:20 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Tom -- post some before pics.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old May 4th, 2016, 01:23 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
How come this thread is under artwork and doodles??
Old May 4th, 2016, 01:24 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Consider a Split System for HVAC?
You may want to consider a Split Circuit (often called Ductless as well) HVAC that does heat (heat pump cycle) and AC. They have a lot of decent units for not a lot of money, and the indoor units are small and easy to place..
Mitsubishi is one of the original, and more well known names, but many manufacturers make them now..
http://www.mitsubishicomfort.com/products
And a Jackshaft Style opener for your new door..
http://www.defendersource.com/forum/...tml#post734928
And don't forget good ventilation..
~Scott T.
'95 D-90 ST - AA Yellow
Old May 4th, 2016, 01:25 PM
tjfslaughter
thomas
Burbon
Two things.
1. My Garage will be a piece of Art when done.
2. Nobody uses this section and I hope other Rover garage builds happen in this section as well.
Old May 4th, 2016, 01:33 PM
Contractor's Avatar
Contractor
Will
1969 IIA
1. New roof
2. New siding
Sounds good, but reconsider the 60 Amps.........go bigger. If you weld, run any equipment or even think you might, you are going to want more power.
I have 60 amps and am teetering on needing more.
Old May 4th, 2016, 01:36 PM
tjfslaughter
thomas
Burbon
I will see what the largest double breaker my panel in the house can hold, I might be able to do a 80 or 100 Amp. Getting the proper wire/panel is a non issue.
Old May 4th, 2016, 01:41 PM
Chris B
72 + D1 drivetrain =?
Bigger on amperage. Cheap to do the upgrade to 100amp now. Don't forget to plan the air line plumbing from the compressor before the build......And a great sounding radio to crank up all the music you want.
Old May 5th, 2016, 08:14 AM
rmuller
Ryan
If your house layout allows for it, put the compressor outside in a shed or something. That's what I was able to do, so I hardly hear it kick on.
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
LR Garage Thread tjfslaughter Support & Suggestions 3 April 29th, 2016 01:33 PM
Garage Sale! Garage Sale! Garage Sale! valsol The Flea Market 6 November 20th, 2013 01:18 PM
Series 109 on 110 Frame pics or build thread? phoenix37 Series Technical Discussions 3 July 26th, 2013 08:22 PM
