Your Rovah So Fat... - Defender Source
Old March 9th, 2013, 07:46 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Finally weighed my 110: 5900lbs.
That's with a full tank a fuel, a rear drawer full of tools, and spares under the middle row seats. This is my typical "empty" driving weight.
If my memory serves me, the NAS110 empty weight was 4850, with a GVW of 6800lbs. So I essentially have about 1100 extra pounds over a NAS110, to include the diesel motor, and all the armor, which I don't think is too bad.
Even fully loaded in expedition mode, I bet I still squeak in under the 6800 GVW.
Anyone else "fat" or weighed their trucks?
Name:	people-are-strange-fat-man-coming-out-of-seven-eleven-with-a-super-gulp-as-big-as-he-is.jpg
Semper Fi!
Old March 9th, 2013, 08:06 AM
Yep. I was just over 6100. When we were deploying to Botswana, I had my 110 at the tarmac at Pope AFB at the big weigh scale, and we talked them into letting me drive it up for a weigh in. Since then I've been more sensitive to weight.
Yours is like Wynonna Judd. Mine is like is like Rosanne Barr. In other words, I'm a fat pig you skinny beeyoch.
With the RTE HD suspensions though and the rear disc conversion, it seems to handle it quite fine. I've had 6 adults in there and there's no sag and braking is manageable.
Mark Kellgren
KM4BOR
Old March 9th, 2013, 08:10 AM
Wolf Fabrication
Sterling Archer
'08 D3
We have a scale here at our TMO office we can use for free. Once I get I my truck fully loaded I'll roll over there and check out my full weight.
But I agree on the handling. I don't feel like I'm rolling in 3 tons. The truck handles surprisingly well with a Tdi, disc brakes, 35s, 4.10 gears, and a rear sway bar.
Semper Fi!
Old March 9th, 2013, 08:28 AM
RRC 4860, I think the 90 was 4680
Old March 9th, 2013, 08:34 AM
Wolf Fabrication
Sterling Archer
'08 D3
I'm not feeling so fat then.
Semper Fi!
Old March 12th, 2013, 04:32 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Rolled mine onto a CAT scale at a truck stop outside Ft Bragg just for shits and giggles once. 4200 lbs empty and just me in it (Im about 170). Ive always thought that was a little low.
1985 Land Rover 110 3-door ST
Old March 12th, 2013, 04:45 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
I had to get my exmod weighed when I registered it. To make it as light as I could I removed the jack, the spare tire, etc. Had no floor mats, no load area mats, but left the door tops on.
Got it down to 3700 lbs.
Old March 12th, 2013, 04:50 PM
fwiw a tdi engine weighs pretty much the same as a 3.9/40 v8.
Old March 12th, 2013, 05:25 PM
Wolf Fabrication
Sterling Archer
'08 D3
200/300tdi is 270kg, the V8 is 230kg. A difference of almost 100lbs.
Semper Fi!
Old March 12th, 2013, 06:08 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
My RRC was right about 5100 with no rear seats and all my tools and rescue junk in the back.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
Old March 12th, 2013, 07:56 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Last time I used the 90 to haul old blacktop to the yard it weighed 4280# when I left.
Old March 12th, 2013, 08:09 PM
thats the engine weight, then theres the heavy ass harness, ecu, vapor recovery canister, additional in tank pump, heavier radiator, y pipe with cats, etc.
Old March 13th, 2013, 03:30 AM
Bolson
Ben Olson
1995 Defender 110
I weighed my 110 on the truck scale at work as I was leaving the yard. 2200 kg or 4894 lbs. that's a row 300 tdi with 3/4 of a tank and my fat butt all stock except for a tire carrier and steering guard
Old March 13th, 2013, 06:05 AM
aka rover's Avatar
aka rover
ed angel
95 D90
My 109 loaded with gear, water tank empty spare fuel tanks empty weighed in at 6150 lbs. I would think at its heaviest she would waddle around at 6400lbs baby got back...
85 D110 3.5 3 DR
Old March 13th, 2013, 06:25 AM
Wolf Fabrication
Sterling Archer
'08 D3
Tdi's have motor specific ancillaries too - sedementor, intercooler, etc, not to mention diesel fuel weighs more than gas at just over 7lbs per gallon versus 6lbs for gas. That's 20lbs in fuel alone.
What else ya got? Next you'll tell me the V8 setup has more cooling capacity.
But I concede it's probably a wash and comes out pretty even between the two.
Semper Fi!
Old March 13th, 2013, 09:00 AM
Point was it's a wash when doing a conversion. Trucks sit pretty much exactly the same before and after. But no doubt the cast iron tdi block vs aluminum v8 block the tdi engine is a bit heavier in the engine hoist.
FWIW most tdi's that have passed through my hands have not had sedimenters. Not sure why. Perhaps an option lthat most don't opt for ?
Old March 13th, 2013, 09:18 AM
Wolf Fabrication
Sterling Archer
'08 D3
Yes, and I already conceded your point...see above.
Semper Fi!
Old March 13th, 2013, 09:40 AM
That's one fat yotch right there.
I'm guessing the external cage on Wolf and my trucks add quite a bit of weight compared to ROW trucks without.
Mark Kellgren
KM4BOR
Old March 13th, 2013, 09:46 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Comes out pretty even till you try to merge into traffic on the highway. Then a bit less so.
I do wish I'd weighed my old truck-I think I have a TMO reference point somewhere-as one of the reasons I built lighter this time around is because of the 2nd and 3rd order effects of making a truck over engineered and over equipped is they become untenable for driving to/from events...and if that's the case, what's the point?
Old March 13th, 2013, 09:47 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
You are PHAT.
I got my Stage One weighed when I was carrying some scrap metal to the recyclers - I think my empty weight was between #2500 ~ #3000.
Of course, this is a basic 109 with a soft top but I do have some decently heavy sliders and a meaty front bumper.
Firemanshort
1980 Stage One 109
Sterling, VA
Big Fat NAS 110 Registry Thread JimC Misc. Chit-Chat 359 August 30th, 2017 03:11 PM
1989 Fat Chance Team Comp L/XL $900 alastair The Flea Market 6 February 17th, 2017 01:02 PM
Any Fat Tire bike owners on here? usadventureracing Misc. Chit-Chat 25 November 20th, 2012 11:33 AM
Rovah Farm Outing, ME steinhnj Trips, Trails and Events 6 October 17th, 2006 02:43 PM
bumper/brushguard-trade 4 case of fat tire Gore Ranger For Sale - Parts 13 February 15th, 2006 07:26 PM
